_D3V_
Re: Ultimate UHD Drives Flashing Guide Updated 2023 - BRUHD-PU3-BK
Post by _D3V_ » Fri Feb 09, 2024 11:20 am
Billycar11 wrote: Fri Feb 09, 2024 12:45 am
_D3V_ wrote: Thu Feb 08, 2024 7:18 pm Hi Guys
Thanks for your help
the one with enc should work
:D
Thanks a lot.
It worked perfectly, soon i'll buy the key for makemkv.
./makemkvcon f -d '/IOBDServices/3084F95F' -f /tmp/sdf.bin rawflash enc -i /tmp/DE_LG_BU40N_1.03_MK.bin
Reading input file /tmp/DE_LG_BU40N_1.03_MK.bin
Current Drive ID: BUFFALO_Optical_Drive_BU14_212106211330_XXXXXXXX
yes
 100% Operation finished
Done successfully
Post by MartyMcNuts » Fri Feb 09, 2024 9:56 pm
skerz2001 wrote: Fri Feb 09, 2024 5:01 am Just bought a BP50NB40 NB52. I bought and ran Marty's flasher which seemed way too easy to use. Find the drive and hit start. I didn't get any errors, but it still shows up as a BP50NB40 in MAKEmkv. It's currently reading Blu-Ray but will not read 4K UHD. So it looks like the cross flash didn't take, what would I be missing?
Watch the GIF in the first post.
ChampaignCowboy
Post by ChampaignCowboy » Mon Feb 12, 2024 5:43 pm
I've been looking at all this "libredrive" stuff and am thoroughly confused. Can someone create me a step by step for this unit, where the flashing software is, where the new firmware is, and whether or not my drive has encrypted firmware, or whatever that means?
I have an LG Drive with the following showing in MakeMKV
HL-DT-ST BD-RE WH149S40
Rev 1.05
Firmware date of 2120-05-06 14:44
Bus Encryption flast 17
Highest AACS Version 76
LibreDrive Info
Drive Platform: MT1959
Hardware Support: Yes
Firmware support: No
Firmware Type: Original (patched version available)
Firmware Version 1.05
DVD All Regions , BD Raw Data Read, BD Raw MetaDataread, and Unrestricted Read Speed all have Possible (with patched firmware)
Any and all assistance is appreciated. I bought this drive so I could get my 4k movies into my Plex.
Mr_Orange
Post by Mr_Orange » Mon Feb 12, 2024 9:18 pm
I assume that your drive is actually a WH14NS40?
If so, flash it to WH16NS60 1.02MK.
SDF Tool will auto detect encryption, etc, so just select the above firmware and hit flash.
If you follow through Post #1 of this thread, it's pretty clear.
Cor3000000323
Post by Cor3000000323 » Thu Feb 15, 2024 12:59 am
Would anyone offer a recommendation?
I'm planning to rip a thousand movie collection. About 15 4K Blu-rays (not a lot but I do not want to wait to rip them), over 500 DVDs and the rest are blu-rays.
Would one drive be better suited for this situation than another?
I'm in Canada btw.
Post by Billycar11 » Thu Feb 15, 2024 1:57 am
Cor3000000323 wrote: Thu Feb 15, 2024 12:59 am Would anyone offer a recommendation?
I'm in Canada btw.
pretty much the only drives you should consider are pioneers with old fw if you not able to get those then a BU40N/W/BP50/60 or just get the cheapest lg/asus they are the same
but yeah pioneers are best very glad not to be dealing with the LG/asus any more replacing drives for everyone constantly
Cor3000000323
Post by Cor3000000323 » Thu Feb 15, 2024 3:32 am
Billycar11 wrote: Thu Feb 15, 2024 1:57 am
I'm in Canada btw.
Thanks a lot for the quick response.
I'd love a pioneer the only thing holding me back is the big price difference ordering from a seller to ship here in canada, and the apparent slow speed of the drives (considering it's a thousand movies to be ripped). If the reliability of the BU40N is close to those that makes me hesitate.
Billy, one thing I don't understand is how come the BDR-213EBK, for example, isn't shown in the list of pioneer drives that work in the guide here, yet asmcom does sell it as a flashed UHD drive. I'm guessing there's something obvious I'm missing since it's not the only one, for example the BDR-XD07TS is also not on the list.
Post by Billycar11 » Thu Feb 15, 2024 3:35 am
Cor3000000323 wrote: Thu Feb 15, 2024 3:32 am
I'm in Canada btw.
guide is focused on usa drives and the EBK is not an offical UHD drive its crossflashed no one except the flashers can crossflash the pioneers so no point telling the public it works when it wont unless you buy a modified one
bkboudreau
Post by bkboudreau » Thu Feb 15, 2024 9:17 pm
I purchased an ASUS BC-12D2HT (Model #: B99V827) as I had been told that it can read 4k blurays however none of the 4k discs that I have seem to work in it and when searching I found this thread. Can someone please confirm if this drive is capable and safe to flash?
Post by Billycar11 » Thu Feb 15, 2024 10:24 pm
bkboudreau wrote: Thu Feb 15, 2024 9:17 pm Hello,
Yes it it's mt1959 you can flash it to Asus 3.10 you might need enc depending on fw date 2020+ needs it
Koubafire
Post by Koubafire » Fri Feb 16, 2024 6:07 am
I have ASUS BW-16D1HT with mk firmware LG WH16NS60 (because of sleep bug) but burning of 50gb blurays with nero express sometimes fail with DAO error - cant write at once (or something like that ) at the end. Should I get other firmware of another LG drive? Can you recomend good firmware for me? Asus firmware has a sleep bug.
Post by MartyMcNuts » Fri Feb 16, 2024 7:07 am
Koubafire wrote: Fri Feb 16, 2024 6:07 am Hello,
If you want to write discs, use the ASUS firmware or get another drive to use as a writer.
natra
Post by natra » Sat Feb 17, 2024 11:27 pm
Hi guys, will my drive work.
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number: RFDL020701WL
Firmware date: 2017-12-21
Highest AACS version: 76
Drive platform: RS8601
Firmware version: E114/ID71
Post by Billycar11 » Sat Feb 17, 2024 11:29 pm
natra wrote: Sat Feb 17, 2024 11:27 pm Hi guys, will my drive work.
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Yes but not with this guide as it's a pioneer email me for a flasher see below
bd-one
Post by bd-one » Sun Feb 18, 2024 4:08 am
Sorry if this is answered elsewhere/many times in this monster thread. I just purchased and flashed a LG WH14NS40. It came with encrypted 1.05 firmware. Thanks to MakeMKV and the SDFlasher, It flashed just fine to the suggested WH16NS60 1.02MK firmware.
Is the drive safe with this firmware for burning all media? I understand the WH14 is supposed to have 14x speed, whereas the WH16 has 16x speed.
My current Bluray media is limited to 6x, so the drive is not the limiting factor right now as the media dictates the burn speed.
