Ok, so i ripped my first UHD today, The Professional. I selected the TrueHD 7.1 in the rip. When i go to play the rip back on my Oppo 203, the best i can get is multi-channel 7.1, no atmos. When I hit "audio" on the Oppo remote i get "MLP English" as the only option. When i play the actual UHD disc in the Oppo 203, I get Atmos no problem.
Also, when i am trying to get the rip to play i try top select Bitstream on the HDMI out, but i get no sound.
What have i done wrong?
first UHD rip and i can not get atmos
Re: first UHD rip and i can not get atmos
Are you sure that movie actually contains ATMOS? It may only be THD 7.1.sotwell wrote: Fri Mar 01, 2024 2:17 am Ok, so i ripped my first UHD today, The Professional. I selected the TrueHD 7.1 in the rip. When i go to play the rip back on my Oppo 203, the best i can get is multi-channel 7.1, no atmos. When I hit "audio" on the Oppo remote i get "MLP English" as the only option. When i play the actual UHD disc in the Oppo 203, I get Atmos no problem.
Blu-ray.com thinks there's Dolby Atmos on the disc, for English anyway. https://www.blu-ray.com/movies/Leon-The-Professional-4K-Blu-ray/179592/
There's a utility called MediaInfo that can show you a lot of details about your media files, including if there's Dolby Atmos.
Here's an example of an audio track with Atmos:
You can verify that your .mkv rip has Dolby Atmos as you expect.
Audio #1
ID in the original source medium : 4352 (0x1100)
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Duration : 2 h 7 min
Bit rate mode : Variable
Bit rate : 3 048 kb/s
Maximum bit rate : 4 752 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 2.71 GiB (4%)
Title : Surround 7.1
Language : English
Default : Yes
Forced : No
Original source medium : Blu-ray
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
