Trouble ripping Leon The Professional
maddog510
Post by maddog510 »
I don't know if I have a bad disc or not but about 25 minutes into ripping The Professional, a messege comes up saying "mts338 is invalid or corrupt; looking for a work around." This continued for about 6 minutes before it continued the rip but came up again with mts339 then I got the fatal error popup & the rip stopped. Anyone have issues with this title?
cherishjoo
Re: Trouble ripping Leon The Professional
Post by cherishjoo »
Do you get the right playlist to rip?
Best Bluray DVD Ripping Solution
maddog510
Post by maddog510 »
cherishjoo wrote:Do you get the right playlist to rip?
I tried it in DVDFAB & I got an error messege before it opened up this disc saying there was a read error.
Read errors point to a problem on the disk... Probably smudges that a simple cleaning with a damp, soft cloth will take care of.
caycep
Post by caycep »
I do have a question about this disk - there's the theatrical release, but then there's 2 separate "director's cut" long versions - one is about 0.1 gb larger than the other but seem to have the same running times. Which is the "real" track for the director's cut?
Post by d00zah »
caycep wrote: Thu Feb 29, 2024 9:10 pm I do have a question about this disk - there's the theatrical release, but then there's 2 separate "director's cut" long versions - one is about 0.1 gb larger than the other but seem to have the same running times. Which is the "real" track for the director's cut?
It MIGHT be these?
1h 50m (110 min)
2h 16m (136 min) (uncut) (France)
2h 13m (133 min) (International)
