SVC code on LG BP60NB10 doesn't match guide
AroundOrion
Post by AroundOrion » Wed Feb 21, 2024 3:15 pm
I just purchased an LG BP60NB10 with intent to flash the custom firmware. I want to ensure it's compatible, but noticed one inconsistency with the guide where it states the following:
SVC NS50+ LG only on label for NB drives NB50+
The label of my drive has the following:
"SVC CODE : NB12"
Am I understanding from the prior quote that it must say NB50 or higher? What does it mean that it says NB12 - will flashing still work?
Thank you!
P.S. Here's the drive info from MakeMKV:
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: *************
Firmware date: 2121-07-08 15:56
Highest AACS version: 47
Hardware support: Yes
Firmware support: No
Firmware version: 1.02
Re: SVC code on LG BP60NB10 doesn't match guide
Post by Billycar11 » Wed Feb 21, 2024 4:35 pm
Nb 12 works fine the nb 50 is talking about the desktop drives.
Just follow the guides recommend fw and you will be fine
