Beta Key 🔑 Doesn’t Work forced to buy
blue-raven
Post by blue-raven »
Hello 👋,
Was curious why the beta key stopped working and now I’m forced to purchase a key. I keep trying the key that is supposedly not expired according to the post yet, for just me, doesn’t work. Kind of creepy.
Re: Beta Key 🔑 Doesn’t Work forced to buy
nah it will be for everyone im guessing it goes by the devs time zone its march there and it says it good till end of feb so should be expired.
a new key will be posted in the future
briansemerick
Post by briansemerick »
I wonder if Leap Day screwed up the release schedule. Either way I'm just twiddling my thumbs until the new key comes out. :mrgreen:
It was never seamless. Just wait a couple of days.
blue-raven
Billycar11 wrote:
Fri Mar 01, 2024 4:37 am
Thanks I’ll hang in there
Ezatoka
Post by Ezatoka »
blue-raven wrote:
Fri Mar 01, 2024 4:33 am
Someone is standing with a gun behind you and forces you to buy? Might need better locks on your home.
Otherwise, buying is an appreciation towards mike for his work.
Dogboy7
Post by Dogboy7 »
Just as a test I changed the date on my computer from March to February. Boom, MKV working again. Changed it back to March when I was done.
blue-raven
Dogboy7 wrote:
Sat Mar 02, 2024 3:54 pm
You are correct 👍! Fancy thinking 🧐
briansemerick
I tried this earlier and it did not work for me.
WilliWieberg
Post by WilliWieberg »
The key expired on 24 03 01. Still works for me if i manually switch back the date, but than every other software complains for security risk of not having set the correct date.
The date is only checked when MakeMKV starts. It can be turned back right after that. If you leave MakeMKV running while idle (depends on how paranoid we are), it doesn't check the date again.
momolabs
Post by momolabs »
Ok so usually this works when I set my system date back. The other day it didn't. Today I got it to work with these steps:
1. Set system date back.
2. Start MakeMKV. If it says evaluation expired, Do a Register and put in the expired key.
3. Restart MakeMKV and open media, this time it works.
4. Set system date/time back to automatic.
5. Keep Calm and Carry On
briansemerick
momolabs wrote:
Mon Mar 04, 2024 10:58 pm
thank you. this worked.
briansemerick
well I thought it worked. Now all my discs are having strings of errors immediately after putting them in, and they crash the system. Wish a new key would just come out. It's 3/5....
Daveo
Post by Daveo »
This is the new key. it didnt work immediately but i had to restart it, now all fine.
viewtopic.php?f=5&t=1053
