Bluray LG BE12LU30
gogul1
Bluray LG BE12LU30
#1 Post by gogul1 » Fri Feb 09, 2024 10:05 pm
Ok so I have the LG BE12LU30 and its marked as Libredrive “possible”. But I believe that its not on the list of flashed drives?
Is there anythinf I can do to help get this set up to trt and be flashed for 4K use?
Re: Bluray LG BE12LU30
#2 Post by MartyMcNuts » Fri Feb 09, 2024 10:42 pm
gogul1 wrote: Fri Feb 09, 2024 10:05 pm Ok so I have the LG BE12LU30 and its marked as Libredrive “possible”. But I believe that its not on the list of flashed drives?
I believe that is far too old and won't ever be able to do UHD. If libredrive is ever enabled on it, it will only stop the drive certificate from being revoked with newer AACS revisions.
