Drive suddenly ejecting everything
D3F3ND3R16
Post by D3F3ND3R16 »
My good old BD-RE BU40N is now ejecting everything within a few seconds. No Error, nothing. Just a few click clacks and boom, ejected. No message on MakeMKV.
Here are the details from the drive:
Product: BD-RE BU40N
Revision: FR07
Serial number: 803HS013801
Firmware date: 2118-01-22 15:36
Bus encryption flags: 1F
Highest AACS version: 81
Firmware version: 0.FR07J
How to tell if it has been bricked? It ejects 4k and BD discs.
I have another Drive. Pioneer BDR-UD04, that runs everything fine so far what the BU40N spits out.
Re: Drive suddenly ejecting everything
Clean the laser lens. If that doesn't help I assumpe it's a door stop now.
D3F3ND3R16
Coopervid wrote:
Thu Feb 22, 2024 4:49 pm
How to clean that?! Never touched anything inside it :O
Pop out the tray. You should see now little glas lenses approx. 2-3 mm in diameter. Use a cotton swab and some alcohol. Wipe them dry with another cotton swab. Try the disc. There are two lenses and 2 lasers in the drive. One for CD /DVD the other for BD. If the drive still reads CDs and DVDs the laser for BDs is defective.
D3F3ND3R16
Coopervid wrote:
Thu Feb 22, 2024 5:28 pm
I will try! Thanks!
Any way to verify if its bricked with software?
No.
Try reading a CD and DVD. If it works the red laser is OK.
Try reading a BD. If it doesn't work the blue laser is dead.
D3F3ND3R16
Coopervid wrote:
Thu Feb 22, 2024 5:45 pm
No.
I tried to clean it now. Inserted UHD - click click - eject.
BD Disc - same two click noises - eject
empty CD-R - same.
Don't have an DVD atm, lol. Can't test that.
doesnt sound to good right?
It's a brick.
D3F3ND3R16
Coopervid wrote:
Thu Feb 22, 2024 6:28 pm
It's a brick.
is that normal that they last that short? its not even 4 years old, maybe copied around 1-200 discs.
luckily I have another drive atm. BD-RW BDR-UD04.
Should I get just a second one then? are they still delivered with an good FW?
My ASUS died after a year.
Pioneer UD04 are still good for UHDs but asmcom reported issues with dBpoweramp with CDs with the newest revision.
D3F3ND3R16 wrote:
Thu Feb 22, 2024 9:29 pm
It's a brick.
Yep, if you manage to get 1 year out of a drive (that isn't Pioneer) these days, you are doing well.
