i was trying to rip S3E10 of my Game Of Thrones DVD.
But i alyways get the following error when ripping.
Fehler 'SCSI-Fehler - MEDIUM ERROR:UNRECOVERED READ ERROR' trat auf während des Auslesens von '/VIDEO_TS/VTS_01_1.VOB' bei Offset '51853312'
Fehler 'Betriebssystemfehler - STATUS_DEVICE_DATA_ERROR' trat auf während des Auslesens von '\Device\CdRom0' bei Offset '51853312'
Fehler 'Interner Fehler - Vorgang wurde abgebrochen (140)' trat auf während des Auslesens von '/VIDEO_TS/VTS_01_1.VOB' bei Offset '51853312'
I thought myabe the disk was just bad but I can view the episode using VLC MediaPlayer with no problem.
Does anyone know a way to resolve this error?
MakeMKV cant read a Disk but VLCMediaPlayer can
Derolius
Re: MakeMKV cant read a Disk but VLCMediaPlayer can
Possible quick question - does the offset change on subsequent rip attempts?
No change usually indicates a disk issue. Changes (especially larger ones) often mean the drive is not getting sufficient power to go the speed it's attempting to go. Faster speed = more amperage needed.
