Error using makemkvcon
RickMac
Post by RickMac » Fri Aug 05, 2011 11:40 pm
Hi All,
I have been transferring all my movie to digital format. After researching decided to go with ISO format due to its lossless feature and wide support by many other applications. Unfortunately, I found PLEX doesn't support ISO format and likes MKV very much.
I tried to use an automated way to convert all ISO files to MKV by using makemkvcon command line. I am posting error below.
Before I have a couple of questions:
1. Which format is the recommended format to use with PLEX and any other Media Servers as XBMC. I require such format to be lossless since space is not an issue for me and want to make sure I keep an exact image of the DVD.
2. Which application besides makemkv in case I cannot get it to work, will be the best recommended to accomplish this task. I am running MAC OS.
Here is the error message I get from makemkvcon:
MSG:1005,0,1,"MakeMKV v1.6.12 darwin(x86-release) started","%1 started","MakeMKV v1.6.12 darwin(x86-release)"
MSG:2014,0,3,"Optical drive \"DVD+R-DL MATSHITA DVD-R UJ-857E ZA0E\" opened in DASPI v1.3 mode.","Optical drive \"%1\" opened in DASPI v%2.%3 mode.","DVD+R-DL MATSHITA DVD-R UJ-857E ZA0E","1","3"
DRV:0,1,1,512,"DVD+R-DL MATSHITA DVD-R UJ-857E ZA0E","",""
DRV:1,0,0,0,"","",""
DRV:2,0,0,0,"","",""
DRV:3,0,0,0,"","",""
DRV:4,0,0,0,"","",""
DRV:5,0,0,0,"","",""
DRV:6,0,0,0,"","",""
DRV:7,0,0,0,"","",""
DRV:8,0,0,0,"","",""
DRV:9,0,0,0,"","",""
DRV:10,0,0,0,"","",""
DRV:11,0,0,0,"","",""
DRV:12,0,0,0,"","",""
DRV:13,0,0,0,"","",""
DRV:14,0,0,0,"","",""
DRV:15,0,0,0,"","",""
