ASUS BW-16D1H-U Pro , Wrong Flasht .
yezzeyaner
Post by yezzeyaner »
Hello
I have the following problem I have by my stupidity my ASUS BW-16D1H-U Pro flasht and the wrong, by the bottles thinks the drive is now a LG . although I have a backup dump_user_ASUS_BW-16D1H-U_A204_211901041044_KLCJ6O83121 but he does not take , Now I need help .
Unfortunately I have to take Goolge translator I hope you understand it .
Re: ASUS BW-16D1H-U Pro , Wrong Flasht .
who cares if its an LG if it a WH16NS60 its better off now the asus is just an lg any way if you didnt know its just a rebrand
if its a BU40N well that would need to be fixed what your makemkv drive info section look like?
yezzeyaner
Sorry I don't understand it, I always get the ERROR 0xff05c103 under hosts, no matter what I use. Can I reset this flash back to factory setting . Please help
yezzeyaner
Here is a screenshot of the drive
yezzeyaner wrote:
Fri Feb 16, 2024 2:01 pm
Use imgur or similar for a pic and link it
yezzeyaner
Billycar11 wrote:
Fri Feb 16, 2024 2:22 pm
screenshot https://ibb.co/6vc5x6d
You flashed a slim drive firmware to a full size drive.
You need to do the RECOVERY procedure and pick first the wrong firmware you had flashed and then the correct firmware of a full size drive.
viewtopic.php?f=16&t=22896
yezzeyaner
Coopervid wrote:
Fri Feb 16, 2024 6:45 pm
I don't understand what I have to do now because unfortunately I don't understand English and use Google for it,
Did you watch the movie in the link?
yezzeyaner
Coopervid wrote:
Fri Feb 16, 2024 8:29 pm
yes , but it doesn't work ixh always get errors
Set the recovery option. You need to choose the identical firmware you have flashed before. Then pick a firmware for a full size drive like BH16NS60 1.02 in the second window. Uncheck "enc". Click start.
If it still won't work send me a PM. Your screenshot is in German and I can help you in your language.
yezzeyaner
Coopervid wrote:
Fri Feb 16, 2024 8:38 pm
Screenshot . https://ibb.co/X2vw5MQ
No, no, no. You need to choose RECOVER DRIVE not write firmware. Then select the firmware first you flashed to the drive. In the second option choose now BH16NS60 1.02 and make sure that "enc" is unchecked.
yezzeyaner
Solved, I forgot something bad or I did NOT notice it, if you have selected your drive at the top of the TOOL you have to select RECOVER and the firmware at the bottom but 2 <---- times once the FIRST version you took and the second firmware you want to put on it !!!
