UHD discs decrypting
Re: UHD discs decrypting
#16 Post by Coopervid » Sun Feb 18, 2024 2:51 pm
macdev wrote: Sun Feb 18, 2024 2:07 pm Is KEYDB.cfg supposed to be in my .MakeMKV directory all the time? I don't have it, just _private_data.tar, some dump_***.tgz files, and MKB_***.tgz files.
Also, am I to understand that I have to buy another app to decrypt keys? DVDFab Passcode is $99 lifetime and I already spent $ on MakeMKV to do the job that I'd be paying DVDFab to do.
I'd really like to rip my Footloose disc, and with the James Cameron stuff coming in a couple of weeks, it would be nice to have those keys ready soon after their release, too.
Yes. It needs to be in that folder. Just extend the synchronize bat with what is posted above. No additional software needed. You just get the database with the keys.
Someguy1234
#17 Post by Someguy1234 » Mon Feb 19, 2024 1:24 am
Yeah, I'm confused here as well, as mentioned. Someone else told me they used AnyDVD with this method and MakeMKV and I'm clueless about what that they meant by that. Using other software with MakeMKV (like DVDFab for example) can be a bad idea, as they conflict and DVDFab (I'm serious) will brick a flashed UHD drive if you try to uninstall it and keep MakeMKV. I've had it happen to be me before and I'm extremely hesitant to ever use that software ever again. I damn sure am not about to dish out $100 for a license to a company that bricked a drive, and I wouldn't suggest anyone else to do so, either.
#18 Post by SamuriHL » Mon Feb 19, 2024 1:29 am
What, exactly, is "confusing" about using AnyDVD WITH MakeMKV? AnyDVD is a real time decryption program. Meaning, you decrypt it real time with AnyDVD, open MakeMKV, and WOA, it's not protected so MakeMKV works. The amount of nonsense I've read on this forum lately is staggering.
macdev
#19 Post by macdev » Mon Feb 19, 2024 1:44 am
SamuriHL wrote: Mon Feb 19, 2024 1:29 am What, exactly, is "confusing" about using AnyDVD WITH MakeMKV? AnyDVD is a real time decryption program. Meaning, you decrypt it real time with AnyDVD, open MakeMKV, and WOA, it's not protected so MakeMKV works. The amount of nonsense I've read on this forum lately is staggering.
Imagine for a second that you don't know what AnyDVD does, and someone is talking down to you because you've never used it, or never used it in this context.
Now re-read your post.
You also neglected to address the bricked drive which I've read AnyDVD does.
#20 Post by SamuriHL » Mon Feb 19, 2024 1:47 am
macdev wrote: Mon Feb 19, 2024 1:44 am
AnyDVD does not "brick drives". That's a complete bullshit claim.
polskasubie
#21 Post by polskasubie » Mon Feb 19, 2024 4:53 am
i've read that one user claimed anyDVD "bricked" their drive... i find that hard to believe without some proof...
makemkv is def my preferred software but when i run into a significant delay with say a disc like Footloose, i opened the disc with anyDVD and then rip with makemkv...
Cynary
#22 Post by Cynary » Sun Feb 25, 2024 7:40 am
Just to add to this conversation - and maybe someone can clarify what I'm doing wrong.
Recently got some disks that were new enough that their keys were not in either MakeMKV / keydb.cfg.
I used the FindVUK+DVDFab method to get the keys, and add them to the keydb.cfg file.
It seems as if MakeMKV just ignores that file, since it still gives me the volume key error. But when anyDVD is pointed to that keydb.cfg file (it was erroring before pointing to it) used to first decrypt the disk, MakeMKV can read it successfully.
So it seems like MakeMKV is either not looking at the keydb.cfg file, or FindVUK is generating some output that MakeMKV doesn't recognize, which for me necessitates going through anyDVD :/
ryley
#23 Post by ryley » Mon Feb 26, 2024 4:30 am
Cynary wrote: Sun Feb 25, 2024 7:40 am Just to add to this conversation - and maybe someone can clarify what I'm doing wrong.
When you use FindVUK in conjunction with that third-party decryption tool you will generally only get the unit key for your UHD discs. My recollection is that MakeMKV was only utilising keydb entries for UHD discs which contained all possible fields (media key, volume ID, volume unique key and unit key(s)).
This limitation in MakeMKV may have been an oversight, as the only absolute requirement is the unit key (which is why VLC can play UHD discs with just the unit key). It’s also possible that this may have changed in the latest version of MakeMKV, I think I last tested this with v1.17.5.
#24 Post by Coopervid » Mon Feb 26, 2024 11:08 am
Look at "View" "Preferences" " General" and make sure that "Makemkv data directory" points to C:\Users\"your USERNAME"\.Makemkv
Cynary
#25 Post by Cynary » Tue Feb 27, 2024 9:42 am
Coopervid wrote: Mon Feb 26, 2024 11:08 am
I appreciate the suggestion but tried that. I even tried moving the data dir and confirmed that it had the dump files and private date next to the key DB file. Most likely it's due to what the other reply mentioned:
Since indeed the find vuk entry did not have all the fields.
For now it works with any DVD so it's not a big issue, just would be nice if I could just use makemkv alone
kwinders2
#26 Post by kwinders2 » Fri Mar 01, 2024 2:01 pm
Coopervid wrote: Mon Dec 25, 2023 1:07 pm Since that location is the standard and eventually used by VLC I just added a line to the FindVUK-Synchronize.bat. So it looks like this:
findvuk.exe synchronize
copy /Y C:\Users\USERNAME\AppData\Roaming\aacs\keydb.cfg c:\users\USERNAME\.Makemkv\keydb.cfg
Just replace USERNAME with your real one.
Worked Great, thank you
The /Y after "copy" prevents the command from asking for confirmation to overwrite the old version.
Cannikin
#27 Post by Cannikin » Fri Mar 01, 2024 5:48 pm
I rip all my stuff with MakeMKV on a Mac, but do have access to a PC. I downloaded FindVUK and ran the .bat file, but I just get an error:
I thought this tool was just downloading keys from somewhere, but maybe not? Do I need the drive connected? Do I need the disc in the drive? Do I need some other software running?
Edit
Just discovered AnyDVD for the PC and it's working! I'd still love not to have to run that, if I could get FindVUK working...
#28 Post by Coopervid » Fri Mar 01, 2024 6:03 pm
You ran the wrong .bat. You are supposed to run the synchronize .bat not AACSkeys.
Cannikin
#29 Post by Cannikin » Fri Mar 01, 2024 6:13 pm
Coopervid wrote: Fri Mar 01, 2024 6:03 pm You ran the wrong .bat. You are supposed to run the synchronize .bat not AACSkeys.
🤦‍♂️ Thanks so much!
Holy crap that **Fancy Icons** is huge.
jtscribe
#30 Post by jtscribe » Thu Mar 14, 2024 3:11 am
Hmm. Well, shoot. Downloaded the keycfg, moved it into the MakeMKV folder in my user profile, and still no joy trying to open True Lies. My hash seems to be different than everyone else; maybe I got a different version?
