Application failed to initialize
bill6996
#1 Post by bill6996 » Thu Aug 04, 2011 1:33 am
So, what am I doing wrong. I've uninstalled, restarted, reinstalled. Still same thing. Vista OS. Plenty of HDD space, RAM. Any help? Please?
twa000
Re: Application failed to initialize
#2 Post by twa000 » Thu Aug 04, 2011 9:22 am
1) what version are you running?
2) does taskmgr (alt-ctrl-del) show anything started?
bill6996
#3 Post by bill6996 » Thu Aug 04, 2011 2:46 pm
Newest version. Just downloaded. Didn't look in task manager.
handsofjade
#4 Post by handsofjade » Fri Aug 05, 2011 5:12 pm
Getting the same problem. Happened after installing the latest version. Has worked perfectly fine up until now.
#5 Post by mike admin » Sat Aug 06, 2011 8:37 am
Are you talking about 1.6.12 or 1.6.13 ?
Sluft
#6 Post by Sluft » Sat Aug 06, 2011 9:46 am
Me2. On MacBook Air i7 Lion failed, on MacBook Pro Snow Leopard works. Both 1.6.13
#7 Post by mike admin » Mon Aug 08, 2011 9:14 am
Please try the following:
1. Reboot computer
2. Reinstall latest MakeMKV
Launch MakeMKV and see if it fails again.
Sluft
#8 Post by Sluft » Mon Aug 08, 2011 9:54 am
It falis again. The previous version works fine before I installed 1.6.13. If i use AppCleaner to remove the latest version, empty trash and reinstall a previous version, I get the same error.
tourmaline
#9 Post by tourmaline » Mon Aug 08, 2011 6:18 pm
Same thing with me, wanted to buy eventually but now have to reconsider!
Tried everything but everytime my system hangs when starting makemkv...if i uninstall en delete all registery entries, then my system works like a charm!
MUST be makemkv 1.6.13...
Good thing i encounter these problems now while in beta, now i have to reconsider if makemkv is such a good product after all. I spent some days trying to make it work...It is a nice product when it works, but now wasted 3 days trying to make it work... :cry:
#10 Post by mike admin » Tue Aug 09, 2011 1:16 pm
tourmaline wrote:Same thing with me, wanted to buy eventually but now have to reconsider!
Sorry about that. Normally MakeMKV works better than that. If you can, please do this as other poster did - http://www.makemkv.com/onlinehelp/dump.html
snakyjake
#11 Post by snakyjake » Thu Aug 11, 2011 6:39 am
Same here.
Windows 7 x64
MakeMKV v1.6.13
Mortikai
#12 Post by Mortikai » Thu Aug 11, 2011 5:24 pm
I am having the same issues since the upgrade. Previous version worked perfectly. Now i can get the application to load, but when i click on open, it hangs. Sometimes i can cntrl alt delete and the open file screen will pop up, but then when i click a file to open it hangs again. i was able to get it to run a few times, but for the most part it has been extremely slow and randomly hangs.
#13 Post by mike admin » Sat Aug 13, 2011 2:26 pm
Sluft wrote:It falis again. The previous version works fine before I installed 1.6.13. If i use AppCleaner to remove the latest version, empty trash and reinstall a previous version, I get the same error.
Thanks for the report, this is a bug in 1.6.13 and will be corrected soon. Please see the next message about application data directory for possible workaround.
#14 Post by mike admin » Sat Aug 13, 2011 2:28 pm
Mortikai wrote:I am having the same issues since the upgrade. Previous version worked perfectly. Now i can get the application to load, but when i click on open, it hangs. Sometimes i can cntrl alt delete and the open file screen will pop up, but then when i click a file to open it hangs again. i was able to get it to run a few times, but for the most part it has been extremely slow and randomly hangs.
Please launch MakeMKV, go to preferences, (last) "General" tab. What is the value of "application data directory" and can you change it?
