Hello. I just made a purchase for makemkv and went to see if I could apply the new license, changing from the free beta code to my new license code but the 'Help > Register' button is greyed out. Do I just need to wait for the beta license to expire before I can use my license?
update makemkv license update question
LG-Grinding-Sound
Re: update makemkv license update question
The register link should not be greyed out... Even on my registered copy, it's clickable and brings up the registration box (filled in already). But that's so I could put a different key in, if I needed to.
What operating system?
LG-Grinding-Sound
Hey, this would be on a Mac where I am experiencing this greyed out register button. The purchase button is working, but I already purchased.
LG-Grinding-Sound
Ah ok, duh. Well I had been ripping non stop. Just realized I might need to try updating the license between rips, sure enough. Got it updated now. Thanks!
fat_lazy_cat
Hi, I'm also getting this problem. How do I update the license? I've seen this issue over a couple of threads from a quick search but none of them really have an answer.
LG-Grinding-Sound
for me, it was just a matter of trying to update the license NOT while the program was ripping.fat_lazy_cat wrote: Sun Oct 06, 2024 2:07 pm Hi, I'm also getting this problem. How do I update the license? I've seen this issue over a couple of threads from a quick search but none of them really have an answer.
