XDG
QuartzColonel
XDG
Post by QuartzColonel »
Are there any plans for XDG Base Directory specification instead of automatically putting files into ~/.MakeMKV, which clutters the user's home directory? Many programs are in the midst of a shift right now, and I encourage MakeMKV devs to do the same.
https://specifications.freedesktop.org/ ... 01s02.html
edited: to improve the precision of the question
Re: XDG
"dumping files"? You have control over what files are dumped there. Mine has 8 files, the most recent is _private_data_tar, with just 4 being created from running the program in general (when I was doing some data collection).
QuartzColonel
Re: XDG
I can tell the term usage may have triggered the wrong response here.
Could you confirm that you've managed to move the ~/.MakeMKV folder to another location, such as ~/.config?
I'm looking to have nothing in the home, sorry for the misusage of the terms above!
QuartzColonel
Re: XDG
Circling back on this one, can the folder ~/.MakeMKV be moved to, say ~/.config/MakeMKV?
Re: XDG
The General tab of MakeMKV's preferences allows one to set the data directory to where ever you like.
