RIO Fails backup
dtblair
RIO Fails backup
#1 Post by dtblair » Tue Aug 02, 2011 7:09 pm
The animated movie RIO fails with version 1.6.12
The dump is attached
dtblair
Re: RIO Fails backup
#2 Post by dtblair » Tue Aug 02, 2011 7:23 pm
According to the FAQ, RIO requires a disc specific sqv. Where are these downloadable if MakeMKV doesn't do it automatically?
crowfax
#3 Post by crowfax » Tue Aug 02, 2011 9:53 pm
You submit all the files listed here, as well as the dump you posted on the forum:
http://www.makemkv.com/faq/item/8
Then you make sure the SVQ directory is set in MakeMKV and that you have allowed it internet access. Then once the SVQ is made it'll download and work automatically.
dtblair
#4 Post by dtblair » Wed Aug 03, 2011 12:04 am
crowfax wrote:You submit all the files listed here, as well as the dump you posted on the forum:
With version 1.6.12, there does not appear to be any setting of the SVQ directory as in previous versions. I have internet access and the SVQ's are being downloaded as far as I can tell. Has anyone else been able to rip RIO?
setarip_old
#5 Post by setarip_old » Wed Aug 03, 2011 5:26 am
@dtblair
I believe the setting you are seeking is now incorporated under the "General" tab of "Preferences" as:
"Allow to contact web server for updates:"
dtblair
#6 Post by dtblair » Wed Aug 03, 2011 2:33 pm
setarip_old wrote:@dtblair
Yes, I have that checked. In older versions you had to tell MakeMKV where the SVQ files could be found on your computer. This doesn't seem to be the case anymore.
Mike had posted a BD+ support announcement (http://www.makemkv.com/forum2/viewtopic.php?f=5&t=612):
List of discs with newer protection supported only by disc-specific SVQ:
Code:
Avatar collectors edition
Knight and day
Rabbit Hole
Taps
Rio
Conan the Barbarian
I read this as meaning a disc specific SVQ existed for RIO. This is apparently not the case. Maybe still in development?
setarip_old
#7 Post by setarip_old » Wed Aug 03, 2011 7:23 pm
@crowfax
Both the .MPLS and .CLPI are already included in the "Dump" file...
MrTeagan
#8 Post by MrTeagan » Wed Aug 03, 2011 10:26 pm
Should we see a disc specific SVQ on this title soon? Anxious kids.
Director
setarip_old
#9 Post by setarip_old » Thu Aug 04, 2011 12:59 am
Just my personal suggestion:
Try using MakeMKV with the "Rio" Blu-ray disc every 5 or 6 hours. I'm guessing that a fix should be distributed in the next 24 hours or so...
Joshin_IT
#10 Post by Joshin_IT » Thu Aug 04, 2011 2:38 am
Sent in Log and other requested files. Anyone know how fast the turn around is on these?
Incredible program by the way, have had great results with every other disc I've tried.
herbcheck
#11 Post by herbcheck » Fri Aug 05, 2011 4:30 am
Any luck?
Still getting errors
MakeMKV v1.6.12 darwin(x86-release) started
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in DASPI v1.3 mode.
Optical drive "BD-RE HL-DT-ST BD-RE WH10LS30 1.00" opened in DASPI v1.3 mode.
Loaded 19 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00002.svq
Failed to process BD+ code using generic SVQ from builtin/00002.svq
Processing BD+ code using generic SVQ from builtin/00001.svq
Failed to process BD+ code using generic SVQ from builtin/00001.svq
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as /Applications/MakeMKV/dump_Rio_DC95A8328085F4D6.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
Joshin_IT
#12 Post by Joshin_IT » Fri Aug 05, 2011 4:38 am
Herbcheck-
Still getting that exact same error here. Hopefully will get svq soon. Any moderators have any updates?
herbcheck
#13 Post by herbcheck » Sat Aug 06, 2011 4:00 pm
Still not working in new update .13 out today. Any word about the status?
#14 Post by mike admin » Mon Aug 08, 2011 9:17 am
The SVQ file is updated, thanks for patience.
herbcheck
#15 Post by herbcheck » Mon Aug 08, 2011 9:42 pm
Thanks again!
