gagans
Post by gagans » Tue Feb 20, 2024 9:23 pm
I am getting about 6x rips.... What did I miss? What did I not flash properly? Also getting a lot of errors. so far unable to successfully make an mkv.
Billycar11 wrote: Mon May 27, 2019 5:20 am
LG WH14NS40, UHD Friendly Internal 5.25 sata | Rip speed 8x BD 66 ~45 mins BD 100 ~1 hour if flashed properly other wise 6x rips speed and slower then BU40N
Manciple
Post by Manciple » Tue Feb 20, 2024 9:48 pm
United States.
Post by MartyMcNuts » Wed Feb 21, 2024 12:33 am
newmkv wrote: Tue Feb 20, 2024 3:47 pm
Billycar11 wrote: Tue Feb 20, 2024 3:25 am
newmkv wrote: Tue Feb 20, 2024 3:02 am Hello, i am thinking to return that player and buy Pioneer BDR-XS07UHD if you think it can rip flawlessly out of the box without any changes. Kindly let me know please. thanks again
no the pioneers no longer work out of the box unless you buy them from a flasher
Thanks again to everyone who is responding to help me here.
Finally i decided to return the Archgon to amazon as I do not want to take a chance in doing manual changes just to make my 4k rip work. Just bought option 3/LG from Bluntman here as it comes with pre-flashed and expected to work out of the box.
Need some inputs from this forum now.
So with my new drive coming in---
--Say, i have licensed of both makemkv and DVDFab UHD ripper SW. FYI, i have been using DVDFab Blu-ray ripper so far which works like a breeze.
--I have already deleted/uninstalled whatever I installed/copied like some additional SD flasher tool, framework modules, etc. and cleaned up my windows 11 just like before.
--Once I receive this pre-flashed LG from Bluntsman, my assumption is that i just out of the box open dvdfab or makemkv and try ripping my 4K discs without any changes. Is my understanding correct?
Or, i still need some pre-requisites?
thanks a lot in advance.
Providing Bluntman has flashed it with BU40N 1.00 firmware, yes it will work with DVDFab out of the box. If it has BU40N 1.03-MK or BP60NB10 MK firmware, then no, it won't work with DVDFab.
newmkv
Post by newmkv » Wed Feb 21, 2024 1:30 am
MartyMcNuts wrote: Wed Feb 21, 2024 12:33 am
ah what a complicated one ;)
Bluntman has already confirmed to me that his drive should work with both dvdfab and makemkv.
Hoping for the best. Let us see.
newmkv
Post by newmkv » Wed Feb 21, 2024 1:34 am
Very strange today.
Following my previous few posts, i just cleaned up my windows 11 laptop by removing all newly installed firmware, SD flash tool, etc. and ended up only with original/unmodified makemkv (licensed) and dvdfab Blu-ray/UHD ripper.
Tried ripping my old Blu-ray disc using dvdfab and to my surprise, did not work but threw same disc error which I got for 4K ripping. Pls note that dvdfab used to work flawlessly for all my Blu-ray ripping just before I tried with a 4K disc.
Then tried same with makemkv and threw same error (Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE
FAILURE - KEY NOT PRESENT) which i got for 4k ripping before.
I just re-attempted makemkv which worked fine for blu-ray ripping.
I really don't know what happened ...
Post by Billycar11 » Wed Feb 21, 2024 1:50 am
gagans wrote: Tue Feb 20, 2024 9:23 pm I am getting about 6x rips.... What did I miss? What did I not flash properly? Also getting a lot of errors. so far unable to successfully make an mkv.
did you flash to WH16NS60 1.02 as the guide says that will give you 8x and no sleep bug...
but yeah lg/asus drives are just junk these days glad to be done with them but what's your error likely need to clean disc
Post by Billycar11 » Wed Feb 21, 2024 1:52 am
newmkv wrote: Wed Feb 21, 2024 1:34 am Very strange today.
could be a few things new aacs version revoked your drive as its not flashed
power to low and drive is rebooting
natra
Post by natra » Wed Feb 21, 2024 11:38 am
natra wrote: Sat Feb 17, 2024 11:27 pm Hi guys, will my drive work.
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number: RFDL020701WL
Firmware date: 2017-12-21
Highest AACS version: 76
Drive platform: RS8601
Firmware version: E114/ID71
Does anyone know if I can flash this drive and if so, what files should I be using?
Post by Billycar11 » Wed Feb 21, 2024 11:44 am
natra wrote: Wed Feb 21, 2024 11:38 am
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
That drive can only be professionally flashed email me for that see below
Post by Coopervid » Wed Feb 21, 2024 12:00 pm
Manciple wrote: Tue Feb 20, 2024 9:48 pm United States.
Check your PM.
Manciple
Post by Manciple » Wed Feb 21, 2024 3:38 pm
@Coopervid. PM received. I'm still unable to send PM's as I'm a new user, hence my reply here. I've canceled the LG order and substituted in the Pioneer. I'll be back in touch once I get it, if I can't get the flash tools available here to work on it.
Post by Coopervid » Wed Feb 21, 2024 4:59 pm
Manciple wrote: Wed Feb 21, 2024 3:38 pm @Coopervid. PM received. I'm still unable to send PM's as I'm a new user, hence my reply here. I've canceled the LG order and substituted in the Pioneer. I'll be back in touch once I get it, if I can't get the flash tools available here to work on it.
OK. Just post here when you have it.
Post by Coopervid » Wed Feb 21, 2024 7:12 pm
You have another PM.
Shuffle2694
Post by Shuffle2694 » Sun Feb 25, 2024 5:56 pm
I was lucky enough to find a BDR-2213 on the older firmware. It shows up in MakeMKV as
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-213M
Revision: 1.02
Serial number:
Firmware date: 2022-04-06
Drive platform: Pioneer RS9200
Firmware version: ID56
Am I correct that there is a UHD flasher available for this device from at least some of the sellers?
newmkv
Post by newmkv » Mon Feb 26, 2024 11:53 pm
Need some help experts.
Received LG option 3 from Bluntsman today & tried ripping my 4k disc (The Thing).
1)Used makemkv and confirmed that audio track has 7.1 (DTS:X) and enabled everything as they are by default.
It completed sucessfully.
2)Coped the mkv file to my Zidoo player & played the file.
Issues:
1)When I clicked Play, as you see in pic, its menu says DTS:x but while playing, I checked its Audio/menu where it says only 5.2 and my yamaha receiver displays as 'DTS and then Neural:X'
I also checked its output where it says '4K 60 Hz'
2)Whereas, if I play my disc directly in my panasonic 4K player, I see 'DTS:X' in my yamaha receiver info and also video output says '4K 24 Hz'.
3)I also tried playing the mkv directly in my VLC in my laptop where it says in Audio menu 'Surround 7.1'
Pls let me know what am I missing here.
I do not think that output mkv from ripping is actually DTS:X and video '4K 24 Hz' as in the original disc. Right?
