Matilda 4k Issue
that_slim_kid
Matilda 4k Issue
#1 Post by that_slim_kid » Wed Feb 14, 2024 3:11 pm
Anyone else having an issue with the Matilda 4k disc? It loads and starts ripping but then always fails halfway through.
Here is the log...
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
Using Java runtime from /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
Saving 1 titles into directory /Users/skidmore/Movies/MATILDA (1996) 4K
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '19069403136'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '19069403136'
DEBUG: Code 1073741829 at Hh/5y8K"X{/3-9GyB[:213131502
DEBUG: Code 101000192 at Hh/5y8K"X{/3-9GyB[:213131502
DEBUG: Code 0 at T0mEpj]eJn>8)6`dHZf=:29395471
DEBUG: Code 0 at U*O3~7zwOyqrVvV@n:*&:29394068
DEBUG: Code 0 at T0mEpj]eJn>8)6`dHZf=:213131157
DEBUG: Code 0 at T0mEpj]eJn>8)6`dHZf=:121262647
DEBUG: Code 9311232 at T0mEpj]eJn>8)6`dHZf=:121261773
DEBUG: Code 0 at !Pz>4E#mN1ylR(J>Zl}F :213137068
DEBUG: Code 0 at GRP5JA\FEB=6;NB*W&v6:29394022
DEBUG: Code 0 at GRP5JA\FEB=6;NB*W&v6:29404878
DEBUG: Code 0 at GRP5JA\FEB=6;NB*W&v6:29405384
DEBUG: Code 0 at GRP5JA\FEB=6;NB*W&v6:29403383
DEBUG: Code 0 at ~30V{5QD.o/>!.Y^fnZL:213141208
DEBUG: Code 0 at 4b#DVYs%f}Su%GUB:213132537
DEBUG: Code 0 at ?vhRd3>V;$. Ob~?0:29396207
DEBUG: Code 0 at ?vhRd3>V;$. Ob~?0:121264257
DEBUG: Code 0 at ?vhRd3>V;$. Ob~?0:213130490
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Failed to save title 3 to file /Users/Movies/MATILDA (1996) 4K/Matilda (1996)_t03.mkv
0 titles saved, 1 failed
Re: Matilda 4k Issue
#2 Post by Woodstock » Wed Feb 14, 2024 6:44 pm
Always at the SAME point, or "about the same"?
Same point usually means a disk error. "About the same" often means the drive shuts down for exceeding its power availability (is this a USB-powered device?) Limiting the speed can help in those cases, but what fun is that?
