2012 4K (UK - 5050630062027) disc problem
geogan
Post by geogan » Sat Feb 10, 2024 9:03 pm
I see this was looked at in 2011... but I just got this new from Amazon UK and having awful trouble with this disc - had ZERO trouble with any previous UHD disc before this - disc appears in perfect condition - can't see any defects at all on surface.
Tried multiple times and unplugged/re-plugged/unmounted external drive etc. The drive had no trouble and making MKVs of the other five 4K discs I got from Amazon this week.
Is it a bad disc or is there some other failure?
Tried to attach the TGZ log file but it said its too large (106MB)
DETAILS
Product: BD-RE BU40N
Revision: 1.04
Serial number: MO4KCTI1614
Firmware date: 2120-05-06 11:42
Highest AACS version: 78
Firmware version: 1.04
Disc Information
Label: 2012
Timestamp: 2020-11-09 17:22:12
Protection: AACS2.0/C v76
Data capacity: 92.35 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at (V0PO7]PqU(,OTLVs:213130766
DEBUG: Code 0 at a%48&'jm4Zb*$m{*oY:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at a%48&'jm4Zb*$m{*oY:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
DEBUG: Code 1 at a%48&'jm4Zb*$m{*oY:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
DEBUG: Code 1 at a%48&'jm4Zb*$m{*oY:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
DEBUG: Code 2 at a%48&'jm4Zb*$m{*oY:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
DEBUG: Code 2 at a%48&'jm4Zb*$m{*oY:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
DEBUG: Code 3 at a%48&'jm4Zb*$m{*oY:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
DEBUG: Code 3 at a%48&'jm4Zb*$m{*oY:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at a%48&'jm4Zb*$m{*oY:213130789
DEBUG: Code 1 at a%48&'jm4Zb*$m{*oY:213130789
DEBUG: Code 2 at a%48&'jm4Zb*$m{*oY:213130789
DEBUG: Code 3 at a%48&'jm4Zb*$m{*oY:213130789
DEBUG: Code 4 at a%48&'jm4Zb*$m{*oY:213130789
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at a%48&'jm4Zb*$m{*oY:121264395
Saved AACS dump file as C:\Users\XXXXX/.MakeMKV/MKB20_v76_2012_3673.tgz
DEBUG: Code 0 at g1G,9/u[_c:!rg}]:213132721
DEBUG: Code 0 at g1G,9/u[_c:!rg}]:213131341
Re: 2012 4K (UK - 5050630062027) disc problem
Post by Billycar11 » Sat Feb 10, 2024 9:32 pm
Your drive is rebooting after it starts ripping
It needs more power or the disc is messed up
geogan
Post by geogan » Sat Feb 10, 2024 11:05 pm
I tried the drive plugged directly into the movie server PC and got the same sorts of crazy noises and errors (I know something is wrong when I hear drive completely stopping and starting again).
I didn't have any problems with hundreds of other Blurays and 4K discs using same drive and setup.
Hold on... I just tried to see if I got error with Fifth Element 4K again there just now that I successfully ripped previously today with no errors... and now its throwing strange errors for it too?? So must be something wrong with drive?? Normally unplugging drive restores it to working state... not sure what's wrong with it now... is there some reset method?
Saved AACS dump file as C:\Users\gaven/.MakeMKV/MKB20_v70_The_Fifth_Element_-_4K_UHD_D557.tgz
EDIT: yes... I forgot to unplug and replug the USB drive before the Fifth Element 4K test... after I did that.. the disc opened without error onto the track selection page withing a few seconds...
So it appears that the 2012 4K disc permanently breaks the drive until it is rebooted by unplugging?!?
Post by Billycar11 » Sun Feb 11, 2024 4:09 am
Yeah LG and Asus drives get into weird modes when they reboot unexpectedly then they need a full power cycle to fix them .
Pioneers don't have this issue
geogan
Post by geogan » Sun Feb 11, 2024 1:10 pm
Oh right... interesting... yes I noticed this a long time ago.
But do you think this "rebooting" is really a power issue? Has it happened others? Why would one disc do it and not all the others? Should I use some sort of external USB power brick instead of using the PC USB ports (which normally are not high-power USB capable)?
I think I have external USB power which swappable end plugs so I could plug into the small hole on back of drive case. Case I use is the "External ODD & HDD Device" Model NO: ECD918-SU3. It says power is DC 5V but doesn't specify what the micro type plug is or if the centre is positive or negative... don't want to blow it plugging in wrong way round...
EDIT: Just tried it again there with an external "SHNITPWR SNT-PS60W-3V12V-BK-UK" variable end plug swappable power plug (from Amazon), using the same size small round plug with black tip and set to 5V (it is center positive)... says its 1A max... drive powered up straight away... and tried 2012 disc and it read it straight away and got past all the initialization and onto track selection within a few seconds!
So it seems it WAS A POWER ISSUE! Now reading disc... strange... with the hundreds I have read powered by PC USB only that this was first disc that did something to trip the power limit!
Post by Billycar11 » Sun Feb 11, 2024 2:03 pm
This is a 3 layer disc they require more power.
Glad I was able to point you in the right direction I know these drives all to well
Fyi that pretty much means your drive is borderline on power you should use the power all the time sometimes LG/Asus drive will decide to move the laser in to the disc killing the disc and laser because it moves closer when low power.
geogan
Post by geogan » Sun Feb 11, 2024 7:26 pm
Yes I did notice it was 3 layer and I know that's tougher to read if there are any problems with disc surface - but I have ripped many 3-layer with this without problems before this.
Yes I am definitely going to use the external 1A power plug instead of the USB power from now on!
Thanks for the replies and help!
