Ultimate UHD Drives Flashing Guide Updated 2023
Manciple
#2191 Post by Manciple » Wed Feb 21, 2024 3:38 pm
@Coopervid. PM received. I'm still unable to send PM's as I'm a new user, hence my reply here. I've canceled the LG order and substituted in the Pioneer. I'll be back in touch once I get it, if I can't get the flash tools available here to work on it.
#2192 Post by Coopervid » Wed Feb 21, 2024 4:59 pm
OK. Just post here when you have it.
#2193 Post by Coopervid » Wed Feb 21, 2024 7:12 pm
You have another PM.
Shuffle2694
#2194 Post by Shuffle2694 » Sun Feb 25, 2024 5:56 pm
I was lucky enough to find a BDR-2213 on the older firmware. It shows up in MakeMKV as
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-213M
Revision: 1.02
Serial number:
Firmware date: 2022-04-06
Drive platform: Pioneer RS9200
Firmware version: ID56
Am I correct that there is a UHD flasher available for this device from at least some of the sellers?
newmkv
#2195 Post by newmkv » Mon Feb 26, 2024 11:53 pm
Need some help experts.
Received LG option 3 from Bluntsman today & tried ripping my 4k disc (The Thing).
1)Used makemkv and confirmed that audio track has 7.1 (DTS:X) and enabled everything as they are by default.
It completed sucessfully.
2)Coped the mkv file to my Zidoo player & played the file.
Issues:
1)When I clicked Play, as you see in pic, its menu says DTS:x but while playing, I checked its Audio/menu where it says only 5.2 and my yamaha receiver displays as 'DTS and then Neural:X'
I also checked its output where it says '4K 60 Hz'
2)Whereas, if I play my disc directly in my panasonic 4K player, I see 'DTS:X' in my yamaha receiver info and also video output says '4K 24 Hz'.
3)I also tried playing the mkv directly in my VLC in my laptop where it says in Audio menu 'Surround 7.1'
Pls let me know what am I missing here.
I do not think that output mkv from ripping is actually DTS:X and video '4K 24 Hz' as in the original disc. Right?
#2196 Post by Billycar11 » Tue Feb 27, 2024 12:13 am
Issues:
the drive and makemkv do not change the audio or video.
you need to configure your setup to correctly pass through the audio often called bit stream vlc cant match frame rate automatically like jriver or madvr can.
so you would need to manually match the fps it actually usually the 23hz option thats correct for movies
mecking
#2197 Post by mecking » Tue Feb 27, 2024 12:44 pm
I am a newbie and have bought an LG drive: BH 16 SN40, Rev. 1.03 with the MT1939 drive platform. Firmware (v. 1.03) is displayed as original (unpatched). Can I flash this drive and with which firmware? I would like to flash an MK-firmware. Is that possible?
Thanks in advance to the team.
kiranmehta
#2198 Post by kiranmehta » Tue Feb 27, 2024 2:35 pm
Hi I am from India, I have been reading a lot of this forum and gotten very interested in ripping blurays but there are not a lot of options available here in India and those which are available are almost double the price if not more.
Initially I was interested in the latest pioneer drives (BDR xd08-umb-s) but due to firmware support for makemkv unavailable stopped pursuing it. I currently have shortlisted following options for me here in India -
lg wh14ns40 (rupees 11492 i.e USD - )
lg wh16ns40 (rupees 11492 i.e USD - )
ASUS BW-16D1HT (rupees 11492 i.e USD - )
I am leaning towards Asus as i have heard that it handles large disks well without read errors. Also Lg drive i am not sure of the svc version as the seller on amazon is not able to provide this info.
Any recommendations apart from the above are welcome
#2199 Post by Billycar11 » Tue Feb 27, 2024 7:50 pm
No that will kill it do not flash that drive
#2200 Post by Billycar11 » Tue Feb 27, 2024 7:51 pm
They are all the same junky drive get the cheapest
It's just the illusion of choice
kiranmehta
#2201 Post by kiranmehta » Tue Feb 27, 2024 8:24 pm
Thanks for replying, will buy one soon!
ShevyMate
#2202 Post by ShevyMate » Thu Feb 29, 2024 1:51 am
G'day, Ive recently started getting into the idea of backing up my physical media collection and struggling to figure out if this LG BH16NS40 manufactured in 2014 is capable of ripping. This is my first time doing this so im a bit confused on how to find the information I need. Twould greatly appreciate it if someone could let me know if my drive is compatible, Cheers!
#2203 Post by Woodstock » Thu Feb 29, 2024 2:13 am
2014 means it won't do UHD, so CD/DVD/BD are what you're limited to.
newmkv
#2204 Post by newmkv » Thu Feb 29, 2024 8:32 pm
Ok, bought option 3 LG from Bluntsman here and so far really happy.
-Finally out of the box, managed to rip 2-3 of my 4k discs successfully without any issues using makemkv (licensed) & for some reason, dvdfab has been unsuccessful.
-I strongly recommend Bluntsman here if someone is looking for easy solution without going through too much of hassle.
kapqa
#2205 Post by kapqa » Tue Mar 05, 2024 2:04 pm
hello ,
could flash a 2021 LG NS55 that has 1.05 (encrypted?) with your provided firmware and SPI Flasher
to WH16NS60 1.02 (MK)
Firmware version: 1.02
however, the drive is a WH16NS55 and not NS60, so do i need to flash another firmware on top of it to get best results?
thank you very much.
