first UHD rip and i can not get atmos
sotwell
Post by sotwell »
Ok, so i ripped my first UHD today, The Professional. I selected the TrueHD 7.1 in the rip. When i go to play the rip back on my Oppo 203, the best i can get is multi-channel 7.1, no atmos. When I hit "audio" on the Oppo remote i get "MLP English" as the only option. When i play the actual UHD disc in the Oppo 203, I get Atmos no problem.
Also, when i am trying to get the rip to play i try top select Bitstream on the HDMI out, but i get no sound.
What have i done wrong?
Re: first UHD rip and i can not get atmos
sotwell wrote:
Fri Mar 01, 2024 2:17 am
Are you sure that movie actually contains ATMOS? It may only be THD 7.1.
Blu-ray.com thinks there's Dolby Atmos on the disc, for English anyway. https://www.blu-ray.com/movies/Leon-The-Professional-4K-Blu-ray/179592/
There's a utility called MediaInfo that can show you a lot of details about your media files, including if there's Dolby Atmos.
Here's an example of an audio track with Atmos:
Audio #1
Duration                                 : 2 h 7 min
Bit rate                                 : 3 048 kb/s
Maximum bit rate                         : 4 752 kb/s
Stream size                              : 2.71 GiB (4%)
You can verify that your .mkv rip has Dolby Atmos as you expect.
