XDG
QuartzColonel
XDG
#1 Post by QuartzColonel » Wed Feb 21, 2024 7:50 pm
Are there any plans for XDG Base Directory specification instead of automatically putting files into ~/.MakeMKV, which clutters the user's home directory? Many programs are in the midst of a shift right now, and I encourage MakeMKV devs to do the same.
https://specifications.freedesktop.org/ ... 01s02.html
edited: to improve the precision of the question
Re: XDG
#2 Post by Woodstock » Wed Feb 21, 2024 8:13 pm
"dumping files"? You have control over what files are dumped there. Mine has 8 files, the most recent is _private_data_tar, with just 4 being created from running the program in general (when I was doing some data collection).
QuartzColonel
Re: XDG
#3 Post by QuartzColonel » Wed Mar 06, 2024 4:48 pm
I can tell the term usage may have triggered the wrong response here.
Could you confirm that you've managed to move the ~/.MakeMKV folder to another location, such as ~/.config?
I'm looking to have nothing in the home, sorry for the misusage of the terms above!
QuartzColonel
Re: XDG
#4 Post by QuartzColonel » Sat Feb 08, 2025 10:41 pm
Circling back on this one, can the folder ~/.MakeMKV be moved to, say ~/.config/MakeMKV?
Re: XDG
#5 Post by dcoke22 » Mon Feb 10, 2025 11:05 pm
The General tab of MakeMKV's preferences allows one to set the data directory to where ever you like.
