Weird errors trying to rip custom UHD
SelenitaDelSur
#1 Post by SelenitaDelSur » Sun Mar 03, 2024 8:04 pm
Hi, I have two customs UHD with customized, enhanced edited audio. I would like to save the main movie and extras as mkvs and not the full UHD since I don't care for the menus and mkvs are easier to play for me.
But no matter which or the two movies I try to rip, or which extra, I always get these errors:
Saving 1 titles into directory S:/
AV synchronization issues were found in file XXX.mkv' (title #1)
AV sync issue in stream 1 at 0:00:00 with duration of 1344ms : 126 frame(s) dropped to reduce audio skew to +6ms
AV sync issue in stream 2 at 0:00:00 with duration of 1344ms : 126 frame(s) dropped to reduce audio skew to +6ms
AV sync issue in stream 3 at 0:00:00 with duration of 1344ms : 126 frame(s) dropped to reduce audio skew to +6ms
AV sync issue in stream 4 at 0:00:00 with duration of 1344ms : 42 frame(s) dropped to reduce audio skew to +6ms
AV sync issue in stream 5 at 0:00:00 with duration of 1344ms : 126 frame(s) dropped to reduce audio skew to +6ms
AV sync issue in stream 6 at 0:00:00 with duration of 1344ms : 126 frame(s) dropped to reduce audio skew to +6ms
AV sync issue in stream 7 at 0:00:00 with duration of 1344ms : 126 frame(s) dropped to reduce audio skew to +6ms
AV sync issue in stream 8 at 0:00:00 with duration of 1344ms : 42 frame(s) dropped to reduce audio skew to +6ms
AV sync issue in stream 9 at 0:00:00 with duration of 1344ms : 126 frame(s) dropped to reduce audio skew to +6ms
AV sync issue in stream 10 at 0:00:00 with duration of 1344ms : 126 frame(s) dropped to reduce audio skew to +6ms
AV sync issue in stream 11 at 0:00:00 with duration of 1344ms : 42 frame(s) dropped to reduce audio skew to +6ms
AV sync issue in stream 12 at 0:00:00 with duration of 1344ms : 126 frame(s) dropped to reduce audio skew to +6ms
AV sync issue in stream 13 at 0:00:00 with duration of 1344ms : 42 frame(s) dropped to reduce audio skew to +6ms
AV sync issue in stream 14 at 0:00:00 with duration of 1344ms : 42 frame(s) dropped to reduce audio skew to +6ms
AV sync issue in stream 15 at 0:00:00 with duration of 1344ms : 42 frame(s) dropped to reduce audio skew to +6ms
AV sync issue in stream 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15 at 0:00:00 with duration of 1350ms : encountered overlapping frame, audio skew is +6ms
DEBUG: Code 179 at ^,i~BX3is!O#bBE`7h\+r:213134055
The source file '/BDMV/STREAM/00241.m2ts' is corrupt or invalid at offset 89819172864, attempting to work around
DEBUG: Code 184 at ^,i~BX3is!O#bBE`7h\+r:213134055
DEBUG: Code 53 at ^,i~BX3is!O#bBE`7h\+r:213134055
AV sync issue in stream 17 at 0:00:00 : Forced subtitles track #17 turned out to be empty and was removed from output file
AV sync issue in stream 23 at 0:00:00 : Forced subtitles track #23 turned out to be empty and was removed from output file
AV sync issue in stream 25 at 0:00:00 : Forced subtitles track #25 turned out to be empty and was removed from output file
AV sync issue in stream 31 at 0:00:00 : Forced subtitles track #31 turned out to be empty and was removed from output file
AV sync issue in stream 35 at 0:00:00 : Forced subtitles track #35 turned out to be empty and was removed from output file
AV sync issue in stream 37 at 0:00:00 : Forced subtitles track #37 turned out to be empty and was removed from output file
AV sync issue in stream 43 at 0:00:00 : Forced subtitles track #43 turned out to be empty and was removed from output file
AV sync issue in stream 45 at 0:00:00 : Forced subtitles track #45 turned out to be empty and was removed from output file
AV sync issue in stream 47 at 0:00:00 : Forced subtitles track #47 turned out to be empty and was removed from output file
AV sync issue in stream 49 at 0:00:00 : Forced subtitles track #49 turned out to be empty and was removed from output file
AV sync issue in stream 53 at 0:00:00 : Forced subtitles track #53 turned out to be empty and was removed from output file
AV sync issue in stream 57 at 0:00:00 : Forced subtitles track #57 turned out to be empty and was removed from output file
AV sync issue in stream 61 at 0:00:00 : Forced subtitles track #61 turned out to be empty and was removed from output file
AV sync issue in stream 63 at 0:00:00 : Forced subtitles track #63 turned out to be empty and was removed from output file
AV sync issue in stream 65 at 0:00:00 : Forced subtitles track #65 turned out to be empty and was removed from output file
AV sync issue in stream 67 at 0:00:00 : Forced subtitles track #67 turned out to be empty and was removed from output file
AV sync issue in stream 73 at 0:00:00 : Forced subtitles track #73 turned out to be empty and was removed from output file
1 titles saved
I get that "sync issue" messages are not important, but I would like to know why they appear. But what about the "corrupt or invalid" ones?
The process ends fine, but now I wonder if it's something wrong. The isos plays fine and I don't think the isos are badly dumped.
Thanks in advance.
Re: Weird errors trying to rip custom UHD
#2 Post by Woodstock » Sun Mar 03, 2024 9:16 pm
1 titles saved
The title is saved, so the errors were worked around.
The "forced subtitle" tracks are always created for each track (one containing "all subtitles", one containing "forced only" subtitles), but are deleted if empty. Sure are a lot of tracks in that disk...
SelenitaDelSur
#3 Post by SelenitaDelSur » Sun Mar 03, 2024 9:58 pm
Woodstock wrote: Sun Mar 03, 2024 9:16 pm
1 titles saved
Hi, thanks for the answer!
What about "frames dropped", "overlapping frame" and "corrupt or invalid" messages? What do they mean? Why would show up if the disk is fine? I'm just trying to make sense out of it.
#4 Post by Woodstock » Sun Mar 03, 2024 11:17 pm
The "AV Sync" messages are adjustments to various tracks to coordinate the video and audio together. These can be common, and there are quite a number of audio tracks on this disk.
"Corrupt or invalid" messages are for a single area of the disk, which had to be retried multiple times to get a good read. It could have become an issue if it had continued to be unreadable, but MakeMKV can be rather persistent at times. The disk may need cleaning to make it read better.
SelenitaDelSur
#5 Post by SelenitaDelSur » Mon Mar 04, 2024 8:50 am
Woodstock wrote: Sun Mar 03, 2024 11:17 pm The "AV Sync" messages are adjustments to various tracks to coordinate the video and audio together. These can be common, and there are quite a number of audio tracks on this disk.
But it is not a disk, but an authored ISO (modified from the original to include customized audio track). So how can it give these kinds of error reading from a file??
#6 Post by Woodstock » Mon Mar 04, 2024 1:57 pm
Authored ISO is same as a disk, if it's constructed "just like a disk". The video and audio still have sync requirements.
SelenitaDelSur
#7 Post by SelenitaDelSur » Mon Mar 04, 2024 6:50 pm
Woodstock wrote: Mon Mar 04, 2024 1:57 pm Authored ISO is same as a disk, if it's constructed "just like a disk". The video and audio still have sync requirements.
But "corrupt or invalid" messages are not from sync requirements. What else could it be? Surely NOT read errors from the optical drive.
#8 Post by Billycar11 » Mon Mar 04, 2024 7:17 pm
SelenitaDelSur wrote: Mon Mar 04, 2024 6:50 pm
It is very common on LG and Asus drives to produce corrupt results
SelenitaDelSur
#9 Post by SelenitaDelSur » Mon Mar 04, 2024 10:41 pm
Billycar11 wrote: Mon Mar 04, 2024 7:17 pm
Sorry but have you read the post? I'm dealing with a file, an iso, not any optical drive. That's why I'm so annoyed with those error messages.
#10 Post by Billycar11 » Tue Mar 05, 2024 12:03 am
SelenitaDelSur wrote: Mon Mar 04, 2024 10:41 pm
well at some point was it ripped from a disc? with an lg/asus drive
you say its a custom iso how so was it modified to change something in it if so it will always show as corrupt if the hash tables were not updated after the modification
#11 Post by MartyMcNuts » Tue Mar 05, 2024 2:29 am
You'd be better off creating your mkv movie from the original disc in MakeMKV then adding your custom audio to the mkv file using mkvtoolnix.
SelenitaDelSur
#12 Post by SelenitaDelSur » Tue Mar 05, 2024 9:50 am
Billycar11 wrote: Tue Mar 05, 2024 12:03 am you say its a custom iso how so was it modified to change something in it if so it will always show as corrupt if the hash tables were not updated after the modification
Hash tables not updated, now that makes sense...
MartyMcNuts wrote: Tue Mar 05, 2024 2:29 am You'd be better off creating your mkv movie from the original disc in MakeMKV then adding your custom audio to the mkv file using mkvtoolnix.
I can't do that for now, but as long as you guys assure me that, as long as the process finish there is absolutely zero video/audio/subs corruption or sync issues, then I'm OK with that. Is that the case?
Thanks in advance!
#13 Post by MartyMcNuts » Wed Mar 06, 2024 12:43 am
SelenitaDelSur wrote: Tue Mar 05, 2024 9:50 am
Thanks in advance!
We can't assure you that. You would have to watch the movie and make sure yourself.
SelenitaDelSur
#14 Post by SelenitaDelSur » Fri Mar 08, 2024 11:00 pm
Thanks, you guys have been helpful :)
