But if I copy the folder to Dovi_Tools after selecting 3-1, it doesn't ask me the MDL or borders I want to use. So how does it know I want option 7 and 0 borders?RESET_9999 wrote: Thu Feb 22, 2024 3:18 pm https://www.youtube.com/watch?v=jBqbG5XM54g
if your folder with files all have the same MDL and Active area, you don't have to provide external config files.
Trees
if you input a folder and no config file is found, it will ask you for a MDL and L5 which will be used for all the videos in the folder.
If the videos in your folder are cropped, the script won't ask you about it and will automatically set L5 to 0
Trees
Dovi_Tools usually doesn't ask me to choose an MDL or L5 when I input a whole folder. Edit: Weird, it does now. Typical!RESET_9999 wrote: Thu Feb 22, 2024 5:58 pm if you input a folder and no config file is found, it will ask you for a MDL and L5 which will be used for all the videos in the folder.
I also cannot seem to choose and MDL of 10000, I think I could in the past. Has it been removed? Also, is there are difference in HDR quality when choosing a, say, MDL 10000 over 4000?
Shellsobig30
Do you mean the OS HDR sends incorrect static metadata even when using MadVR with HDR Passthrough? Is NV HDR any different?RESET_9999 wrote: Tue Feb 06, 2024 9:18 pmno i think the OS HDR always sends incorrect static HDR10 metadata.sw5163 wrote: Tue Feb 06, 2024 6:57 pm Is there a way to disable tone mapping in Movies & TV app or energy player with MSFT HW video decoder, and pass through HDR10 metadata? Or do I have to use MPV for passing through HDR10 and switch to MSFT HW video decoder for tone mapping DV content?
Yes, 4000 MDL looks much darker vs 1000. As for the metadata, the L1 max and min are the same but the avg is not calculated the same. Trims are also different.Trees wrote: Sat Feb 24, 2024 4:22 pm Also, is there are difference in HDR quality when choosing a, say, MDL 10000 over 4000?
see: https://slow.pics/c/xlgE3H1t
this the only MDL possible in resolve and CMI also cannot seem to choose and MDL of 10000, I think I could in the past. Has it been removed?
afarvvik
hi @RESET_9999 is dovi tools available for arm64 linux anywhere?
dovi_tool cli: yesafarvvik wrote: Wed Feb 28, 2024 2:59 am hi @RESET_9999 is dovi tools available for arm64 linux anywhere?
dovi_scripts: no
frrilay
Hi RESET, using cm_analyze to generate DV will result in a CMv4.0 file with latest algorythm; what exactly do you loose when converting this file down to CMv2.9? The goal being to make it compatible with ATV for example (and even when Infuse adds support for CMv4.0, I understood from your previous posts that ATV doesn't handle CMv4.0 perfectly).
Taking the occasion to say merci beaucoup for your hard work
afarvvik
could you please provide a link, it is not on the github page & googling did not help. thanks.RESET_9999 wrote: Wed Feb 28, 2024 2:11 pmdovi_tool cli: yesafarvvik wrote: Wed Feb 28, 2024 2:59 am hi @RESET_9999 is dovi tools available for arm64 linux anywhere?
dovi_scripts: no
quietvoid
There are currently no Linux ARM64 builds.afarvvik wrote: Thu Feb 29, 2024 10:15 am could you please provide a link, it is not on the github page & googling did not help. thanks.
Build it yourself.
cmv4.0 has better tone mapping than cmv2.9.frrilay wrote: Thu Feb 29, 2024 8:47 am Hi RESET, using cm_analyze to generate DV will result in a CMv4.0 file with latest algorythm; what exactly do you loose when converting this file down to CMv2.9? The goal being to make it compatible with ATV for example (and even when Infuse adds support for CMv4.0, I understood from your previous posts that ATV doesn't handle CMv4.0 perfectly).
Taking the occasion to say merci beaucoup for your hard work![]()
It never clips highlights(tunning 1), is much brighter, and doesn't crush black/shadow details.
old cmv2.9 vs old cmv4.0 vs new cmv4.0 vs hdr10plus vs madVR (metadata comparison)
https://drive.google.com/file/d/1PiiK4W ... sp=sharing
Cannikin
Hey everyone sorry to butt in on this thread but it seemed fairly related to what I'm trying to do:
Is there an easy ffmpeg command to convert an .mp4 with embedded DV (profile 5) to .mkv?
A google search for "mp4 with dolby vision to mkv" is all for doing the opposite—converting .mkv to .mp4. I've got plenty of DV MKVs that all play great (ripped with MakeMKV) but I recently got an .mp4 and can't figure out how to convert. When I try with a standard `ffmpeg -i movie.mp4 -map 0 -c copy movie.mkv` I get:
The stream identifier for the mp4 looks like:
Thanks for any help!
[matroska @ 0x11e028400] Tag dvh1 incompatible with output codec id '173' ([0][0][0][0])
Could not write header for output file #0 (incorrect codec parameters ?): Invalid data found when processing input
Error initializing output stream 0:2 --
Stream #0:0(und): Video: hevc (Main 10) (dvh1 / 0x31687664), yuv420p10le(pc), 1920x1080 [SAR 1:1 DAR 16:9], 6829 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 23.98 tbc (default)
Metadata:
creation_time : 2024-03-02T05:05:29.000000Z
handler_name : VideoHandler
vendor_id : [0][0][0][0]
encoder : DOVI Coding
Side data:
DOVI configuration record: version: 1.0, profile: 5, level: 3, rpu flag: 1, el flag: 0, bl flag: 1, compatibility id: 0
LV8HD
Hi everyone, since the topic of HDR metadata is well know in this forum I wanted to ask a question about it.
While I was browsing some trackers I've found one release group which seems to be really aware of what they are doing with video and audio related stuff. In particular, they managed to change MDL and MaxCLL/MaxFALL values within the hevc stream itself.
How is this even possible to do?
Here's the releaser's words:
"As usual we checked the static metadata and surprise-surprise, it was wrong again after doing a complete frame by frame analysis using industry standard methods. Dune has a supremely well done, highly dynamic 4000-nit mastered HDR grade, so having accurate grade specific static metadata for the base HDR presentation is very important. Not just to maximize the viewing experience, but also to correctly inform the display of the precise range of the content being played. The stock metadata had 1000-nit limited values despite the film and HDR grade on the disc being mastered at 4000-nit by the studio. We suspect the discrepancy came from values left over from the theatrical 1.90:1 IMAX, or far more likely: metadata for a 1000-nit tonemapped variation that somehow got in there. In either case, the actual measured uncapped values were applied. MaxCLL/MaxFALL coming from frames 4549 and 55532 respectively, properly ratio output blanked and at native UHD resolution of course."
This is a comparison of the video track before and after:
Stock video
Edited video
Stock video
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 2 h 35 min
Bit rate : 59.8 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.300
Stream size : 64.9 GiB (89%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 787 cd/m2
Maximum Frame-Average Light Level : 239 cd/m2Edited video
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.301
Stream size : 64.9 GiB (92%)
Language : English
Default : Yes
Forced : No
Maximum Content Light Level : 1804 cd/m2
Maximum Frame-Average Light Level : 501 cd/m2-
skull88
In my opinion, this group only "seems" or "acts" like they know it all, and they tend to just write very long and nerdy release notes and talk about using "industry" tools etc, but I've seen mistakes by them with audio and Dolby Vision metadata before (even plain converting HDR10plus to DV before, which is a no-no). Considering maxCLL and maxFALL metadata values for HDR BL (and L6 for DV too) are often inaccurate or even completely absent for many studio releases including UHD BDs, they clearly don't have the impact the group states during playback in all cases and MDL matters most (RESET_9999 confirmed they do matter in some cases in post below). I believe how all of these values impact PQ varies by playback device/TV and if in TV-LED or LLDV mode (for L6/DV), but statistically speaking, MDL is usually correct and matches the HDR grading monitor used, at least for retail UHD BD (don't forget that technically, a colourist can use a 4K mastering display but grade for peaks of 1K maxCLL still), and cannot be modified without re-encoding. More importantly, Dolby Vision metadata can have different internal MDL than the HDR BL metadata shows, and that is what counts for DV playback, which is quickly becoming the standard for majority of releases. As for your example, I don't see that they changed MDL, it's 4K in both before/after, they only modified the maxCLL and maxFALL values, which maybe is done using ffmpeg to do a "pass-through" re-encode and only modify those values? Maybe there's another way to do it though? Cheers!
On LG TVs, for HDR10 it uses maxcll if it's under MDL otherwise it uses MDL. But yeah that sounds like the crappy group WiLDCAT/EPS. I remember a while ago , they even tried to convince people that the HDRplus_tools was wrong which is totally false. I wouldn't believe a word they say. and once again they proved it...
As for Dune, I just measured it with madVR and I get a maxcll of 1127nits so the original static metadata is clearly a studio decision that makes sense, and using a maxcll of 1804nits is complete non-sense and will force the TV to use a more aggressive tone mapping curve when in fact 99% of the movie is under 1000nits.
