Trying to flash my drive get error:
Command produced error code 0x82502603
Using SDFtool Flasher
I have read this
viewtopic.php?f=16&t=19634
and
viewtopic.php?f=16&t=22896
Product: BD-RE BP60NB10
Revision: 1.02
Firmware date: 2121-07-08 15:56
Highest AACS version: 78
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Help would be great.
LG HL-DT-ST BD-RE BP60NB10 Get error when trying to flash.
Blue MKV
Re: LG HL-DT-ST BD-RE BP60NB10 Get error when trying to flash.
Is it SVC NB12? If so, are you trying to flash BP60NB10 NB12 1.02-MK firmware?Blue MKV wrote: Sat Feb 24, 2024 11:45 pm Trying to flash my drive get error:
I have read this
and
Revision: 1.02
Is the drive tray empty and closed?
Blue MKV
SVC code NB12Is it SVC NB12? If so, are you trying to flash BP60NB10 NB12 1.02-MK firmware?
The Firmware name is: DE_LG_BP60NB10_1.00_MK_HBD.bin
Is this the wrong firmware?
Yes the drive is empty and closed.
Wrong firmware. You should flash DE_LG_BP60NB10-NB12_1.02-MK firmware. It is in my "All You Need Firmware Pack (MartyMcNuts)". The download link is in the first post of the SDFtool Flasher thread you linked to in your first post.Blue MKV wrote: Sun Feb 25, 2024 10:54 pmSVC code NB12Is it SVC NB12? If so, are you trying to flash BP60NB10 NB12 1.02-MK firmware?
Blue MKV
Thank you MartyMcNuts
I was able to flash the drive now. But still can't copy my 4k movies?
MakeMKV v1.17.5 win(x64-release) started
Using LibreDrive mode (v06.3 id=2C4D7778BC41)
Saved AACS dump file as F:/MakeMKV/Data/MKB20_v61_Jurassic_World-_Fallen_Kingdom_AC51.tgz
OS device name: G:
Revision: 1.02
Disc Information
Label: JWFK_UPK75
Timestamp: 2018-07-23 12:41:41
Protection: AACS2.0/C v61
Data capacity: 84.72 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
What do I need to do next?
OS device name: G:
Revision: 1.02
Disc Information
Label: JWFK_UPK75
Number of layers: 3
Check that "allow internet access" is checked in preferences as MakeMKV needs to download the UHD hashed keys.Blue MKV wrote: Tue Feb 27, 2024 12:52 am Thank you MartyMcNuts
OS device name: G:
Revision: 1.02
Disc Information
Label: JWFK_UPK75
Number of layers: 3
Blue MKV
Thank you so much MartyMcNuts.
if there was a tears of joy smiley face I would use those. I have been trying for weeks trying to get this to work.
It's copying now.
And again, thank you.
It's copying now.
