Wonka 4k Dump Submitted
crosis
Re: Wonka 4k Dump Submitted
Post by crosis »
Coopervid wrote: Thu Feb 29, 2024 12:09 am Read this:
viewtopic.php?f=12&t=32784
Thank you for that info. I tried that and it worked. I have created a symlink in the .MakeMKV folder pointing to the keydb file it creates and set the synchronize batch file to run daily. I appreciate the assist on this.
jt5298
Post by jt5298 »
It worked! Thanks again. :D
kwinders2
Post by kwinders2 »
This worked perfect for me, thank you
Ballesteros
Post by Ballesteros »
MKB20_v77_Wonka_16A0.tgz dump submitted from today's UK UHD release.
theandrewgilbert
Post by theandrewgilbert »
Is there a fix that I'm missing? i have a problem still
Arndrell
Post by Arndrell »
MKB20_v77_Wonka_16A0 - Dump file sent today
Obsessive compulsive ripper and collector since finding Make MKV!
Converting nearly 1,200 Blu Rays and UHD in 1:1 format to a Plex library serviced by Infuse.
Ballesteros
Heads up for UK users - the 16A0 UHD disc is now decrypting for me - it wasn't yet when I had last tried on Wednesday.
ElvenKind
Post by ElvenKind »
MKB20_v77_Wonka_8E40.tgz submitted
The keydb-trick does not work for me.
2024-03-18
Now works.
Macguy
Post by Macguy »
Just bought the combo 4KUHD/Blu-ray of "Willy Wonka & The Chocolate Factory" (version with Gene Wilder)
No problem with the Blu-ray
However MakeMKV rejects the 4K version "unknown key"
Of course, the keydb.cfg file has been downloaded and stored in the MakeMKV folder
Any help would be appreciated :wink:
Macguy wrote: Thu Aug 29, 2024 5:57 pm Hi,
Did you email your dump file to svq@makemkv.com? Post the name of the dump file on the forum.
UHD FAQ
Macguy
Post by Macguy »
Thanks for the tip.
Dump file has just been emailed
MKB20_v76_Willy_Wonka_and_the_Chocolate_Factory_5D29.tgz
