Planet Earth III 4K - Dump Files Submitted
I've submitted 3 dump files (3 discs) for Planet Earth III 4K, released on Feb. 13th, 2024.
MKB20_v77_Planet_Earth_III_-_Disc_1_1058.tgz
MKB20_v77_Planet_Earth_III_-_Disc_2_B366.tgz
MKB20_v77_Planet_Earth_III_-_Disc_1_6DF8.tgz
Looks like the disc 3 is labeled incorrectly by the manufacturer? *_Disc_1_6DF8.tgz is actually disc 3. I've just double-checked and confirmed.
cobaltberry
Re: Planet Earth III 4K - Dump Files Submitted
Just to confirm, my copy also incorrectly labels disk 3 as an additional disk 1.
Crabilouse
submitted mine as well, though my disk 3 also is labeled as disk 1
Submitted mine also, and noted in the submission email that Disc 3 is labeled Disc 1 but with a different four letter code.
Thanks for all the MakeMKV team does!
MKB20_v77_Planet_Earth_III_-_Disc_1_6DF8.tgz (Actually Disc 3, mislabeled by the manufacturer as Disc 1 round 2)
Tried again around 9am PST today, still no joy but I'll be patient
Also submitted mine, and once again I had a disk1 filename for the disk3 dump
androgenix
Submitted mine as Disk 3 is correctly labeled - same 4 letter codes though
Planet_Earth_III_-_Disc_3_6DF8.tgz
Take a look at this, someone had success ripping Planet Earth III using this method:
viewtopic.php?f=12&t=32784
I stumbled across this thread while I was preparing to rip Planet Earth III when my drive arrives. Hope it helps!
I tried following the instructions from that thread. While I could not download FindVUK for some reason, I did manage to find a copy of the latest output.nacellex wrote: ↑Sat Feb 17, 2024 2:13 pmTake a look at this, someone had success ripping Planet Earth III using this method:
Google "FindVUK Online Database", download the keydb and extract the contents to C:\Users\<USERNAME>\.MakeMKV.
Can confirm Planet Earth III is ripping right now. Thanks for the tip!
I might try that method if this isn't updated and working in a day or two
I just downloaded that keydb from the FindVUK Online Database, and the first disk is now ripping.
Thank you, this worked!salticus wrote: ↑Sat Feb 17, 2024 5:17 pmI tried following the instructions from that thread. While I could not download FindVUK for some reason, I did manage to find a copy of the latest output.nacellex wrote: ↑Sat Feb 17, 2024 2:13 pmTake a look at this, someone had success ripping Planet Earth III using this method:
I just waited it out and now plain old vanilla MakeMKV is able to open disk 1. backing mine up now
Can confirm that UHD discs are backing up beautifully without any workarounds. Thanks as always to the MakeMKV team.
