Hi there,
This is my 2nd UHD disk that I've ripped, first had no problems. Will this effect the video or audio in anyway? Thanks.
Saving 2 titles into directory C:/Video/The Super Mario Bros. Movie (2023)
AV synchronization issues were found in file 'C:/Video/The Super Mario Bros. Movie (2023)/The Super Mario Bros. Movie (2023)_t00.mkv' (title #1)
AV sync issue in stream 4 at 0:00:00 : Forced subtitles track #4 turned out to be empty and was removed from output file
AV synchronization issues were found in file 'C:/Video/The Super Mario Bros. Movie (2023)/The Super Mario Bros. Movie (2023)_t42.mkv' (title #43)
AV sync issue in stream 3 at 0:00:00 : Forced subtitles track #3 turned out to be empty and was removed from output file
2 titles saved
AV sync issue in stream Forced subtitles track turned out to be empty and was removed from output file
hunteredh
hunteredh
Re: AV sync issue in stream Forced subtitles track turned out to be empty and was removed from output file
Full log:
MakeMKV v1.17.6 win(x64-release) started
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Evaluation version, 29 day(s) out of 30 remaining
This disc requires Java runtime (JRE), but none was found. Certain functions will fail, please install Java. See http://www.makemkv.com/bdjava/ for details.
File 00801.mpls was added as title #0
File 00149.mpls was added as title #1
Title #01041.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01042.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01048.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00040.mpls is equal to title 00801.mpls and was skipped
Title #01064.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01065.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01066.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01067.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01258.mpls was added as title #2
File 01259.mpls was added as title #3
File 01260.mpls was added as title #4
File 01261.mpls was added as title #5
File 01262.mpls was added as title #6
File 01263.mpls was added as title #7
File 01264.mpls was added as title #8
File 01265.mpls was added as title #9
Title #01266.mpls has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01267.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01268.mpls was added as title #10
File 01269.mpls was added as title #11
File 01270.mpls was added as title #12
File 01271.mpls was added as title #13
File 01272.mpls was added as title #14
File 01273.mpls was added as title #15
Title #01274.mpls has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01275.mpls has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01288.mpls was added as title #16
File 01289.mpls was added as title #17
File 01290.mpls was added as title #18
File 01291.mpls was added as title #19
File 01292.mpls was added as title #20
File 01293.mpls was added as title #21
File 01294.mpls was added as title #22
File 01295.mpls was added as title #23
File 01296.mpls was added as title #24
File 01297.mpls was added as title #25
File 01298.mpls was added as title #26
File 01299.mpls was added as title #27
Title #00174.m2ts has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00175.m2ts has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00165.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00293.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00214.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00240.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00241.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00215.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00242.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00216.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00243.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00217.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00218.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00219.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00099.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00231.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00039.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00098.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00107.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00130.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00093.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00097.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00227.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00228.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00132.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00088.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00096.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00229.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00125.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00137.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00108.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00129.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00133.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00230.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00112.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00089.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00118.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00139.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00233.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00338.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00339.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00254.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00255.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00256.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00257.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00258.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00259.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00260.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00261.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00262.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00263.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00264.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00265.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00266.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00267.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00268.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00269.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00270.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00271.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00272.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00273.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00274.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00275.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00276.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00277.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00278.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00279.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00280.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00281.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00282.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00283.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00284.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00285.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00286.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00287.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00288.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00289.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00290.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00291.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00292.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00294.m2ts was added as title #28
Title #00340.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00330.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00296.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00365.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00366.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00367.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00435.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00436.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00437.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00438.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00439.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00440.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00441.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00442.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00443.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00444.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00445.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00446.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00447.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00448.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00449.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00450.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00451.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00452.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00453.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00454.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00455.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00456.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00457.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00458.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00459.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00460.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00461.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00462.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00463.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00464.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00465.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00466.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00467.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00468.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00469.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00470.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00471.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00472.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00473.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00474.m2ts was added as title #29
File 00475.m2ts was added as title #30
File 00476.m2ts was added as title #31
File 00477.m2ts was added as title #32
File 00478.m2ts was added as title #33
File 00479.m2ts was added as title #34
Title #00480.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00481.m2ts has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00482.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00483.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00484.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00485.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00486.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00487.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00488.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00489.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00490.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00491.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00492.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00493.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00494.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00495.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00496.m2ts was added as title #35
File 00497.m2ts was added as title #36
File 00498.m2ts was added as title #37
File 00499.m2ts was added as title #38
File 00500.m2ts was added as title #39
File 00501.m2ts was added as title #40
File 00502.m2ts was added as title #41
File 00503.m2ts was added as title #42
File 00504.m2ts was added as title #43
Title #00505.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00506.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
2 titles saved-
For every subtitle track on a BD, MakeMKV will try to make two of them - "everything", and "just those subtitles marked as forced".
Usually, disks do not have mixed subtitle types; they have tracks with "everything", and separate tracks of "just the signs and printed text". So, the constructed subtitle track ("marked as forced") gets nothing put in it. It's empty, so it gets deleted.
Some (small number!) of disks have mixed. Avatar is one. Those are what this was intended to "fix", because not every player can deal with it. You'll see the deleted message a lot, though.
hunteredh
Thank you, I'm sure it's been asked a million times!
