Pioneer BDR-UD03B
Bendstrup1996
Pioneer BDR-UD03B
#1 Post by Bendstrup1996 » Tue Mar 05, 2024 1:58 am
Hi.
I have a "Pioneer BDR-UD04" "Model 43888" with BDXL icon on it. I try to read a UHD disc and it doesn't work. Is it possible to make it recognize UHD discs and rip them?
Thanks! :D
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: C***********
Firmware date: 2020-06-15
Highest AACS version: 61
Drive platform: RS8A10
Firmware version: 1.14
Disc Information
Label: MAN_OF_STEEL
Timestamp: 2016-04-12 18:06:23
Protection: AACS2.0/C v61
Data capacity: 93.22 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Re: Pioneer BDR-UD03B
#2 Post by MartyMcNuts » Tue Mar 05, 2024 2:27 am
Bendstrup1996 wrote: Tue Mar 05, 2024 1:58 am Hi.
Thanks! :D
Revision: 1.14
Disc Information
Label: MAN_OF_STEEL
Number of layers: 3
That recognizes them just fine and is ready to rip. What do you mean it doesn't work? As you can see, the disc is recognized. Start decrypting it. If you get errors, tell us what errors you are getting.
skimige
#3 Post by skimige » Sat Mar 09, 2024 4:25 pm
Hi, why you copy the title and text from my post? This is confusing.
#4 Post by Woodstock » Sun Mar 10, 2024 12:28 am
He didn't. It is just VERY similar, except for the text from the drive. Dates are way different.
