Taking the occasion to say merci beaucoup for your hard work
Hi RESET, using cm_analyze to generate DV will result in a CMv4.0 file with latest algorythm; what exactly do you loose when converting this file down to CMv2.9? The goal being to make it compatible with ATV for example (and even when Infuse adds support for CMv4.0, I understood from your previous posts that ATV doesn't handle CMv4.0 perfectly).
could you please provide a link, it is not on the github page & googling did not help. thanks.
cmv4.0 has better tone mapping than cmv2.9.frrilay wrote: ↑Thu Feb 29, 2024 8:47 amHi RESET, using cm_analyze to generate DV will result in a CMv4.0 file with latest algorythm; what exactly do you loose when converting this file down to CMv2.9? The goal being to make it compatible with ATV for example (and even when Infuse adds support for CMv4.0, I understood from your previous posts that ATV doesn't handle CMv4.0 perfectly).
Taking the occasion to say merci beaucoup for your hard work![]()
It never clips highlights(tunning 1), is much brighter, and doesn't crush black/shadow details.
old cmv2.9 vs old cmv4.0 vs new cmv4.0 vs hdr10plus vs madVR (metadata comparison)
https://drive.google.com/file/d/1PiiK4W ... sp=sharing
Hey everyone sorry to butt in on this thread but it seemed fairly related to what I'm trying to do:
Is there an easy ffmpeg command to convert an .mp4 with embedded DV (profile 5) to .mkv?
A google search for "mp4 with dolby vision to mkv" is all for doing the opposite—converting .mkv to .mp4. I've got plenty of DV MKVs that all play great (ripped with MakeMKV) but I recently got an .mp4 and can't figure out how to convert. When I try with a standard `ffmpeg -i movie.mp4 -map 0 -c copy movie.mkv` I get:
The stream identifier for the mp4 looks like:
Thanks for any help!
[matroska @ 0x11e028400] Tag dvh1 incompatible with output codec id '173' ([0][0][0][0])
Could not write header for output file #0 (incorrect codec parameters ?): Invalid data found when processing input
Error initializing output stream 0:2 --
Stream #0:0(und): Video: hevc (Main 10) (dvh1 / 0x31687664), yuv420p10le(pc), 1920x1080 [SAR 1:1 DAR 16:9], 6829 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 23.98 tbc (default)
Metadata:
creation_time : 2024-03-02T05:05:29.000000Z
handler_name : VideoHandler
vendor_id : [0][0][0][0]
encoder : DOVI Coding
Side data:
DOVI configuration record: version: 1.0, profile: 5, level: 3, rpu flag: 1, el flag: 0, bl flag: 1, compatibility id: 0
Hi everyone, since the topic of HDR metadata is well know in this forum I wanted to ask a question about it.
While I was browsing some trackers I've found one release group which seems to be really aware of what they are doing with video and audio related stuff. In particular, they managed to change MDL and MaxCLL/MaxFALL values within the hevc stream itself.
How is this even possible to do?
Here's the releaser's words:
"As usual we checked the static metadata and surprise-surprise, it was wrong again after doing a complete frame by frame analysis using industry standard methods. Dune has a supremely well done, highly dynamic 4000-nit mastered HDR grade, so having accurate grade specific static metadata for the base HDR presentation is very important. Not just to maximize the viewing experience, but also to correctly inform the display of the precise range of the content being played. The stock metadata had 1000-nit limited values despite the film and HDR grade on the disc being mastered at 4000-nit by the studio. We suspect the discrepancy came from values left over from the theatrical 1.90:1 IMAX, or far more likely: metadata for a 1000-nit tonemapped variation that somehow got in there. In either case, the actual measured uncapped values were applied. MaxCLL/MaxFALL coming from frames 4549 and 55532 respectively, properly ratio output blanked and at native UHD resolution of course."
This is a comparison of the video track before and after:
Stock video
Edited video
Stock video
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 2 h 35 min
Bit rate : 59.8 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.300
Stream size : 64.9 GiB (89%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 787 cd/m2
Maximum Frame-Average Light Level : 239 cd/m2Edited video
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.301
Stream size : 64.9 GiB (92%)
Language : English
Default : Yes
Forced : No
Maximum Content Light Level : 1804 cd/m2
Maximum Frame-Average Light Level : 501 cd/m2Re: Dolby Vision now possible through MP4 Mux.
In my opinion, this group only "seems" or "acts" like they know it all, and they tend to just write very long and nerdy release notes and talk about using "industry" tools etc, but I've seen mistakes by them with audio and Dolby Vision metadata before (even plain converting HDR10plus to DV before, which is a no-no). Considering maxCLL and maxFALL metadata values for HDR BL (and L6 for DV too) are often inaccurate or even completely absent for many studio releases including UHD BDs, they clearly don't have the impact the group states during playback in all cases and MDL matters most (RESET_9999 confirmed they do matter in some cases in post below). I believe how all of these values impact PQ varies by playback device/TV and if in TV-LED or LLDV mode (for L6/DV), but statistically speaking, MDL is usually correct and matches the HDR grading monitor used, at least for retail UHD BD (don't forget that technically, a colourist can use a 4K mastering display but grade for peaks of 1K maxCLL still), and cannot be modified without re-encoding. More importantly, Dolby Vision metadata can have different internal MDL than the HDR BL metadata shows, and that is what counts for DV playback, which is quickly becoming the standard for majority of releases. As for your example, I don't see that they changed MDL, it's 4K in both before/after, they only modified the maxCLL and maxFALL values, which maybe is done using ffmpeg to do a "pass-through" re-encode and only modify those values? Maybe there's another way to do it though? Cheers!
On LG TVs, for HDR10 it uses maxcll if it's under MDL otherwise it uses MDL. But yeah that sounds like the crappy group WiLDCAT/EPS. I remember a while ago , they even tried to convince people that the HDRplus_tools was wrong which is totally false. I wouldn't believe a word they say. and once again they proved it...
As for Dune, I just measured it with madVR and I get a maxcll of 1127nits so the original static metadata is clearly a studio decision that makes sense, and using a maxcll of 1804nits is complete non-sense and will force the TV to use a more aggressive tone mapping curve when in fact 99% of the movie is under 1000nits.
Thanks for clarifying and confirming for Dune, RESET. I should also add that in some cases, the highest peak brightness found is actually in the studio logos or some 1-2 second blinding shot, and that is probably why studios don't always set maxCLL to match the brightest single frame in the entire master encode, but rather use other judgement/decision process, as that would not be a good idea for tonemapping if majority of the film is WAY below those tiny outliers.
I see, thank you for the clarifications. Still, I don't understand how it is possible to change MDL or MaxCLL/FALL without re-encoding the video, but if it doesn't practically impact playback at all i think I'll get over this thought.
It's just SEI in the bitstream.
There's been some other people asking me for a tool to do it, and I had started working on one long time ago (October 2022 from my git logs)
I just don't really care enough since it doesn't matter that much and I had other priorities.
Makes sense, I don't blame you either for leaving it in the past. Not to mention, a tool like that may have an unintended consequence of more "experts" and groups around the interwebz to modify retail values and spread misinformation about what they should or should not be.
speeddemon
Is this still a thing?RESET_9999 wrote: ↑Tue Feb 13, 2024 1:43 pmplease ask any further questions related to the dovi_scripts here: https://forum.doom9.org/showthread.php? ... ost1997616
thanks.
Looks like ffmpeg doesn't support dvh1 codec in mkv.
Try something like:
ffmpeg -i dvh1.mp4 -c copy -vtag dvhe dvhe.mkv
