snap and saving to another folder
dennis__
Post by dennis__ »
I installed Makemkv 1.17.6 onto ubuntu 20.04.6 via snap. My OS and ~ are on a tiny drive. I changed my "Defalut destination" to "SemiAuto" and then entered a different disk as the path.
When I rip a blue ray I get this error
Directory /media/dennis/2_TB_DISK/Movies/The Hunger Games- The Ballad Of Songbirds And Snakes is invalid
Is this because I am using snaps? If so, is there a work around?
Re: snap and saving to another folder
Sometimes, names that contain spaces don't QUITE work out. One test is to copy the whole file name, and try creating it manually. Can it be "opened"?
Spaces are a big "gotcha". Also, file names that don't match up with what is actually there can be a problem.
dennis__
Post by dennis__ »
For me, this was an issue with snap. I have avoided them in the past and so ran into this beginners problem.
sudo snap connect makemkv:removable-media
sudo snap disconnect makemkv:removable-media
I plan on using automatic ripping machine or something like it eventually but these work for now.
dennis__
Post by dennis__ »
Thanks for your response. I should have been more clear. The error prevented Makemkv from even creating a folder let alone starting the ripping process. It just bombed immediately.
That's possibly because of the snap; I cannot say, but I have heard that they limit abilities to protect users from malicious files. It MAY be that "create a directory on a remote drive" is one of those protections.
If you've created the directory, does it allow you to write to it?
flojo
Post by flojo »
That's a bad error message! Post the whole log, maybe it can be demystified. This could be a permission issue, a whitespace issue or a Makemkv issue (the error message certainly is).
Why do you have this stuff in "/media/dennis" and not "/home/dennis"? What is $HOME set to?
flojo wrote:
Sun Mar 03, 2024 6:12 pm
I'd guess /media is where external drives are mounted.
flojo
Post by flojo »
dcoke22 wrote:
Sun Mar 03, 2024 7:09 pm
You are correct, sorry, I forgot that's a default for auto mounting (I put them in home).
