The Equalizer 3 4K (German Disc)
katja2500
Post by katja2500 » Sat Dec 02, 2023 7:05 pm
Submitted: MKB20_v77_The_Equalizer_3_6C86-UHD-German Disc
NGNXM8
Re: The Equalizer 3 4K (German Disc)
Post by NGNXM8 » Wed Dec 06, 2023 2:18 pm
Got the same disc from plaion (Steelbook), not working so far. Fingers crossed I can watch it by Christmas haha
katja2500
Post by katja2500 » Wed Dec 06, 2023 2:47 pm
I hope so too, I've been waiting for a few days, it's taking a long time, it's a shame.
katja2500
Post by katja2500 » Fri Dec 08, 2023 8:07 pm
It works now, I have successfully ripped my disc
MeyroNW
Post by MeyroNW » Sat Feb 17, 2024 3:17 pm
I have the same problem - MakeMKV stopps with error and does not save the file. I have added the log file here. Do I need to submit more or different material?
I'm working on a Mac with MakeMKV version 1.17.6
Post by dcoke22 » Sat Feb 17, 2024 4:38 pm
Copy & paste the content of your log file into a post so we can see it.
MeyroNW
Post by MeyroNW » Mon Feb 19, 2024 8:33 am
I hope this time it works to add the file.
MeyroNW
Post by MeyroNW » Mon Feb 19, 2024 8:38 am
And here's the plain text of the log file:
Debug log started at Sat Feb 17 11:38:21 2024 , written by MakeMKV v1.17.6 darwin(x64-release)
001005:0000 MakeMKV v1.17.6 darwin(x64-release) gestartet
001004:0000 Debug-Aufzeichnung eingeschaltet. Aufzeichnung wird gespeichert als file:///Users/xxxx/MakeMKV_log.txt
Network access is ENABLED, CURL version 8.1.2/(SecureTransport) LibreSSL/3.3.6/1.55.1 (x86_64-apple-darwin23.0) , proxy server not set.
002010:0000 Optisches Laufwerk "BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIK0EM3EG5347d" wurde im Zugriffsmodus des Betriebssystems geöffnet.
SDF  v098: HL-DT-ST_BD-RE_BP60NB10_1.02_212005070935_SIK0EM3EG5347
001011:0000 Using LibreDrive mode (v06.3 id=4C194CE2C4D1)
003007:0000 Direkter Zugriffsmodus wird verwendet
005085:0000 Inhalte-Hashtabelle geladen, überprüfe Integrität der M2TS-Dateien.
DEBUG: Code 2147483648 at G}\YxK&TCAV(>~(6:121265499
Found java version=1.7.0 path=/Library/Java/JavaVirtualMachines/jdk1.7.0_21.jdk/Contents/Home/bin/java
Found java version=1.8.0.333 path=/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
003344:0000 Using Java runtime from /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
DISCID=2A6092BD803761F6875390D2FBD7B40083E68230
003307:0000 Datei 00853.mpls wurde als Titel 1 hinzugefügt
003307:0000 Datei 00855.mpls wurde als Titel 2 hinzugefügt
003307:0000 Datei 00856.mpls wurde als Titel 3 hinzugefügt
003307:0000 Datei 00001.m2ts wurde als Titel 4 hinzugefügt
005011:0000 Die Aufgabe wurde erfolgreich abgeschlossen
005014:0000 1 Titel werden in Verzeichnis file:///Users/xxxx/Movies/MakeMKV gespeichert
001003:0020 DEBUG: Code 1073741829 at Eg<>(hmIqmxY;\b^:213130559
001003:0020 DEBUG: Code 100864261 at WX<_NOE'^Y?:OlZ]:121271617
001003:0020 DEBUG: Code 100864261 at Eg<>(hmIqmxY;\b^:213130559
002003:0000 Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf während des Auslesens von '/BDMV/STREAM/00001.m2ts' bei Offset '40269643776'
002003:0000 Fehler 'Posix-Fehler - Input/output error' trat auf während des Auslesens von '/dev/rdisk4' bei Offset '40269643776'
DEBUG: Code 1073741829 at <;1uQF|/9dA >N~dqD:29394896
001003:0020 DEBUG: Code 1073741829 at <;1uQF|/9dA >N~dqD:213131502
002003:0000 Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf während des Auslesens von '/BDMV/STREAM/00001.m2ts' bei Offset '40269772800'
002003:0000 Fehler 'Posix-Fehler - Input/output error' trat auf während des Auslesens von '/dev/rdisk4' bei Offset '40269772800'
DEBUG: Code 100864261 at <;1uQF|/9dA >N~dqD:29394896
001003:0020 DEBUG: Code 100864261 at <;1uQF|/9dA >N~dqD:213131502
001003:0020 DEBUG: Code 0 at {_kGLPBkGw6T{3z-=mU_:29395471
001003:0020 DEBUG: Code 0 at )LNJ}/Cb{^R\-EP_yo=J:29394068
001003:0020 DEBUG: Code 0 at {_kGLPBkGw6T{3z-=mU_:213131157
001003:0020 DEBUG: Code 0 at {_kGLPBkGw6T{3z-=mU_:121262647
001003:0020 DEBUG: Code 19662975 at {_kGLPBkGw6T{3z-=mU_:121261773
002003:0000 Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf während des Auslesens von '/BDMV/STREAM/00001.m2ts' bei Offset '40270166016'
002003:0000 Fehler 'Posix-Fehler - Input/output error' trat auf während des Auslesens von '/dev/rdisk4' bei Offset '40270166016'
001003:0020 DEBUG: Code 19663167 at {_kGLPBkGw6T{3z-=mU_:121261773
001003:0020 DEBUG: Code 0 at 0wo#W)AHY#RDU'nC\1 4$:213137068
001003:0020 DEBUG: Code 0 at ~eC$-;&KgzB(YxU]+/JP:29394022
001003:0020 DEBUG: Code 0 at ~eC$-;&KgzB(YxU]+/JP:29404878
001003:0020 DEBUG: Code 0 at ~eC$-;&KgzB(YxU]+/JP:29405384
001003:0020 DEBUG: Code 0 at ~eC$-;&KgzB(YxU]+/JP:29403383
001003:0020 DEBUG: Code 0 at :?2!{,=xJ6k.)%}mum*o:213141208
001003:0020 DEBUG: Code 0 at a4h>~FX72&t{|>W3:213132537
001003:0020 DEBUG: Code 0 at G5<tTo/|5HYhH;`>0:29396207
001003:0020 DEBUG: Code 0 at G5<tTo/|5HYhH;`>0:121264257
001003:0020 DEBUG: Code 0 at G5<tTo/|5HYhH;`>0:213130490
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
---- Failed /Users/xxxx/Movies/MakeMKV/The Equalizer 3-FPL_MainFeature.mkv
ch_0        4682517840000 0
ch_1        4683463785000 0
ch_2        4684409730000 0
ch_3        4685400720000 0
ch_4        4686346665000 0
ch_5        4687292610000 0
ch_6        4688238555000 0
ch_7        4689184500000 0
mt=0x7f985b718a40 n=11
s=0 n=1 o=40270166016
    0 796342 000001  4689184500000       45045000 D6D4B76B 000000034601100000002040010C01FFFF222000000300900000030000030099350300004E3400075300E8000002A1420101222000000300900000030000030099A001E020021C4D8D35924F841470F1C0903B0E18361A0842F081210088401006E1A306C341085CA0A021044170B02A0AC28035407080E007D02B4180A8200B
s=1 n=1 o=40263290880
    1   2752 000001  4689192960000       11520000 D4142676 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000040000000000000004000000070CDB0CE2F7356B5AD6A529494A5294A10839CC5349EE63148314A429CE7325294A4E93A0E624A0E6B148394A4318C6425294A528318C62418B4988218C64298C73
s=2 n=1 o=40263290880
    2   2012 000001  4689192960000       11520000 899B7BB0 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000040000000000000004000000070CDB0CE2F7356B5AD6A529494A5294A10839CC5349EE63148314A429CE7325294A4E93A0E624A0E6B148394A4318C6425294A528318C62418B4988218C64298C73
s=3 n=1 o=40261165056
    3   1048 000001  4689183600000         900000 D4822E56 120C0CC4F8726FBA0017804FB7521000000088D543FC0201CAEFE307E3011FC6BC003212203C20BA212121F6F1EA0D00011078923A4A840C7000000334486DD03CF260725F971F5324333900E0227F160A32234345D66B971A6AC40C8F4880712B0F13846DAFCC0F420827F9E400023DA16149CF94C3AF4387E6200012D1595A
s=4 n=1 o=40264925184
    4   2560 000001  4689204480000       34560000 5EAA8118 0B77ED852440E1FFFCC03E955E186186170E22AAD4A15454AAB27430A3D776F9F52854DED84C957967B5F4D7A6E953E4CF9FA5AEF61BE4CE953DAD512BE8549F3E7CFA9A57D49F5372E75584C96BBE7DD4388AA952B56E142A501ED77B11D257CF69BEA6492D2ACFA13EAEF61577CFA191856A1BA4CFD2BE56E696756968D873
s=5 n=1 o=40260894720
    5   1048 000001  4689183600000         900000 D4822E56 120C0CC4F8726FBA0017804FB7521000000088D543FC0201CAEFE307E3011FC6BC003212203C20BA212121F6F1EA0D00011078923A4A840C7000000334486DD03CF260725F971F5324333900E0227F160A32234345D66B971A6AC40C8F4880712B0F13846DAFCC0F420827F9E400023DA16149CF94C3AF4387E6200012D1595A
s=6 n=1 o=40264925184
    6   2560 000001  4689204480000       34560000 C537C441 0B77ED852440E1FFFCC03E955E186186170E22AAD4A15454AAB27430A3D776F9F52854DED84C957967B5F4D7A6E953E4CF9FA5AEF61BE4CE953DAD512BE8549F3E7CFA9A57D49F5372E75584C96BBE7DD4388AA952B56E142A501ED77B11D257CF69BEA6492D2ACFA13EAEF61577CFA191856A1BA4CFD2BE56E696756968D873
s=7 n=0 o=40270166016
s=8 n=0 o=40270166016
s=9 n=0 o=40270166016
s=10 n=0 o=40270166016
mt=0x600000d10c00 n=11
s=0 n=11 o=40270166016
    0 169429 000008  4689094410000       45045000 A7B7B146 00000003460150000000094401C172438D63B240000000084E01010304004080000000161001E00CF677085E21308F800000030000030000DB800000626010014784019ECEE10BC426BC7544D44BB3249292E0E99E76995911A621F104EBC8A2E8474B99C949EE0C190AC891D26B03A905A666EA07566A52980CA3F9C0CD7C85
    0 167140 000008  4689139455000       45045000 A962B4C6 00000003460150000000094401C172438D63B240000000084E01010304104080000000171001E00D024BCEE10BC4268F800000030000030000DB80000061931001478401A04979DC217884C0BC7544D48EC7DC60883F87E8BF3E2D15150F3DFA6441F35AB922F971C4B873027D9CFE911F6009F94447ED55B3F08938E1754FEF
    0 395652 000000  4689319635000       45045000 1961D3DC 00000003460130000000094401C172438D63B240000000084E0101030421C080000000210201D00364FE43710980A640000003000003000003000003000003000003008F800000F12E02014782006C9FC86E2130C2540EDFCA668071F7B80899B026D98769EA762F0167B997855048D8FC5772F9E57EACD2F88A0AA061AD4299
    0 189691 000008  4689229545000       45045000 A31060FA 00000003460150000000094401C172438D63B240000000084E01010304304080000000160001E00D5677085E21308F800000030000030000DB80000064020001478401AACEE10BC4261ABC1C6F60E2E0C4A919B141F0003F313BB42F50B7BDB32A28C61BCB17E2AF256D40ACBFC0F950053803508B865EF38CA9382C495CA88C
    0 170481 000008  4689274590000       45045000 99ABA0B8 00000003460150000000094401C172438D63B240000000084E01010304404080000000170001E00D624BCEE10BC4268F800000030000030000DB80000062D20001478401AC4979DC217884C0D0CA181AB2A6BCFBCD36721798ACC22D6E675A9BF684B77594DCFC1CEB3E2013DE9F065DB40B8E1384414F382430B95BF6BB2D4F
    0 399729 000000  4689454770000       45045000 628DD50E 00000003460130000000094401C172438D63B240000000084E0101030451C080000000210201D0037CFE43710980A640000003000003000003000003000003000003008F800000F66E02014782006F9FC86E2130C25A0BBD4009456AC85CF118E79E1A18A6DBC6E2ED6272474BB6EC5F8AA6650C032A04C8A6DCB8D300D4D0D6
    0 169099 000008  4689364680000       45045000 89BC81BA 00000003460150000000094401C172438D63B240000000084E01010304604080000000160001E00DB677085E21308F800000030000030000DB80000062340001478401B6CEE10BC426C741E81AB2C88EDDD4EB0B48BFBD52683D983F111CD97D902E30FD34D1C4E638A730AB7AD7809C110A9B295092C14B0C6636C69CF5161A
    0 188569 000008  4689409725000       45045000 39EC5A76 00000003460150000000094401C172438D63B240000000084E01010304704080000000170001E00DC24BCEE10BC4268F800000030000030000DB80000062500001478401B84979DC217884C0C741E81AB098A383B69C7C4634FFDD19380CB96710145BFB57C2EE879A09941FBA624134B9903914AF1919EF5262E3C02B4D6174
    0 399434 000000  4689589905000       45045000 2E26E405 00000003460130000000094401C172438D63B240000000084E0101030481C080000000210201D00394FE43710980A640000003000003000003000003000003000003008F800000F86F0201478200729FC86E2130C2543C3CCAF59AF527751856E45FBD6861FC8FB9147DC89D62A07D4CE0F75361F8A1031B657DFEC342E08F05
    0 171273 000008  4689499815000       45045000 8565E36C 00000003460150000000094401C172438D63B240000000084E01010304904080000000160001E00E1677085E21308F800000030000030000DB80000065450001478401C2CEE10BC4261AC8875F69937C727021058B53740CC468D3C708457EA94FF90EAA157D66A72DFB2C8B7BAF84E6B16A2A926E578D3136A1916933F34CD6
    0 171075 000008  4689544860000       45045000 79D03A5F 00000003460150000000094401C172438D63B240000000084E01010304A04080000000170001E00E224BCEE10BC4268F800000030000030000DB80000064040001478401C44979DC217884C0C742609CEACA49F367C95E9966367BF2DC308CB6FD2B36A21B9EC6081971C28C850C0CBC2455CA5630C83ADB4012BB7D39020210
s=1 n=34 o=40263290880
    1   2748 002001  4689204480000       11520000 53C9AF6F 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44000000040000000400000004000000040000000707F7CDB0DB67E9CA0F7356C5AD6A525294A5294A50839CC6245EE63127314A5298E7325094A50841CC6349EE6B149318A4318E639D094A4E739CE62BDAB4A48310
    1   2768 002001  4689216000000       11520000 17EF7657 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000000000000400000004000000040000000132DB60124A0F7358B5A96A529294A5294A1283A0C62C9EE63148398C529CE73A0E942528418E62C9EF6B128314A4318C73A5294A528398E633D8B4986210884298
    1   2760 002001  4689227520000       11520000 8A672D4F 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000004000000000000000400000005A5DB64E0F7318B5AD4A4A52941D294A52839CE52C9EE63129398C529CC8421294A4E8418C634A0E6B148318A529CC73A1094A4E739CE62C1AB494A310C63318E74
    1   2760 002001  4689239040000       11520000 B05E8CCB 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000040000000400000004000000070A71C0C8CE0F7356B5A96A529274A1294A52739CE534DEE6B148394A529CE73A1284A509420C62C9EE6AD49318A5298C73A5094A12739CE62BD8B4986218863318
    1   2776 002001  4689250560000       11520000 05A44D57 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000400000004000000040000000400000004C176F5A85B90194A0F7356B5AD4A4A52949D294A527318C6349EE6B129394A6318E83A1294A52941CC6349EE6AD293984529CE739D294A52739CA62C18B4986218
    1   2752 002001  4689262080000       11520000 0053DAC0 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000040000000000000004000000010F70CCE0F7356B5AD4B529294A5094A52839CA51C9EE6AD49398C5318C7421084A4E841CE6349EE62D27318A4318C739D294A4E939CC62C18B4986210C65298E74
    1   2768 002001  4689273600000       11520000 94C397E9 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000004000000040000000400000005AA933DAAF81CE0F7356B5A96A52529425094A4E839CC634A0E6AD4941CE5294E63A4C94A52839CC6349EE72D49318A5318C74A1294A4E749CE533D8B4946310885
    1   2768 002001  4689285120000       11520000 A110D1CB 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000040000000400000004000000070CDB20154A0F7358C5AD4A525294A1294A52839CC52C9EE6312939CC6318C739D294A52939CE62C9EE6AD48398C6314E641D094A4E941CC72C18A4986210C65294
    1   2784 002001  4689296640000       11520000 5CCE8150 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000004000000040000000400000005A77047FB4CCCE0F7356B5A96A529294A5094A507398C52C9EE6B148498C6318E83A1094A508398C72C9EE6AD29398C531CE641D294A52841CC52C18B4984118884
    1   2764 002001  4689308160000       11520000 09D71A7F 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44000000040000000400000004000000040000000701DB670B5B65B64A2F7356B5AD6B52929425294A12939CC52C9EE6B129398C5314C749D294A4E8398C52C9ED62D29414C5298E64A1084A10739CE52C18A49C6210
    1   2760 002001  4689319680000       11520000 BBFE8250 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000004000000040000000400000001114CB000104CE0E7356B5A96B525284A12949D29418C62C9EE63148398C6318C73A5284A50939CC62C9EE62D49314C5318C73A1294A50931CC623D8B4986208CA4
    1   2748 002001  4689331200000       11520000 093689E7 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000000000004000000040000000400000004B54AEDAB7E9CA2F6B56B52D6952929421274A50839CC62CA0E63129398C6318C7425294A50941CC63460E62D49398A6318C7421094A52941CC533D8B49C4210C85
    1   2776 002001  4689342720000       11520000 5E0196FD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000004000000040000000400000004000000003A0CCF96802CA0F7356B5AD4A525284A5294A507320E5349EE6AD4831CE4314E74A1294A10939CA62C9EE62D2839CC6318E739D294A50741CC52BD8B4984110C84
    1   2732 002001  4689354240000       11520000 A5C44605 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000040000000400000001117044E2F6B56C5AD4A529294A1294A52739CC62CE0E6AD293A0A7318E73A1294A4E939CE72C9EE6B129418C6294E73A1094A52849CA63418A4184210C84314C73
    1   2756 002001  4689365760000       11520000 D3523955 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000400000000000000040000000400000005A0FE6015799CE0F7316B5A96A525293A5294A50739CC62C9EE63149318C5298C63A5294A12741CC6251EE6AD29398A5294E7425294A0E939CE62BD8A4984218864
    1   2744 002001  4689377280000       11520000 4D8532DE 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000004000000040000000400000004BE8DFF710CC4E0F7358B5AD4A5292949D294A4E739CE52C9EE62D29398C7318E73A5294A527420C72CA0E6AD4839CC6318C7425284A528318C52BD8A4984210884
    1   2756 002001  4689388800000       11520000 A2E5491D 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000040000000400000004000000040000000032816DB07B14E0F6B16B5AD4B525294A5284A4E939CE62CA0E62D29318C5298E73A1294A52939CE52C9EE6AD28398A5218E641D294A5283A0C633DAA3986210C84
    1   2720 002001  4689400320000       11520000 953309E0 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000004000000040000000400000001085AAF647924A0F7356B5AD4A529293A1294A5284A0C6249EE6AD29418C5294C7425294A52839CC62C60F6AD47398A5298E7425294A4E939CE533D8A49C4210C65
    1   2752 002001  4689411840000       11520000 7CA30BF1 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002000000040000000400000004000000052C4C60DA4CB4E0F7318B62D4A5A9294A5294A5083A0C62C9CE6B147398C6298C73A1094A52949CE6349ED63128298A5298E739D294A52831CE62BD8A4946210C65
    1   2780 002001  4689423360000       11520000 2B1DCD3B 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4400000000000000040000000400000004000000048DDAA77FF9ACA2F7356B5AD6B5A92939D294A4E7398C52CDEE6AD49318C529CE8421294A52731CE534A0D62D29398A5198E749D294A52839CC73418B4984210885
    1   2756 002001  4689434880000       11520000 A0304B83 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000400000004000000040000000400000007010CF90F90B5AB4E0F7356B5AD4A52929425094A509398E634A0E62D47398E6318C74A1094A52839CE62C9EE62D2731865318E7421094A12939CC53418B4946210
    1   2756 002001  4689446400000       11520000 AC86D0A8 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000004000000040000000000000007085B24E0F7356C5AD6B52929425294A52839CC62CDEE6314931CA5298C741D2949D2939CE634A0E6AD29394A6298E6421284A10939CC62BD8A4944110864298E73
    1   2760 002001  4689457920000       11520000 1335DBDE 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000004000000040000000400000007084E390E80ACE0F7358B5AD6B5A9494A5094A5083A0C62C9EE62D2839CC531CE83A5294A52831CC52C9EE62D29398A3318E739D094A52739CC72C18B3984210865
    1   2764 002001  4689469440000       11520000 D77D1903 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4400000004000000040000000400000004000000011077CDB0F7FFA94A2E7356B62D4A525494A4E94A50939CC62CA0E6AD49398C6298C8421294A50839CC62C5EE6B129494A5318A73A1294A528398C53418A4186210
    1   2768 002001  4689480960000       11520000 79C3DBA2 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000004000000040000000000000000000000012CF0CCA0F6B16B5AD6A529494A1294A52741CC62C9EE6312949CA5318E7425074A528398C62C9EE62D49418A5298E93A5094A1283A0E62C56A3944210C84298C73
    1   2764 002001  4689492480000       11520000 80184C4E 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000004000000040000000400000004000000000000C932000CE0F7356B5AD6B529494A5294A509418C52C5ED6B129418C5294E74A5294A508418C52C9EE6B129494A5294E7399294A12749CC62BD8B4984110C63
    1   2744 002001  4689504000000       11520000 86E70A6D 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000004000000040000000400000004C45B8003803CE2F7356C5AD6B5A9294A5294A50841CC634A0E62D29414C5294E8421294250639CE62CA0E6B148398A5314E63A5294A507418E52BD8A41C4110C65
    1   2744 002001  4689515520000       11520000 0DDC10AD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000004000000040000000400000005A9FE6DA5DB94A0F7358C5A96A52949425294A12939CC62C9EE63149318C5318C74A1294A52931CC62C9EE6B149318A4298E73A0E94A50841CE623D8A4984208C65
    1   2764 002001  4689527040000       11520000 322341D3 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000400000004000000040000000400000001090084C55B64CACA0F7358B5AD6A529294A5294A52939CC6349EE62D49318A6298E63A1294A508398A6349EE6AD48394A4298C7421294A4C9320C62C18A3986210
    1   2764 002001  4689538560000       11520000 C5719466 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000004000000040000000400000003FB7030107BECE0F7356B5A96A525493A5294A52739CE6349EE6AD4839CA5298E7425094A52839CC6249EE62D2839CA6298E749D094A529420C62BD8A4984210865
    1   2748 002001  4689550080000       11520000 9B8F9E62 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000004000000040000000400000004000000010D4C390E125CE2F7356B5A96A529494A5284A12741CC62CA0E6AD27398A6318C73A5294A4E9398C62C9EE63149318A531CE73A5274A12839CC62C18A4984108C63
    1   2752 002001  4689561600000       11520000 B2AE8AD7 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4400000004000000040000000400000004000000070CF07814DA5F684A0F7358B5AD6A525294A1094A5273A4E62C9EE62D48398C6318C741D294A529420C62C60E6AD49394A529CC741D094A52841CE62C18A4984210
    1   2752 002001  4689573120000       11520000 FD5BF82F 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000400000004000000040000000400000004CB4E402413801BC60E6B16A5294949D2731CE431CC6290A31C5CE72D4A52949320C5318E631CE5314631C5EF6AD495294931CC6318E731CC7310A3139AD62D294A
    1   2768 002001  4689584640000       11520000 23E80341 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000401000005010000000000000580000004C2177F00047977F0C047A0FC9EF6B16A5292A4A4C731CE639CC6314631C60F6B16A4A929314E631927318E6294A31C60F6AD6A4A528314E53192839CC5318A31C1
s=2 n=34 o=40263290880
    2   2012 002001  4689204480000       11520000 AE3E1FC7 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44000000040000000400000004000000040000000707F7CDB0DB67E9CA0F7356C5AD6A525294A5294A50839CC6245EE63127314A5298E7325094A50841CC6349EE6B149318A4318E639D094A4E739CE62BDAB4A48310
    2   2012 002001  4689216000000       11520000 BB45A08B 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000000000000400000004000000040000000132DB60124A0F7358B5A96A529294A5294A1283A0C62C9EE63148398C529CE73A0E942528418E62C9EF6B128314A4318C73A5294A528398E633D8B4986210884298
    2   2012 002001  4689227520000       11520000 D9CD0F72 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000004000000000000000400000005A5DB64E0F7318B5AD4A4A52941D294A52839CE52C9EE63129398C529CC8421294A4E8418C634A0E6B148318A529CC73A1094A4E739CE62C1AB494A310C63318E74
    2   2012 002001  4689239040000       11520000 67CB6D33 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000040000000400000004000000070A71C0C8CE0F7356B5A96A529274A1294A52739CE534DEE6B148394A529CE73A1284A509420C62C9EE6AD49318A5298C73A5094A12739CE62BD8B4986218863318
    2   2012 002001  4689250560000       11520000 F4C4ABC3 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000400000004000000040000000400000004C176F5A85B90194A0F7356B5AD4A4A52949D294A527318C6349EE6B129394A6318E83A1294A52941CC6349EE6AD293984529CE739D294A52739CA62C18B4986218
    2   2012 002001  4689262080000       11520000 910E420B 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000040000000000000004000000010F70CCE0F7356B5AD4B529294A5094A52839CA51C9EE6AD49398C5318C7421084A4E841CE6349EE62D27318A4318C739D294A4E939CC62C18B4986210C65298E74
    2   2012 002001  4689273600000       11520000 79D873C9 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000004000000040000000400000005AA933DAAF81CE0F7356B5A96A52529425094A4E839CC634A0E6AD4941CE5294E63A4C94A52839CC6349EE72D49318A5318C74A1294A4E749CE533D8B4946310885
    2   2012 002001  4689285120000       11520000 6078F008 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000040000000400000004000000070CDB20154A0F7358C5AD4A525294A1294A52839CC52C9EE6312939CC6318C739D294A52939CE62C9EE6AD48398C6314E641D094A4E941CC72C18A4986210C65294
    2   2012 002001  4689296640000       11520000 A8DE5AF9 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000004000000040000000400000005A77047FB4CCCE0F7356B5A96A529294A5094A507398C52C9EE6B148498C6318E83A1094A508398C72C9EE6AD29398C531CE641D294A52841CC52C18B4984118884
    2   2012 002001  4689308160000       11520000 207DA5AB 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44000000040000000400000004000000040000000701DB670B5B65B64A2F7356B5AD6B52929425294A12939CC52C9EE6B129398C5314C749D294A4E8398C52C9ED62D29414C5298E64A1084A10739CE52C18A49C6210
    2   2012 002001  4689319680000       11520000 AACE4A9D 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000004000000040000000400000001114CB000104CE0E7356B5A96B525284A12949D29418C62C9EE63148398C6318C73A5284A50939CC62C9EE62D49314C5318C73A1294A50931CC623D8B4986208CA4
    2   2012 002001  4689331200000       11520000 A03F8E40 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000000000004000000040000000400000004B54AEDAB7E9CA2F6B56B52D6952929421274A50839CC62CA0E63129398C6318C7425294A50941CC63460E62D49398A6318C7421094A52941CC533D8B49C4210C85
    2   2012 002001  4689342720000       11520000 B201FA34 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000004000000040000000400000004000000003A0CCF96802CA0F7356B5AD4A525284A5294A507320E5349EE6AD4831CE4314E74A1294A10939CA62C9EE62D2839CC6318E739D294A50741CC52BD8B4984110C84
    2   2012 002001  4689354240000       11520000 A7897AD8 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000040000000400000001117044E2F6B56C5AD4A529294A1294A52739CC62CE0E6AD293A0A7318E73A1294A4E939CE72C9EE6B129418C6294E73A1094A52849CA63418A4184210C84314C73
    2   2012 002001  4689365760000       11520000 45294343 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000400000000000000040000000400000005A0FE6015799CE0F7316B5A96A525293A5294A50739CC62C9EE63149318C5298C63A5294A12741CC6251EE6AD29398A5294E7425294A0E939CE62BD8A4984218864
    2   2012 002001  4689377280000       11520000 2F24077D 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000004000000040000000400000004BE8DFF710CC4E0F7358B5AD4A5292949D294A4E739CE52C9EE62D29398C7318E73A5294A527420C72CA0E6AD4839CC6318C7425284A528318C52BD8A4984210884
    2   2012 002001  4689388800000       11520000 EC1E94C3 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000040000000400000004000000040000000032816DB07B14E0F6B16B5AD4B525294A5284A4E939CE62CA0E62D29318C5298E73A1294A52939CE52C9EE6AD28398A5218E641D294A5283A0C633DAA3986210C84
    2   2012 002001  4689400320000       11520000 264FB051 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000004000000040000000400000001085AAF647924A0F7356B5AD4A529293A1294A5284A0C6249EE6AD29418C5294C7425294A52839CC62C60F6AD47398A5298E7425294A4E939CE533D8A49C4210C65
    2   2012 002001  4689411840000       11520000 AE5DD9C4 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002000000040000000400000004000000052C4C60DA4CB4E0F7318B62D4A5A9294A5294A5083A0C62C9CE6B147398C6298C73A1094A52949CE6349ED63128298A5298E739D294A52831CE62BD8A4946210C65
    2   2012 002001  4689423360000       11520000 68C1F7B3 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4400000000000000040000000400000004000000048DDAA77FF9ACA2F7356B5AD6B5A92939D294A4E7398C52CDEE6AD49318C529CE8421294A52731CE534A0D62D29398A5198E749D294A52839CC73418B4984210885
    2   2012 002001  4689434880000       11520000 4526BCAB 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000400000004000000040000000400000007010CF90F90B5AB4E0F7356B5AD4A52929425094A509398E634A0E62D47398E6318C74A1094A52839CE62C9EE62D2731865318E7421094A12939CC53418B4946210
    2   2012 002001  4689446400000       11520000 1DDA1909 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000004000000040000000000000007085B24E0F7356C5AD6B52929425294A52839CC62CDEE6314931CA5298C741D2949D2939CE634A0E6AD29394A6298E6421284A10939CC62BD8A4944110864298E73
    2   2012 002001  4689457920000       11520000 F19DD64B
mt=0x600001a1c000 n=11
    0 495362 000001  4689634950000       45045000 DAC5F549 000000034601100000002040010C01FFFF222000000300900000030000030099350300004E3400075300E8000002A1420101222000000300900000030000030099A001E020021C4D8D35924F841470F1C0903B0E18361A0842F081210088401006E1A306C341085CA0A021044170B02A0AC28035407080E007D02B4180A8200B
    1   2776 002001  4689596160000       11520000 6F7CE2B4 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000000000004000000000000000400000005A5F0C71049EF6B56B5A94A4A4E831D0749CE7318A324A106B1293A4E9298E7318E842106294A52CA0F63149420E9298E6398E949CE6318A41C1CE5A907218A7294
    2   2012 002001  4689596160000       11520000 0950926F 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000000000000004000000000000000400000005A5F0C71049EF6B56B5A94A4A4E831D0749CE7318A324A106B1293A4E9298E7318E842106294A52CA0F63149420E9298E6398E949CE6318A41C1CE5A907218A7294
    3    264 000000  4689210600000         900000 E1DBEADF 60841188601760436058607E1032275FD3AE8F0BEF3733A6B759D3D57FEFC3615A8E89D2789207D4C691CACFB9E21CBBADCAA58E50355E00F2CA24C81124532C3E26EEACB69B55C9BAD8FB575D46D48CC3E3462E6CA3B0AC4A44CA735E12B954972530E54CDB99D6A93D510E927B65B97293EA6448567657E4A73F6F776D45C7
    4   2560 002001  4689826560000       34560000 1BFE36C1 0B7701E92440E1FFFCC03E955E18618618ADFAA7D4DF3F536DFBE7EE9CEB54FABAEAD0DD3AA351EBEADBDD52A6D9F265D5960D74E946AE09C8BA4B0DD3DAF09FA4A6EA156A3BE13DD74DCC27CF6E3E7DE267EF9F53A53D2D37B0ABD774E6B3EA569F577349F5AAE95FBE4CE95427D4D4CE7D014D3235AD43AB6ABBF74FA73A7D
    5    262 000000  4689203400000         900000 79FFAE9B 60831048601860456058607D1866B499DA2038AC9EF9E7020DEC5F4A1096BE11E71FEE634BAEA5553BF7A40E54EDE4BEF286099113958540B200336E36BABFB37452B1E369A950AC8C8C17DA4C9772D5F8F921A0C525663B37763A0EB1738F8CC255C9F75F22B16D4B54F66A087398ECC3C947C52550DBBB4A2328723B4707CA
    6   2560 002001  4689826560000       34560000 E7BF999B 0B7701E92440E1FFFCC03E955E18618618ADFAA7D4DF3F536DFBE7EE9CEB54FABAEAD0DD3AA351EBEADBDD52A6D9F265D5960D74E946AE09C8BA4B0DD3DAF09FA4A6EA156A3BE13DD74DCC27CF6E3E7DE267EF9F53A53D2D37B0ABD774E6B3EA569F577349F5AAE95FBE4CE95427D4D4CE7D014D3235AD43AB6ABBF74FA73A7D
005003:0000 Titel 2 in Datei /Users/xxxx/Movies/MakeMKV/The Equalizer 3-FPL_MainFeature.mkv zu speichern schlug fehl
002023:0000 Encountered 43 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
error=0x06031105 count=43 name=SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
Encountered 37 unclassified errors
error=0x40000005 count=37 name=Posix-Fehler - Input/output error
005004:0080 0 Titel wurden gesichert, 1 schlugen fehl
005037:0204 Das Kopieren wurde abgeschlossen. 0 Titel wurden gesichert, 1 schlugen fehl.
MeyroNW
Post by MeyroNW » Mon Feb 19, 2024 8:39 am
I had to delete a number of (repetitive) lines since the system told me "too many characters".
Thanks for any help on further steps.
Post by Coopervid » Mon Feb 19, 2024 10:13 am
Clean the disc with liquid soap and warm water.
Make sure that your drive gets enough power via USB using an USB-C port or use an active USB hub.
MeyroNW
Post by MeyroNW » Mon Feb 19, 2024 7:04 pm
The disc is clean like a mirror (cleaned it again). Power is by active (power supported) USB hub. Still the same problem. At the end of the failed attempt to read, MakeMKV states "no disc".
One of the messages in the log, that repeats, is "Fehler 'Posix-Fehler - Input/output error' trat auf während des Auslesens von '/dev/rdisk4' bei Offset '40270166016'". So, Posix-error during reading...
Faulty disc?
Post by Coopervid » Mon Feb 19, 2024 7:29 pm
A questionable pressing. Most likely a Pioneer drive would read it.
Post by dcoke22 » Tue Feb 20, 2024 3:34 am
I agree with Coopervid.
The key is this line:
Those errors mean that the optical drive was unable to correctly read the disc.
MeyroNW
Post by MeyroNW » Tue Feb 20, 2024 10:37 am
Understood - mine is a Hitachi / LG reader.
Thanks for your comments!
