There Will Be Blood - Error from backup
kbutler84
#1 Post by kbutler84 » Sun Aug 07, 2011 8:53 pm
I created a full backup of There Will Be Blood. When I try to create an MKV from the backup, I get the following error:
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 24948633600, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 24948639744, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 24948645888, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 24948652032, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 24948658176, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 24948664320, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 24948670464, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 24948676608, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 24948682752, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 24948688896, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 24948695040, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 24948701184, attempting to work around
Failed to save title 0 to file /Volumes/2TB External HDD/MKV Files/title00.mkv
0 titles saved, 1 failed
setarip_old
Re: There Will Be Blood - Error from backup
#2 Post by setarip_old » Sun Aug 07, 2011 10:42 pm
Hi!
Have you played your full disc backup copy to determine whether IT may be corrupt?
kbutler84
#3 Post by kbutler84 » Mon Aug 08, 2011 11:59 am
Since posting the OP, I did try that. And that does seem to be the problem. Guess I'll try again.
setarip_old
#4 Post by setarip_old » Mon Aug 08, 2011 6:01 pm
Glad to hear my suggestion has helped you identify the starting point of your problem ;>}
Try cleaning the disc...
