Planet Earth III 4K - Dump Files Submitted
Necronar
Post by Necronar »
I've submitted 3 dump files (3 discs) for Planet Earth III 4K, released on Feb. 13th, 2024.
MKB20_v77_Planet_Earth_III_-_Disc_1_1058.tgz
MKB20_v77_Planet_Earth_III_-_Disc_2_B366.tgz
MKB20_v77_Planet_Earth_III_-_Disc_1_6DF8.tgz
Looks like the disc 3 is labeled incorrectly by the manufacturer? *_Disc_1_6DF8.tgz is actually disc 3. I've just double-checked and confirmed.
cobaltberry
Re: Planet Earth III 4K - Dump Files Submitted
Post by cobaltberry »
Just to confirm, my copy also incorrectly labels disk 3 as an additional disk 1.
Crabilouse
Post by Crabilouse »
Giffdev
Post by Giffdev »
submitted mine as well, though my disk 3 also is labeled as disk 1
ibumpthis
Post by ibumpthis »
Submitted mine also, and noted in the submission email that Disc 3 is labeled Disc 1 but with a different four letter code.
Thanks for all the MakeMKV team does!
MKB20_v77_Planet_Earth_III_-_Disc_1_6DF8.tgz (Actually Disc 3, mislabeled by the manufacturer as Disc 1 round 2)
Giffdev
Post by Giffdev »
Tried again around 9am PST today, still no joy but I'll be patient :)
BBergle
Post by BBergle »
Also submitted mine, and once again I had a disk1 filename for the disk3 dump
androgenix
Post by androgenix »
Submitted mine as Disk 3 is correctly labeled - same 4 letter codes though
Planet_Earth_III_-_Disc_3_6DF8.tgz
nacellex
Post by nacellex »
Take a look at this, someone had success ripping Planet Earth III using this method:
viewtopic.php?f=12&t=32784
I stumbled across this thread while I was preparing to rip Planet Earth III when my drive arrives. Hope it helps!
salticus
Post by salticus »
nacellex wrote:
Sat Feb 17, 2024 2:13 pm
I tried following the instructions from that thread. While I could not download FindVUK for some reason, I did manage to find a copy of the latest output.
Google "FindVUK Online Database", download the keydb and extract the contents to C:\Users\<USERNAME>\.MakeMKV.
Can confirm Planet Earth III is ripping right now. Thanks for the tip!
Giffdev
Post by Giffdev »
I might try that method if this isn't updated and working in a day or two :)
bw171291
Post by bw171291 »
I just downloaded that keydb from the FindVUK Online Database, and the first disk is now ripping.
BBergle
Post by BBergle »
salticus wrote:
Sat Feb 17, 2024 5:17 pm
Thank you, this worked!
Giffdev
Post by Giffdev »
I just waited it out and now plain old vanilla MakeMKV is able to open disk 1. backing mine up now :)
ibumpthis
Post by ibumpthis »
Can confirm that UHD discs are backing up beautifully without any workarounds. Thanks as always to the MakeMKV team.
