hkdata.crabdance.comCode: Select all
185.84.108.20Code: Select all
Let's Encrypt!Doing:
curl -k -s --resolve 'hkdata.crabdance.com:443:185.84.108.20' https://hkdata.crabdance.com/svq/sdf.dat.gzCode: Select all
Let's Encrypt!Code: Select all
$ dig @ns1.afraid.org. hkdata.crabdance.com
; <<>> DiG 9.19.21 <<>> @ns1.afraid.org. hkdata.crabdance.com
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 24950
cool bro. whats the new url so i can whitelist it and actually stand a slim chance of getting this thing to work?Billycar11 wrote: Sat Feb 17, 2024 6:08 am guys the url is always changing look i just had it work...
so its not down the conspiracy theories really need to stop
These are both older 4K discs that shouldn't really require anyone on the latest version 1.17.6 to even have to access the latest HK. In fact, how did you make it download the latest SDF? We need to know this. It could help us try to rip discs that have dump files we've submitted.GunerX wrote: Sat Feb 17, 2024 3:03 pmcool bro. whats the new url so i can whitelist it and actually stand a slim chance of getting this thing to work?Billycar11 wrote: Sat Feb 17, 2024 6:08 am guys the url is always changing look i just had it work...
you just delete privatedata.tar but this is not recommended unless your really having issues and are using it to troubleshoot.Someguy1234 wrote: Sun Feb 18, 2024 4:55 am
That's a bit alarming that there's not been an update in 11 days as of today. Thanks for the feedback though. At least I know the server is working.Billycar11 wrote: Sun Feb 18, 2024 5:37 amyou just delete privatedata.tar but this is not recommended unless your really having issues and are using it to troubleshoot.Someguy1234 wrote: Sun Feb 18, 2024 4:55 am
i wasn't saying they are new discs i was just showing the key server is not down as above people were saying makemkv key server was down and they are asking me to wire shark the url for them its hidden for a reason so not posting it.
currently there has not been a key update since 2/7 i believe i test drives everyday so just over a week.
Its pretty normal for it to be 2 weeksSomeguy1234 wrote: Sun Feb 18, 2024 5:57 amThat's a bit alarming that there's not been an update in 11 days as of today. Thanks for the feedback though. At least I know the server is working.Billycar11 wrote: Sun Feb 18, 2024 5:37 amyou just delete privatedata.tar but this is not recommended unless your really having issues and are using it to troubleshoot.Someguy1234 wrote: Sun Feb 18, 2024 4:55 am
HK was updated today now so all can try the new discs they were likely addedSomeguy1234 wrote: Sun Feb 18, 2024 5:57 am
Yes. It's working now. I had to use a VPN though to access the HK server.Billycar11 wrote: Mon Feb 19, 2024 1:50 amHK was updated today now so all can try the new discs they were likely addedSomeguy1234 wrote: Sun Feb 18, 2024 5:57 am
