Pioneer BDR-UD03 UHD possibility
skimige
Post by skimige » Thu Feb 29, 2024 10:59 am
Hi all, I have a "Pioneer BDR-UD03B" with BDXL icon on it. I try to read a UHD disc and it doesn't work. Is it possible to make it recognize UHD discs and rip them?
Thanks in advance! :wink:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.05
Serial number: ************
Firmware date: 2015-11-24
Highest AACS version: 58
Drive platform: RS8510
Firmware version: 1.05
Re: Pioneer BDR-UD03 UHD possibility
Post by Coopervid » Thu Feb 29, 2024 4:49 pm
PM sent.
kill3r
Post by kill3r » Tue Apr 23, 2024 1:39 pm
Hi Coopervid,
I have the same problem with the same drive:
Laufwerksinformation
OS-Gerätename: J:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.05
Serienummer: QBDL090378WL
Firmware-Datum: 2015-11-24
Highest AACS version: 12
Can you please help me also? :-)
Many thanks in advance!
Post by Coopervid » Wed Apr 24, 2024 9:07 am
Hi Coopervid,
OS-Gerätename: J:
Produzent: PIONEER
Revision: 1.05
Read your PM.
kill3r
Post by kill3r » Wed Apr 24, 2024 1:51 pm
Thank you very much :-)
fs9178
Post by fs9178 » Wed Apr 24, 2024 3:09 pm
PM sent.
Hi Coopervid,
I also have the same problem with the same drive.
Thank you too !
jobj42
Post by jobj42 » Wed Apr 24, 2024 6:53 pm
Hey,
Jumping on the bandwagon
BDR-UD03 Rev 1.14 here
PIONEER&Prod_BD-RW___BDR-UD03&Rev_1.14
Someting possible here, most posts I find for this model are rev 1.05
Post by Coopervid » Thu Apr 25, 2024 9:46 am
Check your PMs.
infectedrain
Post by infectedrain » Mon Apr 29, 2024 10:04 pm
PM sent.
Hi Coopervid,
I have the same problem with the drive wthen name differs by one letter BDR-UD03D.
Can I also unlock UHD? Does the letter D change much :(
Device: \\.\E:
Drive Information:
Model Name : PIONEER BD-RW BDR-UD03D
Firmware Rev : 1.00
Extra Info : 14/05/14 PIONEER
Serial Number : OGDL091378WL
Buffer Size : 4000 kiB
Additional Drive Information:
Label Code : ----
Hardware Rev : SAT 8510
Kernel Type : ID84
Firmware Type : ID84
Kernel Version : 0000
Drive is in normal mode.
Firmware flashing support : NO
Firmware dumping support : NO
Drive Capabilities:
CD-ROM : R BD-ROM : R
CD-R : R/W BD-R : R/W
CD-RW : R/W BD-R XL : R/W
DVD-ROM : R BD-RE : R/W
DVD-R : R/W BD-RE XL : R/W
DVD-R DL : R/W HD DVD-ROM : -
DVD-RW : R/W HD DVD-R : -
DVD+R : R/W HD DVD-R DL : -
DVD+R DL : R/W HD DVD-RW : -
DVD+RW : R/W LabelFlash : NO
DVD-RAM : R/W LightScribe : NO
Drive Region Settings:
RPC Scheme : RPC-2
Current Region : 2
Changes Left : 4 (available to user)
Resets Left : 4 (available only to vendor)
Region State : Region is set
Thank you for your help ;)
johnnyflashy
Post by johnnyflashy » Tue Apr 30, 2024 4:28 am
I have this drive as well. Can it be updated? Thanks in advance guys
Post by Coopervid » Tue Apr 30, 2024 7:49 am
PM sent.
Hi Coopervid,
Device: \\.\E:
Drive Information:
Firmware Rev : 1.00
Label Code : ----
Kernel Type : ID84
Drive Capabilities:
RPC Scheme : RPC-2
Current Region : 2
Check your PM.
SneakyGit
Post by SneakyGit » Wed May 01, 2024 2:18 pm
Hey,
Something possible here, most posts I find for this model are rev 1.05
I have one of these as well ...
Firmware 2020-06-15
Post by Coopervid » Thu May 02, 2024 10:45 am
Hey,
Firmware 2020-06-15
PM sent.
jeepsey
Post by jeepsey » Fri May 03, 2024 8:40 am
PM sent.
Hi I have the same drive and hope you could pm me with any information you are able to offer.
Post by Coopervid » Fri May 03, 2024 1:42 pm
PM sent.
Check your PM.
