LG HL-DT-ST BD-RE BP60NB10 Get error when trying to flash.
Blue MKV
Post by Blue MKV »
Trying to flash my drive get error:
Command produced error code 0x82502603
Using SDFtool Flasher
I have read this
viewtopic.php?f=16&t=19634
and
viewtopic.php?f=16&t=22896
Product: BD-RE BP60NB10
Revision: 1.02
Firmware date: 2121-07-08 15:56
Highest AACS version: 78
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Help would be great.
Re: LG HL-DT-ST BD-RE BP60NB10 Get error when trying to flash.
Blue MKV wrote:
Sat Feb 24, 2024 11:45 pm
I have read this
and
Revision: 1.02
Is it SVC NB12? If so, are you trying to flash BP60NB10 NB12 1.02-MK firmware?
Is the drive tray empty and closed?
Blue MKV
Post by Blue MKV »
SVC code NB12
The Firmware name is: DE_LG_BP60NB10_1.00_MK_HBD.bin
Is this the wrong firmware?
Yes the drive is empty and closed.
Blue MKV wrote:
Sun Feb 25, 2024 10:54 pm
SVC code NB12
Wrong firmware. You should flash DE_LG_BP60NB10-NB12_1.02-MK firmware. It is in my "All You Need Firmware Pack (MartyMcNuts)". The download link is in the first post of the SDFtool Flasher thread you linked to in your first post.
Blue MKV
Post by Blue MKV »
Thank you MartyMcNuts
I was able to flash the drive now. But still can't copy my 4k movies?
MakeMKV v1.17.5 win(x64-release) started
Using LibreDrive mode (v06.3 id=2C4D7778BC41)
Saved AACS dump file as F:/MakeMKV/Data/MKB20_v61_Jurassic_World-_Fallen_Kingdom_AC51.tgz
OS device name: G:
Revision: 1.02
Disc Information
Label: JWFK_UPK75
Timestamp: 2018-07-23 12:41:41
Protection: AACS2.0/C v61
Data capacity: 84.72 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
What do I need to do next?
Blue MKV wrote:
Tue Feb 27, 2024 12:52 am
OS device name: G:
Revision: 1.02
Disc Information
Label: JWFK_UPK75
Number of layers: 3
Check that "allow internet access" is checked in preferences as MakeMKV needs to download the UHD hashed keys.
Blue MKV
Post by Blue MKV »
Thank you so much MartyMcNuts. :D :D :D if there was a tears of joy smiley face I would use those. I have been trying for weeks trying to get this to work.
It's copying now.
And again, thank you.
