The animated movie RIO fails with version 1.6.12
The dump is attached
RIO Fails backup
dtblair
Re: RIO Fails backup
According to the FAQ, RIO requires a disc specific sqv. Where are these downloadable if MakeMKV doesn't do it automatically?
crowfax
You submit all the files listed here, as well as the dump you posted on the forum:
http://www.makemkv.com/faq/item/8
Then you make sure the SVQ directory is set in MakeMKV and that you have allowed it internet access. Then once the SVQ is made it'll download and work automatically.
dtblair
With version 1.6.12, there does not appear to be any setting of the SVQ directory as in previous versions. I have internet access and the SVQ's are being downloaded as far as I can tell. Has anyone else been able to rip RIO?crowfax wrote:You submit all the files listed here, as well as the dump you posted on the forum:
setarip_old
@dtblair
I believe the setting you are seeking is now incorporated under the "General" tab of "Preferences" as:
"Allow to contact web server for updates:"
dtblair
Yes, I have that checked. In older versions you had to tell MakeMKV where the SVQ files could be found on your computer. This doesn't seem to be the case anymore.setarip_old wrote:@dtblair
Mike had posted a BD+ support announcement (http://www.makemkv.com/forum2/viewtopic.php?f=5&t=612):
List of discs with newer protection supported only by disc-specific SVQ:
Code:
Avatar collectors edition
Knight and day
Rabbit Hole
Taps
Rio
Conan the Barbarian
I read this as meaning a disc specific SVQ existed for RIO. This is apparently not the case. Maybe still in development?
setarip_old
@crowfax
Both the .MPLS and .CLPI are already included in the "Dump" file...
MrTeagan
setarip_old
Just my personal suggestion:
Try using MakeMKV with the "Rio" Blu-ray disc every 5 or 6 hours. I'm guessing that a fix should be distributed in the next 24 hours or so...
Joshin_IT
Sent in Log and other requested files. Anyone know how fast the turn around is on these?
Incredible program by the way, have had great results with every other disc I've tried.
herbcheck
Any luck?
Still getting errors
MakeMKV v1.6.12 darwin(x86-release) started
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in DASPI v1.3 mode.
Optical drive "BD-RE HL-DT-ST BD-RE WH10LS30 1.00" opened in DASPI v1.3 mode.
Loaded 19 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00002.svq
Failed to process BD+ code using generic SVQ from builtin/00002.svq
Processing BD+ code using generic SVQ from builtin/00001.svq
Failed to process BD+ code using generic SVQ from builtin/00001.svq
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as /Applications/MakeMKV/dump_Rio_DC95A8328085F4D6.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
Joshin_IT
Herbcheck-
Still getting that exact same error here. Hopefully will get svq soon. Any moderators have any updates?
herbcheck
Still not working in new update .13 out today. Any word about the status?
The SVQ file is updated, thanks for patience.
