libredrive bypass bus encryption?
thetoad
Post by thetoad »
Not that it matters in the context of MakeMKV, but for discs I have that are scratched and unable to be fully read easily, bypassing bus encryption would be useful for making ddrescue images of them especially if one tries to read different portions on different machines.
Re: libredrive bypass bus encryption?
Post by mike admin »
Yes. The moment you see "Using LibreDrive mode" message, bus encryption is disabled (for the current disc only!). You can even close MakeMKV and use dd or anything else to copy the files.
Note, that this has some drawbacks. Your drive would still report that drive supports bus encryption (as it is, LibreDrive code does not meddle with AACS) and some applications might think that sectors might need to be decrypted, while bus encryption was in fact not applied.
The disc would be in this state until you eject it.
thetoad
Post by thetoad »
this is very useful for trying to recover broken discs (where one might use multiple copies to fill in the blanks). Is it possible for you to add a command line option to makemkvcon to basically say ("insert libredrive, but don't do anything else) so I can then just use ddrescue.
i.e. today for DVDs my workflow is lsdvd /dev/dvd && ddrescue /dev/dvd NAME.ISO NAME.log this could be similar. (as you probably know, in the DVD case, lsdvd authenticates the disc for RPC2 drives enabling them to be fully read so the ISO can be then decrypted via CSS brute force decrypters (vlc will play it as is), though it doesn't quite help for small VOB files as dont have enough data to brute force the CSS, but in practice those don't matter so much)
thetoad wrote: Tue Mar 12, 2019 3:44 pmIs it possible for you to add a command line option to makemkvcon to basically say ("insert libredrive, but don't do anything else) so I can then just use ddrescue.
"makemkvcon info" will do just that.
xmh10000
Post by xmh10000 »
mike admin wrote: Fri Mar 15, 2019 1:54 pm
Hi, this command seems don't trigger LibreDrive mode in my Linux environment (I'm using Debian/testing), I'm using the latest MakeMKV version from this post (currently 1.17.6).
On Windows and macOS, the LibreDrive mode can be triggered on the same optical drive successfully ("Using LibreDrive mode" is shown in the console), so I am wondering if this is a problem on Linux or I've missed something?
Info from Linux MakeMKV GUI: (Without performing any further operation, just plug in the USB cable and insert a disk)
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.04
Serial number: XXXXXXXXXXX
Firmware date: 2120-05-06 11:42
Highest AACS version: 61
Firmware version: 1.04
Disc Information
Label: INCEPTION
Timestamp: 2017-11-13 16:59:12
Protection: AACS2.0/C v61
Data capacity: 92.55 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Errors from "makemkvcon info" command in Linux: (I didn't see "Using LibreDrive mode" in the console)
user@my-laptop:~$ sudo makemkvcon info dev:/dev/sr0
MakeMKV v1.17.6 linux(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:0'
Saved AACS dump file as file:///root/.MakeMKV/MKB20_v61_Inception_E1D5.tgz
Total 0 titles
There a few issues with some fw on Linux
Put your bu40n to 1.00 and that should fix it
xmh10000
Post by xmh10000 »
Billycar11 wrote: Sat Mar 02, 2024 5:30 pm There a few issues with some fw on Linux
It works without errors after downgrading to 1.00! Thanks for your advice!
