HP BU40N firmware flashing
crisvan04
#1 Post by crisvan04 » Tue Feb 06, 2024 4:47 pm
Hello everyone, totally a newbie here. Quick question, is the HP BU40N drive "just" the LG BU40N with HP label? If the answer is "yes", that means I could flash my drive using the ultimate guide to unlock UHD Blu-ray ripping, right? Here's the specs of my drive:
Model: BU40N (S05NT)
Firmware: BW42
H/W: B
Manufactured: October 2018
Re: HP BU40N firmware flashing
#2 Post by MartyMcNuts » Tue Feb 06, 2024 10:26 pm
Firmware: BW42
H/W: B
Have you tried a UHD discs yet? Not sure if BW42 firmware is compatible or not. If not UHD compatible, you can flash it directly to BU40N 1.00 as BW42 isn't encrypted.
crisvan04
#3 Post by crisvan04 » Sun Feb 25, 2024 10:50 am
Hello!
Sorry for my very late response. I just came back from my long vacation.
Anyway, I did tried putting an UHD disc in, and the drive didn't do anything. So I went ahead and tried flashing my drive using your software and the firmware pack file. After selecting the drive, the tool immediately thrown an "Input string was not in a correct format" error. So what's the problem with it?
#4 Post by MartyMcNuts » Sun Feb 25, 2024 9:08 pm
Hello!
Ensure you have MakeMKV installed in the default location which is C:\Program Files (x86)\MakeMKV.
Make sure that there isn't a disc in the drive and the tray is closed.
crisvan04
#5 Post by crisvan04 » Sun Feb 25, 2024 10:03 pm
Yeah I didn't change anything when installing MakeMKV. Also the drive tray was closed and no disk was inside when I plugged it in through direct SATA connection and opened the tool. I'm using the latest Windows 10 build, installing the latest MakeMKV version from the website.
#6 Post by MartyMcNuts » Sun Feb 25, 2024 11:42 pm
If you haven't used MakeMKV since you installed it, check MakeMKV's preferences and ensure "allow internet access" is checked then insert a standard blu-ray disc and open/intiialize it. Now remove the disc and close MakeMKV before trying to flash it again.
crisvan04
#7 Post by crisvan04 » Mon Feb 26, 2024 5:16 am
I did try a standard Blu-ray disc of mine lying around. The funny thing is the drive was recognised in Windows, but when I put the disc in, MakeMKV detected and tried to load the disc, but ended up showing that "No disc inserted". The flashing tool still threw the same "Incorrect string format" error.
#8 Post by MartyMcNuts » Mon Feb 26, 2024 5:58 am
Did you make sure MakeMKV has internet access? How is the drive connected to your PC? You are using Windows 11 64 bit?
crisvan04
#9 Post by crisvan04 » Mon Feb 26, 2024 6:50 am
Of course I did, the "enable Internet access" box was checked by default. The drive is connected into SATA connection directly because my main PC is a laptop and I swapped the stock DVD slim drive for the BU40N one. And I'm currently using Windows 10 64-bit.
crisvan04
#10 Post by crisvan04 » Mon Feb 26, 2024 7:10 am
I just took a spare HP BU40N to see if I just ignored the error and tried to flash it according to the guide, what would happen?
The flashing process went completed and MakeMKV saw new information of the drive. I put a standard and even a 4K Blu-ray to test, MakeMKV detected the discs and ripped them perfectly fine (with the stock firmware the software couldn't even see the discs). I didn't expect this to happen (thought I bricked my drive already). So, that's unusual, isn't it?
#11 Post by MartyMcNuts » Mon Feb 26, 2024 9:31 am
No, there have been several instances of people reporting an error yet the flash completed successfully.
crisvan04
#12 Post by crisvan04 » Mon Feb 26, 2024 1:37 pm
Okay, my drive was flashed successfully when I ignored the error. After being flashed, it isn't bricked and rip UHD discs smoothly, which means it's good, isn't it?
#13 Post by MartyMcNuts » Mon Feb 26, 2024 10:57 pm
Yep
s-a-g-b
#14 Post by s-a-g-b » Wed Apr 24, 2024 4:33 pm
I am having trouble with the HP drive as well, here is the label information:
HP Drive labeled "UHD Blu-Ray/DVD Writer"
Model: BU40N (S05JH)
FW: BW42
HW: B
HP PN: 849057-6F1
Made in Malaysia
MEZ65047704
I am having trouble with just plane old playback in VLC viewer. I have another BU40N (non HP) and it works consistently and all the time using VLC, but the HP is trouble.
I have tried all of the old MKV firmware the version 1.03 causes CRC errors in VLC. I currently have HL-DT-ST-BD-RE_BU40N-BU12-OM01001-211902230922 flashed on it. In order for it to play, I have to load Make MKV and open the disk, or open MKV, open the disk, then close MKV (completely random as to when this will work) It will stay capable until I reboot the computer, then the shenanigans start all over. Sometimes it plays the disk, sometimes it does not. (The HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142 also does not work)
Is there a recommended firmware for this drive that will get it to work as well as my other BU40N? I was trying to build a home theatre PC for my parents. Ripping 4K is just too expensive on storage, I would really like the playback to work consistently.
Please note: I made a firmware dump of the original firmware before I flashed it. Can it be modified to work?
