thirdmoon
Post by thirdmoon »
RESET_9999 wrote:
Fri Feb 09, 2024 12:10 am
thirdmoon wrote:
Wed Nov 01, 2023 6:02 am
When trying to grade HDR in DaVinci, the preview looks washed out (I have a 4K HDR monitor).
Is there any way to get a proper preview without any specific hardware?
If not, what is the most budget friendly option?
hey, I know you asked about this a while ago, but even though the Resolve manual says only the expensive Decklink cards work, I just got the cheap Deck link 4k mini monitor, and HDR preview works through HDMI.
Yeah, I looked at some YouTube videos and found out later. I got one too. Thanks anyway.
thirdmoon
Post by thirdmoon »
@RESET_9999
Is it okay to split and later merge DV mkv files. Does it cause any issues?
thirdmoon wrote:
Fri Feb 09, 2024 6:41 pm
@RESET_9999
I don't know, I never tried but if you don't remove any frames I guess it should be fine?
Sometimes I have to trim the start of a video and after, I always verify if my first frame still starts with a scene cut.
Ok i think i figured out why positive trim offset is ignored in TV-LED HDMI source. That value is the ''lift'' control in Resolve and unlike slope(gamma?) and power(gain?) , offset(lift) metadata will raise black bars if higher than 0.025(2100 in 12bit pq) and if the device doesn't use L5. So this means HDMI source will have worse quality than TVs internal player but lift is rarely used higher than 0.005. The positive offset metadata is 100% ignored, even values under 0.025 have no effect.
It doesn't make sense that the metadata is not ignored in LLDV though and I just tested on my LLDV devices and it does indeed raise letterbox black levels. Fake TV-LED devices also don't ignore positive lift.
test file without L5: https://drive.google.com/file/d/1NgG1Zp ... drive_link
test file with L5: https://drive.google.com/file/d/18eNbkD ... drive_link
https://www.youtube.com/watch?v=AVZ7xcgeEAM
NO L5:
PROPER L5 on device that use it:
Lift/Gamma/Gain: These controls function similarly to the Y-only Lift, Gamma, and Gain master
wheels of the Color Wheels palette, to let you trim the overall contrast levels of the image. The
Dolby Best Practices Guide recommends to limit positive Lift to no more than 0.025, and mostly
restrict yourself to using Gamma and Gain if necessary to lighten the image.
— Saturation Gain: Lets you trim the saturation of the most highly saturated areas within a scene.
Lesser saturated values will be less affected.
— Chroma Weight: Darkens saturated parts of the image to preserve colorfulness in areas of
the image that are clipped by smaller gamuts that don’t have enough headroom for saturation
in the highlights.
— Tone Detail: Lets you preserve contrast detail in the highlights that might otherwise be lost when
the highlights are mapped to lower dynamic ranges, usually due to clipping. Increasing Tone
Detail Weight increases the amount of highlight detail that’s preserved. When used, can have the
effect of sharpening highlight detail.
You can use Gamma to elevate the blacks/shadows as required and use the Gain trim control to restore any highlights that may have been elevated or clipped.
For example, if a program were graded relative to a 4000 nit display, along with a single 100 nit
BT.709 trim pass, then a Dolby Vision-compatible television with 750 nit peak output will reference
the 100 nit trim pass metadata in order to come up with the best way of “splitting the difference” to
output the signal correctly. On the other hand, were the colorist to do three trim passes, the first
at 100 nits, -cond at 600 nits, and a third at 1000 nits, then a 750 nit-capable Dolby Vision television
would be able to use the 600 and 1000 nit trim metadata to output more accurately scaled color
volume and HDR-strength highlights, relative to the colorist’s adjustments, that take better advantage
of the 750 nit output of that television.
Low Winter Sun
Post by Low Winter Sun »
Not so sure it's everything we want..
"Dolby Vision profile 5 and profile 8 both work. Profile 7 as used on Bluray discs, is currently converted on-the-fly by chosen mode by libdovi 209 due to a bug in the upstream proprietary code."
https://discourse.coreelec.org/t/coreel ... ion/20982
ultrahorst wrote:
Wed Feb 07, 2024 11:51 pm
Just a heads up in case you haven't heard:
Our old and well hated friend the UGOOS AM6+ rises from the dead.
With the latest CoreELEC 20.3 Nexus version, it finally supports proper Dolby Vision FEL decoding with HD audio passthrough. I just installed it on my device (I have the AM6b+), configured audio passthrough, installed Plex Mod 4 Kodi and it just played every MKV Remux with Dolby Vision I tried. No Issues with pausing or skipping.
Source and how-to: https://www.reddit.com/r/PleX/comments/ ... _team_has/
Beware: My device did not boot from the SD card right away, I had to press the "recovery" button on the bottom of the device before powering it on. Then it booted fine - following start directly booted to CoreELEC, no need to press the recovery button again.
ultrahorst
Post by ultrahorst »
Low Winter Sun wrote:
Sun Feb 11, 2024 12:46 am
This is true for devices that are not the ugoos AM6 plus or the Minix counterpart. Look at the source code, the libdovi conversion is disabled by default in the amlogic-ng-dv device tree: https://github.com/CoreELEC/CoreELEC/bl ... r-Am.patch
lexyz
Post by lexyz »
Ugoos AM6B+ with CoreELEC utilize FEL for sure.
Infamous Saving Private Ryan plays without flickering and with much-much less compression artifacts.
I would keep this device only for P7FEL mkvs
please ask any further questions related to the dovi_scripts here: https://forum.doom9.org/showthread.php? ... ost1997616
thanks.
jayper
Post by jayper »
RESET_9999 wrote:
Tue Feb 13, 2024 1:43 pm
thanks.
I've created an account on Doom9 but I can't post there for 5 days. If you have a moment: if I wanted to create screenshots for a DV MEL title, is the best process to use: Mode S (7) and Workflow 1? Thanks very much!
7-1 would be a waste of time for a MEL input. You can use 7-2 instead(it works for single input too).
jayper
Post by jayper »
RESET_9999 wrote:
Wed Feb 14, 2024 6:13 pm
Cheers and thanks! Sorry to post here. Will use Doom9 going forward.
bobbymkV
Post by bobbymkV »
I guess I didn't throw this device after all. I booted up 20.3 w/ DV and yeah, FEL playback is no better than other devices. Power Rangers' credits are gray and not white like they should be.
ragico
Post by ragico »
On my Ugoos Power Rangers credits are white not grey. May be you are watching the DT.DL version and not ST-DL version?
Trees
Post by Trees »
I have a question.
I have some AMZN episodes that are both in HDR10-only and HDR10+. The issue I have is the HDR10+ versions are very very grainy. Much worse than regular film grain, especially in lower lit scenes. I measured both with MadVR (6-6) and the clear HDR10-only episodes peak at 2.1k nits whereas the HDR10+ episodes peak at 10k nits. Will analysing the clear HDR10+ episodes with CM v4.0 9 (3-1) @ 10k nits net me the same or similar HDR results as the grainy HDR10+ episodes or is it a bad idea?
Unfortunately, my TV (C2) doesn't support HDR10+ so I cannot directly compare the both.
chros
Post by chros »
chros wrote:
Thu Feb 08, 2024 5:47 pm
RESET_9999 wrote:
Thu Feb 08, 2024 12:09 pm
There are also ways to fix it when you calibrate but I don't know much about it... @chros could tell you more.
You don't even have to calibrate it, just to have good eyes (or lupe), guide.
I will try out Tmin=0, have you yet?
Tmin=0 doesn't do anything with the raised black in DoVi on LG Oleds.
