#9721 Post by RESET_9999 » Wed Feb 21, 2024 3:03 pm
chros wrote:
Wed Feb 21, 2024 2:32 pm
Tmin=0 doesn't do anything with the raised black in DoVi on LG Oleds.
good to know thanks... Strange how the DV engine works differently in LLDV for that aspect.
Trees
#9722 Post by Trees » Thu Feb 22, 2024 3:11 pm
Question, I'm looking to batch analyse a folder. However, I want the MDL to be 7 and all the borders to be 0. Dovi_Scripts tells me to provide a external config file.
How do I do such thing?
#9723 Post by RESET_9999 » Thu Feb 22, 2024 3:18 pm
https://www.youtube.com/watch?v=jBqbG5XM54g
if your folder with files all have the same MDL and Active area, you don't have to provide external config files.
PS: please ask your dovi_scripts questions on doom9 official support thread: https://forum.doom9.org/showthread.php?t=185317
I'll eventually stop answering questions about my script here on makemkv.
Trees
#9724 Post by Trees » Thu Feb 22, 2024 5:40 pm
But if I copy the folder to Dovi_Tools after selecting 3-1, it doesn't ask me the MDL or borders I want to use. So how does it know I want option 7 and 0 borders?
#9725 Post by RESET_9999 » Thu Feb 22, 2024 5:58 pm
if you input a folder and no config file is found, it will ask you for a MDL and L5 which will be used for all the videos in the folder.
If the videos in your folder are cropped, the script won't ask you about it and will automatically set L5 to 0
Trees
#9726 Post by Trees » Sat Feb 24, 2024 4:22 pm
Dovi_Tools usually doesn't ask me to choose an MDL or L5 when I input a whole folder. Edit: Weird, it does now. Typical!
I also cannot seem to choose and MDL of 10000, I think I could in the past. Has it been removed? Also, is there are difference in HDR quality when choosing a, say, MDL 10000 over 4000?
Shellsobig30
#9727 Post by Shellsobig30 » Sun Feb 25, 2024 2:47 am
RESET_9999 wrote:
Tue Feb 06, 2024 9:18 pm
sw5163 wrote:
Tue Feb 06, 2024 6:57 pm
Is there a way to disable tone mapping in Movies & TV app or energy player with MSFT HW video decoder, and pass through HDR10 metadata? Or do I have to use MPV for passing through HDR10 and switch to MSFT HW video decoder for tone mapping DV content?
no i think the OS HDR always sends incorrect static HDR10 metadata.
Do you mean the OS HDR sends incorrect static metadata even when using MadVR with HDR Passthrough? Is NV HDR any different?
#9728 Post by RESET_9999 » Sun Feb 25, 2024 2:36 pm
Yes, 4000 MDL looks much darker vs 1000. As for the metadata, the L1 max and min are the same but the avg is not calculated the same. Trims are also different.
see: https://slow.pics/c/xlgE3H1t
this the only MDL possible in resolve and CM
afarvvik
#9729 Post by afarvvik » Wed Feb 28, 2024 2:59 am
hi @RESET_9999 is dovi tools available for arm64 linux anywhere?
#9730 Post by RESET_9999 » Wed Feb 28, 2024 2:11 pm
dovi_tool cli: yes
dovi_scripts: no
frrilay
#9731 Post by frrilay » Thu Feb 29, 2024 8:47 am
Hi RESET, using cm_analyze to generate DV will result in a CMv4.0 file with latest algorythm; what exactly do you loose when converting this file down to CMv2.9? The goal being to make it compatible with ATV for example (and even when Infuse adds support for CMv4.0, I understood from your previous posts that ATV doesn't handle CMv4.0 perfectly).
Taking the occasion to say merci beaucoup for your hard work ;)
afarvvik
#9732 Post by afarvvik » Thu Feb 29, 2024 10:15 am
dovi_tool cli: yes
dovi_scripts: no
could you please provide a link, it is not on the github page & googling did not help. thanks.
quietvoid
#9733 Post by quietvoid » Thu Feb 29, 2024 11:36 am
There are currently no Linux ARM64 builds.
Build it yourself.
#9734 Post by RESET_9999 » Thu Feb 29, 2024 3:20 pm
cmv4.0 has better tone mapping than cmv2.9.
It never clips highlights(tunning 1), is much brighter, and doesn't crush black/shadow details.
old cmv2.9 vs old cmv4.0 vs new cmv4.0 vs hdr10plus vs madVR (metadata comparison)
https://drive.google.com/file/d/1PiiK4W ... sp=sharing
Cannikin
#9735 Post by Cannikin » Tue Mar 05, 2024 5:46 pm
Hey everyone sorry to butt in on this thread but it seemed fairly related to what I'm trying to do:
Is there an easy ffmpeg command to convert an .mp4 with embedded DV (profile 5) to .mkv?
A google search for "mp4 with dolby vision to mkv" is all for doing the opposite—converting .mkv to .mp4. I've got plenty of DV MKVs that all play great (ripped with MakeMKV) but I recently got an .mp4 and can't figure out how to convert. When I try with a standard `ffmpeg -i movie.mp4 -map 0 -c copy movie.mkv` I get:
[matroska @ 0x11e028400] Tag dvh1 incompatible with output codec id '173' ([0][0][0][0])
Could not write header for output file #0 (incorrect codec parameters ?): Invalid data found when processing input
Error initializing output stream 0:2 --
The stream identifier for the mp4 looks like:
Stream #0:0(und): Video: hevc (Main 10) (dvh1 / 0x31687664), yuv420p10le(pc), 1920x1080 [SAR 1:1 DAR 16:9], 6829 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 23.98 tbc (default)
    Metadata:
      creation_time   : 2024-03-02T05:05:29.000000Z
      handler_name    : VideoHandler
      vendor_id       : [0][0][0][0]
      encoder         : DOVI Coding
    Side data:
      DOVI configuration record: version: 1.0, profile: 5, level: 3, rpu flag: 1, el flag: 0, bl flag: 1, compatibility id: 0
Thanks for any help!
