Wrongly flashed BU40N
J0han
Post by J0han » Sun Feb 18, 2024 9:22 pm
Hi all,
I received a LG BU40N-FR07 yesterday, and I tried many different .bin files for flashing using terminal and sdftool (using enc and without) and everytime the flasher told me the process was succesful (no errors) but the firmware never changed/never showed as updated after starting makemkv. Not after rebooting and/or powering off the device.
UNTILL I installed a LG WH16NS60_1.00.bin, but now drive will not eject/open (it's probably the wrong firmware).
How do I fix this? Please help, quite frustrated.
J0han
Re: Wrongly flashed BU40N
Post by J0han » Mon Feb 19, 2024 2:29 am
This is my current information:
OS device name: K:
Product: BD-RE WH16NS60
Revision: 1.00
Serial number: 908HS022858
Firmware date: 2117-04-25 17:56
Highest AACS version: 61
Firmware version: 1.00
Reflashing does not change anything..
Post by MartyMcNuts » Mon Feb 19, 2024 7:29 pm
J0han wrote: Sun Feb 18, 2024 9:22 pm Hi all,
You should have just flashed it to BU40N 1.00 as the original firmware was not encrypted. Use the recovery option of SDFtool Flasher. In the popup, select the drive's current firmware then in the firmware selection drop down box, select BU40N 1.00 firmware.
J0han
Post by J0han » Sun Feb 25, 2024 4:19 am
I tried the recovery option with that firmware and it did not work. The UI always tells me the process is successful but the in the mkv overview the firmware always stays the same (except for that one time when I flashed the wrong one).
I'm actually not unexperienced with flashing, I even regularly do it for work.. but the UI always telling you everything went well while nothing ever changes? How is that possible? :roll: Never seen that before.
Post by MartyMcNuts » Sun Feb 25, 2024 9:21 pm
J0han wrote: Sun Feb 25, 2024 4:19 am I tried the recovery option with that firmware and it did not work. The UI always tells me the process is successful but the in the mkv overview the firmware always stays the same (except for that one time when I flashed the wrong one).
The UI is just a front end for the MakeMKV command line flash tool so the output is the same.
If it's not working, you're not doing it correctly.
When you select recovery, a window will popup. In this window select the drive's current firmware (WH16NS60 or whatever you flashed). Now in the normal firmware drop down box select BU40N 1.00 firmware.
It's been a few years since I tested this but it should work. I did the opposite (desktop drive flashed with slim drive firmware).
J0han
Post by J0han » Tue Mar 05, 2024 5:35 am
The recovery option worked!! (when selecting the old firmware first, the drive is correctly flashed now..)
Thanks a lot. Sorry if the information was somewhere, it just gets overwhelming (need a vacation as well ;)).
