Love to see chapters start 1 instead of 0
MrTeagan
#1 Post by MrTeagan » Sun Jul 31, 2011 5:57 am
Anyway you guys could give us the option of having chapters to start at 1 instead of 0?
Director
Re: Love to see chapters start 1 instead of 0
#2 Post by Woodstock » Wed Aug 03, 2011 9:57 pm
Chapter numbers or track numbers? All my rips show chapter numbers starting at 1.
MrTeagan
#3 Post by MrTeagan » Wed Aug 03, 2011 10:24 pm
When I rip using makemkv, my chapters are labeled beginning "Chapter 00" then next Chapter 01.
Director
Smithcraft
#4 Post by Smithcraft » Thu Aug 04, 2011 8:12 pm
I believe you mean titles, not chapters.
SC
MrTeagan
#5 Post by MrTeagan » Thu Aug 04, 2011 8:17 pm
No, I mean chapters. Not titles. If I rip one title, the chapter stops when read on Subler etc or on the playback device start as labeled Chapter 00 and it should start at 01.
Director
Romansh
#6 Post by Romansh » Thu Aug 04, 2011 9:44 pm
Files created with MakeMKV 1.6.12 have the chapter titles start with "Chapter 01" for me.
#7 Post by mike admin » Sat Aug 06, 2011 8:40 am
This is a bit complex and ugly. Chapters start with 00, but if the first chapter is too close (less than 1 second) to the second, then the "0" chapter is deleted. This is the case for 99% discs. Sometimes, for discs that don't have the real "first" chapter MakeMKV keeps the "0" chapter. Iwould only suggest to rename chapters manually for such discs.
bw001
#8 Post by bw001 » Fri Aug 12, 2011 6:44 pm
I was doing some searching for this problem and ran across a couple of threads.
All of the Blu-ray rips that I checked (about a dozen) display Chapter 00 for the first chapter.
The DVD rips that I checked display Chapter 01 for the first chapter.
It also looks like this was brought up before: http://www.makemkv.com/forum2/viewtopic.php?f=1&t=215
I could check more but it seems that all blu-ray's are displaying Chapter 00 for the chapter beginning at 00:00:00.000
Is it possible to increment the chapter number for display when creating the MKV?
Example Blu-ray (from text display mode in MediaInfo):
Menu
00:00:00.000 : en:Chapter 00 <<---
00:03:57.779 : en:Chapter 01
00:07:05.425 : en:Chapter 02
00:09:19.183 : en:Chapter 03
00:13:34.146 : en:Chapter 04
00:14:22.319 : en:Chapter 05
paulster
#9 Post by paulster » Sat Aug 20, 2011 6:59 pm
Every one of the dozen or so BluRays I've ripped so far to test has begun Chapter 00 whereas every DVD has correctly begun Chapter 01.
I'd really like this fixed as it's a pain to have to edit every single chapter name after ripping.
bw001
#10 Post by bw001 » Sat Sep 03, 2011 3:15 pm
paulster wrote:Every one of the dozen or so BluRays I've ripped so far to test has begun Chapter 00 whereas every DVD has correctly begun Chapter 01.
What do you use to edit the chapter names?
paulster
#11 Post by paulster » Sat Sep 03, 2011 6:52 pm
bw001 wrote:What do you use to edit the chapter names?
MKVtoolnix.
Since I wrote this I've actually found a couple of DVDs where the chapter names have ended up starting from 0 as well!
bw001
#12 Post by bw001 » Wed Apr 11, 2012 6:46 pm
mike admin wrote:This is a bit complex and ugly. Chapters start with 00, but if the first chapter is too close (less than 1 second) to the second, then the "0" chapter is deleted. This is the case for 99% discs. Sometimes, for discs that don't have the real "first" chapter MakeMKV keeps the "0" chapter. Iwould only suggest to rename chapters manually for such discs.
I see this is still doing this. So far 100% of my blu-ray disks are starting with 00 instead of 01, so it doesn't seem like the "0" chapter is deleted in 99% of cases.
paulster
#13 Post by paulster » Wed Apr 11, 2012 7:18 pm
+1. I've ripped about 50 Blu-rays lately and, without fail, they've started at Chapter 00.
DVDs, on the other hand, just work.
ryanjk333
#14 Post by ryanjk333 » Wed Apr 11, 2012 9:40 pm
+1....Blu rays all start at 00 for me too. It's strange to see because I play my MKVs on a Popcorn Hour, which temporarily displays the chapter number on the screen when I manually skip to a different chapter in a movie, and this display and what the MKV says the chapter is is always off by one. The MKV starts at 00 and my Popcorn Hour starts at 01 (as it should). So on my TV, the display says something like "01: Chapter 00".
MakeMKV registered!
LG External 12x Super Multi Blue Lightscribe Blu-Ray Rewriter BE12LU30
Popcorn Hour C-200
woody777
#15 Post by woody777 » Wed Jun 20, 2012 4:44 pm
ryanjk333 wrote:+1....Blu rays all start at 00 for me too. It's strange to see because I play my MKVs on a Popcorn Hour, which temporarily displays the chapter number on the screen when I manually skip to a different chapter in a movie, and this display and what the MKV says the chapter is is always off by one. The MKV starts at 00 and my Popcorn Hour starts at 01 (as it should). So on my TV, the display says something like "01: Chapter 00".
I have the exact same issue with every one of my rips... MPC-HC reports chapter 1/0, 2/1, 3/2, etc. The MKV is always off by one compared to the original disc.
