7-1 would be a waste of time for a MEL input. You can use 7-2 instead(it works for single input too).
Cheers and thanks! Sorry to post here. Will use Doom9 going forward.RESET_9999 wrote: ↑Wed Feb 14, 2024 6:13 pm7-1 would be a waste of time for a MEL input. You can use 7-2 instead(it works for single input too).
I guess I didn't throw this device after all. I booted up 20.3 w/ DV and yeah, FEL playback is no better than other devices. Power Rangers' credits are gray and not white like they should be.ultrahorst wrote: ↑Wed Feb 07, 2024 11:51 pmJust a heads up in case you haven't heard:
Our old and well hated friend the UGOOS AM6+ rises from the dead.
With the latest CoreELEC 20.3 Nexus version, it finally supports proper Dolby Vision FEL decoding with HD audio passthrough. I just installed it on my device (I have the AM6b+), configured audio passthrough, installed Plex Mod 4 Kodi and it just played every MKV Remux with Dolby Vision I tried. No Issues with pausing or skipping.
Source and how-to: https://www.reddit.com/r/PleX/comments/ ... _team_has/
Beware: My device did not boot from the SD card right away, I had to press the "recovery" button on the bottom of the device before powering it on. Then it booted fine - following start directly booted to CoreELEC, no need to press the recovery button again.
On my Ugoos Power Rangers credits are white not grey. May be you are watching the DT.DL version and not ST-DL version?
I have a question.
I have some AMZN episodes that are both in HDR10-only and HDR10+. The issue I have is the HDR10+ versions are very very grainy. Much worse than regular film grain, especially in lower lit scenes. I measured both with MadVR (6-6) and the clear HDR10-only episodes peak at 2.1k nits whereas the HDR10+ episodes peak at 10k nits. Will analysing the clear HDR10+ episodes with CM v4.0 9 (3-1) @ 10k nits net me the same or similar HDR results as the grainy HDR10+ episodes or is it a bad idea?
Unfortunately, my TV (C2) doesn't support HDR10+ so I cannot directly compare the both.
Tmin=0 doesn't do anything with the raised black in DoVi on LG Oleds.chros wrote: ↑Thu Feb 08, 2024 5:47 pmYou don't even have to calibrate it, just to have good eyes (or lupe), guide.RESET_9999 wrote: ↑Thu Feb 08, 2024 12:09 pmThere are also ways to fix it when you calibrate but I don't know much about it... @chros could tell you more.
I will try out Tmin=0, have you yet?
good to know thanks... Strange how the DV engine works differently in LLDV for that aspect.
Question, I'm looking to batch analyse a folder. However, I want the MDL to be 7 and all the borders to be 0. Dovi_Scripts tells me to provide a external config file.
How do I do such thing?
https://www.youtube.com/watch?v=jBqbG5XM54g
if your folder with files all have the same MDL and Active area, you don't have to provide external config files.
PS: please ask your dovi_scripts questions on doom9 official support thread: https://forum.doom9.org/showthread.php?t=185317
I'll eventually stop answering questions about my script here on makemkv.
But if I copy the folder to Dovi_Tools after selecting 3-1, it doesn't ask me the MDL or borders I want to use. So how does it know I want option 7 and 0 borders?RESET_9999 wrote: ↑Thu Feb 22, 2024 3:18 pmhttps://www.youtube.com/watch?v=jBqbG5XM54g
if you input a folder and no config file is found, it will ask you for a MDL and L5 which will be used for all the videos in the folder.
If the videos in your folder are cropped, the script won't ask you about it and will automatically set L5 to 0
Dovi_Tools usually doesn't ask me to choose an MDL or L5 when I input a whole folder. Edit: Weird, it does now. Typical!RESET_9999 wrote: ↑Thu Feb 22, 2024 5:58 pmif you input a folder and no config file is found, it will ask you for a MDL and L5 which will be used for all the videos in the folder.
I also cannot seem to choose and MDL of 10000, I think I could in the past. Has it been removed? Also, is there are difference in HDR quality when choosing a, say, MDL 10000 over 4000?
Do you mean the OS HDR sends incorrect static metadata even when using MadVR with HDR Passthrough? Is NV HDR any different?RESET_9999 wrote: ↑Tue Feb 06, 2024 9:18 pmno i think the OS HDR always sends incorrect static HDR10 metadata.
Yes, 4000 MDL looks much darker vs 1000. As for the metadata, the L1 max and min are the same but the avg is not calculated the same. Trims are also different.
see: https://slow.pics/c/xlgE3H1t
this the only MDL possible in resolve and CMI also cannot seem to choose and MDL of 10000, I think I could in the past. Has it been removed?
hi @RESET_9999 is dovi tools available for arm64 linux anywhere?
