The Last Castle 4K will not rip
Someguy1234
Post by Someguy1234 »
I keep getting to the 99% mark and then get all kinds of errors.
See log below:
Saving 1 titles into directory D:/MakeMKV/The_Last_Castle_4K
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98015035392, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98015102976, attempting to work around
Hash check failed for file 00004.m2ts at offset 98015176704, file is corrupt.
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98015232000, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98015244288-98015256576, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98015256576-98015268864, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98015268864, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98015379456, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98015379456-98015391744, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98052390912, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98052403200, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98052415488, attempting to work around
Hash check failed for file 00004.m2ts at offset 98052532224, file is corrupt.
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98052415488-98052421632, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98052421632, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98052421632-98052427776, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98052427776, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98052446208-98052452352, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98052452352, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98052452352-98052458496, attempting to work around
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98052458496, attempting to work around
Too many AV synchronization issues in file '/BDMV/STREAM/00004.m2ts' (title #-) , future messages will be printed only to log file
Hash check failed for file 00004.m2ts at offset 98057250816, file is corrupt.
Hash check failed for file 00004.m2ts at offset 98057447424, file is corrupt.
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 98052446208, attempting to work around
Hash check failed for file 00004.m2ts at offset 98084972544, file is corrupt.
Too many hash check errors in file 00004.m2ts.
Failed to save title 0 to file D:/MakeMKV/The_Last_Castle_4K/The Last Castle_t00.mkv
Encountered 115 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failed
Re: The Last Castle 4K will not rip
I would recommend you clean the disc with a damp lint free microfiber then immediately dry with another to avoid water spots.
If that don't work replace the disc
If still no replace the drive with a pioneer
The LG/Asus drives really are not recommend anymore as long as pioneers are available with old fw everyone should get one of those
