Post by Billycar11 » Tue Feb 27, 2024 12:13 am
newmkv wrote: Mon Feb 26, 2024 11:53 pm Need some help experts.
Received LG option 3 from Bluntsman today & tried ripping my 4k disc (The Thing).
1)Used makemkv and confirmed that audio track has 7.1 (DTS:X) and enabled everything as they are by default.
It completed sucessfully.
2)Coped the mkv file to my Zidoo player & played the file.
Issues:
1)When I clicked Play, as you see in pic, its menu says DTS:x but while playing, I checked its Audio/menu where it says only 5.2 and my yamaha receiver displays as 'DTS and then Neural:X'
I also checked its output where it says '4K 60 Hz'
2)Whereas, if I play my disc directly in my panasonic 4K player, I see 'DTS:X' in my yamaha receiver info and also video output says '4K 24 Hz'.
3)I also tried playing the mkv directly in my VLC in my laptop where it says in Audio menu 'Surround 7.1'
Pls let me know what am I missing here.
I do not think that output mkv from ripping is actually DTS:X and video '4K 24 Hz' as in the original disc. Right?
the drive and makemkv do not change the audio or video.
you need to configure your setup to correctly pass through the audio often called bit stream vlc cant match frame rate automatically like jriver or madvr can.
so you would need to manually match the fps it actually usually the 23hz option thats correct for movies
mecking
Post by mecking » Tue Feb 27, 2024 12:44 pm
I am a newbie and have bought an LG drive: BH 16 SN40, Rev. 1.03 with the MT1939 drive platform. Firmware (v. 1.03) is displayed as original (unpatched). Can I flash this drive and with which firmware? I would like to flash an MK-firmware. Is that possible?
Thanks in advance to the team.
kiranmehta
Post by kiranmehta » Tue Feb 27, 2024 2:35 pm
Hi I am from India, I have been reading a lot of this forum and gotten very interested in ripping blurays but there are not a lot of options available here in India and those which are available are almost double the price if not more.
Initially I was interested in the latest pioneer drives (BDR xd08-umb-s) but due to firmware support for makemkv unavailable stopped pursuing it. I currently have shortlisted following options for me here in India -
lg wh14ns40 (rupees 11492 i.e USD - )
lg wh16ns40 (rupees 11492 i.e USD - )
ASUS BW-16D1HT (rupees 11492 i.e USD - )
I am leaning towards Asus as i have heard that it handles large disks well without read errors. Also Lg drive i am not sure of the svc version as the seller on amazon is not able to provide this info.
Any recommendations apart from the above are welcome
Post by Billycar11 » Tue Feb 27, 2024 7:50 pm
mecking wrote: Tue Feb 27, 2024 12:44 pm I am a newbie and have bought an LG drive: BH 16 SN40, Rev. 1.03 with the MT1939 drive platform. Firmware (v. 1.03) is displayed as original (unpatched). Can I flash this drive and with which firmware? I would like to flash an MK-firmware. Is that possible?
No that will kill it do not flash that drive
Post by Billycar11 » Tue Feb 27, 2024 7:51 pm
kiranmehta wrote: Tue Feb 27, 2024 2:35 pm Hi I am from India, I have been reading a lot of this forum and gotten very interested in ripping blurays but there are not a lot of options available here in India and those which are available are almost double the price if not more.
They are all the same junky drive get the cheapest
It's just the illusion of choice
kiranmehta
Post by kiranmehta » Tue Feb 27, 2024 8:24 pm
Billycar11 wrote: Tue Feb 27, 2024 7:51 pm
Thanks for replying, will buy one soon!
ShevyMate
Post by ShevyMate » Thu Feb 29, 2024 1:51 am
G'day, Ive recently started getting into the idea of backing up my physical media collection and struggling to figure out if this LG BH16NS40 manufactured in 2014 is capable of ripping. This is my first time doing this so im a bit confused on how to find the information I need. Twould greatly appreciate it if someone could let me know if my drive is compatible, Cheers!
Post by Woodstock » Thu Feb 29, 2024 2:13 am
2014 means it won't do UHD, so CD/DVD/BD are what you're limited to.
newmkv
Post by newmkv » Thu Feb 29, 2024 8:32 pm
Ok, bought option 3 LG from Bluntsman here and so far really happy.
-Finally out of the box, managed to rip 2-3 of my 4k discs successfully without any issues using makemkv (licensed) & for some reason, dvdfab has been unsuccessful.
-I strongly recommend Bluntsman here if someone is looking for easy solution without going through too much of hassle.
kapqa
Post by kapqa » Tue Mar 05, 2024 2:04 pm
hello ,
could flash a 2021 LG NS55 that has 1.05 (encrypted?) with your provided firmware and SPI Flasher
to WH16NS60 1.02 (MK)
Firmware version: 1.02
however, the drive is a WH16NS55 and not NS60, so do i need to flash another firmware on top of it to get best results?
thank you very much.
Post by Billycar11 » Tue Mar 05, 2024 7:09 pm
kapqa wrote: Tue Mar 05, 2024 2:04 pm hello ,
1.02 ns60 will work and is recommend
kapqa
Post by kapqa » Wed Mar 06, 2024 12:10 pm
thanks,
it seem function well
it give error "scsi error - illegal request: copy protection key exchange failure - key not present' occured while issuing SCSI command A30..00xx............../6E3008AF
when entering and ripping first UHD movie, would process 60 GB File in around 40 Minutes which is fast, albeit in rather loud fashion.
Now my question for Film Aficionados:
This UHD has practically (according to MakeMKV) 2 titles, both are 58.9GB, and seem to contain the same files. Why is that so?
I have ripped only title 1.
Title information
Name: G.I. Joe The Rise of Cobra
Source file name: 00800.[u]mpls[/u]
Duration: 1:57:59
Chapters count: 20
Segment count: 1
Segment map: 70
File name: G.I. Joe The Rise of Cobra_t00.mkv
Title information
Source file name: 00070.[u]m2ts[/u]
Duration: 1:57:59
Segment count: 1
Segment map: 70
File name: G.I. Joe The Rise of Cobra_t01.mkv
Post by dcoke22 » Wed Mar 06, 2024 2:14 pm
They're the same segment map, so they're the same movie. Does one of the titles seem to just be English and Japanese and the other title is English and other languages?
For Disney movies, it is often the case that the title that's 00800.mpls is the English one and the other titles are other languages, but G.I. Joe: The Rise of Cobra (2009) is a Paramount release, so that rule of thumb doesn't necessarily apply.
kapqa
Post by kapqa » Wed Mar 06, 2024 5:04 pm
it has more or less the same languages, and the same subtitles, and also the codecs.,
ok , maybe disc 2 has some language less, subtitle less, but it seems the same otherwise.
i doubt that there are 2 files with each 60gb present.
the download of newest makemkv. has made the error "scsi etc." go away!
content title1
https://ibb.co/LQsxQtS
https://ibb.co/ZYvJ9rg
content title2
https://ibb.co/LpTmVCx
https://ibb.co/XsrWjts
Post by MartyMcNuts » Wed Mar 06, 2024 11:26 pm
kapqa wrote: Wed Mar 06, 2024 12:10 pm thanks,
Title information
Duration: 1:57:59
Chapters count: 20
Segment count: 1
Segment map: 70
Title information
Duration: 1:57:59
Segment count: 1
Segment map: 70
Look at the "source file name". On BD/UHD discs, you have both playlist files (.mpls) and the actual video filles (m2ts). Now, often a movie consists of multiple movie (m2ts) files, therefore, you should only be focusing on the playlist files (.mpls) as these contain the complete segment map and also contain any chapter information.
