My good old BD-RE BU40N is now ejecting everything within a few seconds. No Error, nothing. Just a few click clacks and boom, ejected. No message on MakeMKV.
Here are the details from the drive:
Product: BD-RE BU40N
Revision: FR07
Serial number: 803HS013801
Firmware date: 2118-01-22 15:36
Bus encryption flags: 1F
Highest AACS version: 81
Firmware version: 0.FR07J
How to tell if it has been bricked? It ejects 4k and BD discs.
I have another Drive. Pioneer BDR-UD04, that runs everything fine so far what the BU40N spits out.
Drive suddenly ejecting everything
Re: Drive suddenly ejecting everything
Clean the laser lens. If that doesn't help I assumpe it's a door stop now.
D3F3ND3R16
How to clean that?! Never touched anything inside it :OCoopervid wrote: Thu Feb 22, 2024 4:49 pm Clean the laser lens. If that doesn't help I assumpe it's a door stop now.
Pop out the tray. You should see now little glas lenses approx. 2-3 mm in diameter. Use a cotton swab and some alcohol. Wipe them dry with another cotton swab. Try the disc. There are two lenses and 2 lasers in the drive. One for CD /DVD the other for BD. If the drive still reads CDs and DVDs the laser for BDs is defective.
D3F3ND3R16
I will try! Thanks!Coopervid wrote: Thu Feb 22, 2024 5:28 pm Pop out the tray. You should see now little glas lenses approx. 2-3 mm in diameter. Use a cotton swab and some alcohol. Wipe them dry with another cotton swab. Try the disc. There are two lenses and 2 lasers in the drive. One for CD /DVD the other for BD. If the drive still reads CDs and DVDs the laser for BDs is defective.
Any way to verify if its bricked with software?
No.
Try reading a CD and DVD. If it works the red laser is OK.
Try reading a BD. If it doesn't work the blue laser is dead.
D3F3ND3R16
I tried to clean it now. Inserted UHD - click click - eject.Coopervid wrote: Thu Feb 22, 2024 5:45 pm No.
BD Disc - same two click noises - eject
empty CD-R - same.
Don't have an DVD atm, lol. Can't test that.
doesnt sound to good right?
It's a brick.
D3F3ND3R16
is that normal that they last that short? its not even 4 years old, maybe copied around 1-200 discs.
luckily I have another drive atm. BD-RW BDR-UD04.
Should I get just a second one then? are they still delivered with an good FW?
My ASUS died after a year.
Pioneer UD04 are still good for UHDs but asmcom reported issues with dBpoweramp with CDs with the newest revision.
Yep, if you manage to get 1 year out of a drive (that isn't Pioneer) these days, you are doing well.D3F3ND3R16 wrote: Thu Feb 22, 2024 9:29 pmis that normal that they last that short? its not even 4 years old, maybe copied around 1-200 discs.
