UHD discs decrypting
Post by Coopervid » Sun Dec 24, 2023 10:57 pm
If your discs aren't supported you can try this.
Download FindVUK 1.79. (Updated September, 5th, 2024)
https://forum.doom9.org/showthread.php?t=172472
Put it somewhere.
Run FindVUK - Synchronize.bat
It will write a file keydb.cfg to C:\users\USERNAME\Appdata\Roamimg\AACS
Make a copy of this file and copy to:
C:\users\USERNAME\.Makemkv
Put your disc in the drive.
Run Makemkv.
Then run the Synchronize.bat from time to time in order to get new UHD keys. Replace the updated one and copy to the .Makemkv folder.
Re: UHD discs decrypting
Post by Billycar11 » Mon Dec 25, 2023 2:55 am
i wonder if we can sym link it
Post by SamuriHL » Mon Dec 25, 2023 3:41 am
Or, you know, do what I do and just change FindVUK to drop it in the .MakeMKV folder so when it's sync'd with FindVUK it updates the one MakeMKV uses. Look in the findvuk.ini file in the config folder.
Post by Coopervid » Mon Dec 25, 2023 1:07 pm
Since that location is the standard and eventually used by VLC I just added a line to the FindVUK-Synchronize.bat. So it looks like this:
findvuk.exe synchronize
copy /Y C:\Users\USERNAME\AppData\Roaming\aacs\keydb.cfg c:\users\USERNAME\.Makemkv\KEYDB.cfg
Just replace USERNAME with your real one.
The /Y after "copy" prevents the command from asking for confirmation to overwrite the old version.
EDIT: NOTE THE UPPERCASE of KEYDB.cfg WHEN COPIED TO THE .MAKEMKV DIRECTORY!
Post by d00zah » Mon Dec 25, 2023 2:28 pm
copy /Y C:\Users\USERNAME\AppData\Roaming\aacs\keydb.cfg c:\users\USERNAME\.Makemkv\keydb.cfg
OR, to make it completely generic (use as is):
copy /Y %UserProfile%\AppData\Roaming\aacs\keydb.cfg %UserProfile%\.Makemkv\keydb.cfg
dorsman84
Post by dorsman84 » Fri Feb 16, 2024 1:45 am
I tried this tonight after not being able to rip The Thing UHD but still no luck. I guess I will wait for an update.
Toker
Post by Toker » Fri Feb 16, 2024 3:06 pm
Thanks for this code. I was trying to rip Planet Earth III and the keys weren't available yet, so I gave this a try and it's now ripping.
Newbie question. In the future, do I have to run the batch file again in the event that I find a new disc that hasn't been decrypted yet?
Post by Coopervid » Fri Feb 16, 2024 4:07 pm
Yes. New keys are being added daily. So just run the .bat from time to time.
Toker
Post by Toker » Fri Feb 16, 2024 5:13 pm
nacellex
Post by nacellex » Sat Feb 17, 2024 2:09 pm
Download FindVUK 1.72.
Put it somewhere.
Run Makemkv.
Hi Coopervid thanks so much for this. Just a noob clarification before I take the plunge: I was reading the original thread on doom9, and since this program used to use DVDFab to work, does it require us to download DVDfab for us to run Synchronize.bat?
Thanks again!
Post by Coopervid » Sat Feb 17, 2024 6:02 pm
No. DVDFab is only needed to add new keys.
Someguy1234
Post by Someguy1234 » Sun Feb 18, 2024 2:15 am
Put it somewhere.
Run Makemkv.
I couldn't get the version in the link to download and found the v1.72 elsewhere. I can't get this to work, even after using someone's suggestion of adding a line to the batch file. It put the keydb.cfg in the /.Makemkv folder but all of the discs I've been inserting are still creating dump files and failing. I'm a bit confused how this is working for some?
Hurin
Post by Hurin » Sun Feb 18, 2024 2:23 am
I too have placed the keydb.cfg file in the .MakeMKV directory as instructed. No change in behavior while trying to decrypt Oppenheimer. Which, appears to be a newer version than previous (0C38). *shrug*
Post by Coopervid » Sun Feb 18, 2024 10:51 am
It should work. Also the download link still works.
Did you search through keydb.cfg for keys for your discs if there are any for your discs?
macdev
Post by macdev » Sun Feb 18, 2024 2:07 pm
Is KEYDB.cfg supposed to be in my .MakeMKV directory all the time? I don't have it, just _private_data.tar, some dump_***.tgz files, and MKB_***.tgz files.
Also, am I to understand that I have to buy another app to decrypt keys? DVDFab Passcode is $99 lifetime and I already spent $ on MakeMKV to do the job that I'd be paying DVDFab to do.
I'd really like to rip my Footloose disc, and with the James Cameron stuff coming in a couple of weeks, it would be nice to have those keys ready soon after their release, too.
