Automatic HK download disabled or failed
demon
Re: Automatic HK download disabled or failed
#61 Post by demon » Tue Feb 06, 2024 11:48 pm
I'm not able to look
hkdata.crabdance.com
up via any DNS server at all. Also, when I try to connect directly to
, it returns a
Let's Encrypt!
certificate that has been expired since 15 Sep 2023.
Doing:
curl -k -s --resolve 'hkdata.crabdance.com:443:185.84.108.20' https://hkdata.crabdance.com/svq/sdf.dat.gz
does work for me, though.
Someguy1234
#62 Post by Someguy1234 » Thu Feb 15, 2024 8:33 am
I'm not seeing ANY new UHD titles getting keys and even trying to connect to the server. This is what is starting to worry me. I rely on this software for actual purposes, not just for entertainment. This could honestly hurt a lot of people if things aren't working correctly anymore, even when behind a VPN
#63 Post by Billycar11 » Thu Feb 15, 2024 10:54 am
the latest hk update was about a week ago i dont think its time to be worried
and HKs have been downloading fine for me no issues contacting the server
GunerX
#64 Post by GunerX » Fri Feb 16, 2024 10:36 pm
so I think its time we admit theres something wrong.
I can rename my private_data file and the program will try to download a new one, it will connect, it will start downloading, it will get to about 400kb, then stop with the error "automatic downloading failed or is disabled" which it isnt. it is definetly able to connect, its able to download, but something then stops it.
for the record I have made certain I can connect to the server, I even have a vpn that I tried and I can still connect, but again have the exact same issue.
Anyone else?
*edit*
checking Is It Down Right Now will show that it is, infact, down. and likely has been for a while now
jemima
#65 Post by jemima » Sat Feb 17, 2024 5:44 am
Yes, the subdomain hkdata of crabdance.com is gone, even when querying the authoritative NS for crabdance.com:
$ dig @ns1.afraid.org. hkdata.crabdance.com
; <<>> DiG 9.19.21 <<>> @ns1.afraid.org. hkdata.crabdance.com
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 24950
#66 Post by Billycar11 » Sat Feb 17, 2024 6:08 am
guys the url is always changing look i just had it work...
so its not down the conspiracy theories really need to stop
GunerX
#67 Post by GunerX » Sat Feb 17, 2024 3:03 pm
Billycar11 wrote: Sat Feb 17, 2024 6:08 am guys the url is always changing look i just had it work...
cool bro. whats the new url so i can whitelist it and actually stand a slim chance of getting this thing to work?
Someguy1234
#68 Post by Someguy1234 » Sun Feb 18, 2024 4:55 am
GunerX wrote: Sat Feb 17, 2024 3:03 pm
These are both older 4K discs that shouldn't really require anyone on the latest version 1.17.6 to even have to access the latest HK. In fact, how did you make it download the latest SDF? We need to know this. It could help us try to rip discs that have dump files we've submitted.
#69 Post by Billycar11 » Sun Feb 18, 2024 5:37 am
Someguy1234 wrote: Sun Feb 18, 2024 4:55 am
you just delete privatedata.tar but this is not recommended unless your really having issues and are using it to troubleshoot.
i wasn't saying they are new discs i was just showing the key server is not down as above people were saying makemkv key server was down and they are asking me to wire shark the url for them its hidden for a reason so not posting it.
currently there has not been a key update since 2/7 i believe i test drives everyday so just over a week.
Someguy1234
#70 Post by Someguy1234 » Sun Feb 18, 2024 5:57 am
Billycar11 wrote: Sun Feb 18, 2024 5:37 am
That's a bit alarming that there's not been an update in 11 days as of today. Thanks for the feedback though. At least I know the server is working.
#71 Post by Billycar11 » Sun Feb 18, 2024 6:56 am
Someguy1234 wrote: Sun Feb 18, 2024 5:57 am
Its pretty normal for it to be 2 weeks
GunerX
#72 Post by GunerX » Sun Feb 18, 2024 3:14 pm
1: It isnt working.
2: You still havnt provided the new urls that need to be whitelisted.
3: I previously posted the EXACT problem and you completely ignored it.
The SDF works, the HK does not. These are 2 totally separate things that then combine into 1 file. For the record, once again, this is the link to the SDF file: https://www.makemkv.com/svq/sdf.bin
If you click this link and it downloads something, take that file and put it into your C:\Users\[Your User Name Here]\.MakeMKV\ folder, rename your _private_data.tar to something like _private_data-old.tar. Open MakeMKV, watch as it unpacks the SDF into a brand new _private_data.tar file. Then try to open one of your new movies, it will then try to download a new HK file, and I promise you, it wont do it correctly. Once again, for those of you that refuse to listen, the OLD HK file is around 5,400 KB, the NEW one that is failing to properly download is around 400kb, so the final file size of your combined NEW _private_data.tar file will sit at between 2000 kb to 2400 kb. THIS IS WRONG. Get it through your heads. Old file big. New File Small. You can even extract the .tar file with 7zip and look inside to SEE that the new one has less content than the old one. There is something wrong with the current HK.
macdev
#73 Post by macdev » Sun Feb 18, 2024 3:58 pm
Nothing's working for me either.
If I don't use a VPN, I can't resolve the name.
If I use the IP address directly without VPN, I get a 403 error.
If I use a VPN, I get a 502 error, either with the IP address or the domain.
So for anyone that is getting it to work, please let us know how.
#74 Post by Billycar11 » Mon Feb 19, 2024 1:50 am
HK was updated today now so all can try the new discs they were likely added
Someguy1234
#75 Post by Someguy1234 » Mon Feb 19, 2024 1:56 am
Billycar11 wrote: Mon Feb 19, 2024 1:50 am
Yes. It's working now. I had to use a VPN though to access the HK server.
