Pioneer drive and Libra
conlj
#1 Post by conlj » Fri Feb 09, 2024 4:15 pm
Hi, new to the product and forum,
Any idea when this will be able to perform as a libredrive?
Manufacturer: PIONEER
Product: BD-RW BDR-UD02D
Revision: 0.91
Serial number:
Firmware date: 2012-10-02
Highest AACS version: 12
Drive platform: Pioneer RS8410
Firmware version: ID84
Thanks in advance for any information
Jim
Re: Pioneer drive and Libra
#2 Post by Woodstock » Fri Feb 09, 2024 5:09 pm
Possible. But what do you want it to do? It will NOT read UHD disks. It will possibly be able to read out-of-region disks more easily, if you do those.
But your drive is several years older than what UHD.
#3 Post by Coopervid » Fri Feb 09, 2024 6:33 pm
Revision: 0.91
Serial number:
Jim
Check PM
